07-29-2015, 01:37 AM | #1 |
aem 30-6050 in sr20?
I want to switch over the ECU on my 1jz to an AEM infinity and run the AEM ver. 2 honda box 30-6050 on my s13 with an sr20. Is it possible to make the 30-6050 work with my sr20?
08-01-2015, 12:26 PM | #2 |
I don't see why not as long as it's wired up right. Using AEM's CAS disk gives the ECU the 12 crank/1 cam signal that you'd see in a B series (or similar vintage) Honda.
08-01-2015, 05:32 PM | #3 |
I tried using a 30-6051
Didn't work and it won't Even after opening it/losing warranty and changing jumpers Some hardware changes need to be made (ie. Unsolder resistors on the boards) It's configured to read reluctor pickups, not hall/optical which is what the sr uses I trie asking AEM for help but they gave me attitude and to sum it up. All they said we make a PlugNplay box for SR I wouldn't bother with it if I were in your shoes |
08-01-2015, 08:38 PM | #4 |
Ahhh... that would be a big change. Series 2 are kinda annoying in that respect that it's a physical hardware change to read a different type of pickup.
The stock CAS will output a Hall effect type signal.
08-01-2015, 10:42 PM | #6 |
Decided to just go with power fc.
08-01-2015, 10:47 PM | #8 |
Truuuuuuuuuuuuuuuu
08-02-2015, 12:15 AM | #9 | |
I ended up using a vipec instead just because AEM gave me attitude via email. So now I have an AEM 30-6051 sitting collecting dust if anybody wants LOL |
08-11-2015, 08:58 AM | #10 | |
I'm running my SR on an AEM Infinity 6 with the AEM CAS disk installed. Wired it into the cam and crank hall effect inputs - works like a charm.
