Old 10-25-2016, 09:49 PM   #1
NateMR2
NateMR2 is an unknown quantity at this point
Ls coil pack trouble help plz?
So i wired up and installed some ls coil packs started the car.. Well it runs weird motor seems to shake a bit more i have a very short exhaust i installed at the same time out the hood and it is back firing a little i checked the timing on the first cylnder and and the timing marks are no where to be found the were on the bottom so 180 degrees oit? No way car wouldnt run i am so confused... I tried adjusting the cas a bit and it didnt seem to do a lot. Im pretty sure there all wired to the correct plug 95% and there is no way no1 could be wrong no wire is long enough for that. I am running on the stock ecu but from what i ready other people do this with no issue i have a series 2. Any help plz and thank u. Cylnder 2 was showing advance 31 degrees its very strange
NateMR2 is offline   Reply With Quote
Old 10-25-2016, 10:00 PM   #2
KAT-PWR
KAT-PWR's Avatar
Wow. Just wow.
MRP Manufacturing
Old 10-25-2016, 10:32 PM   #3
derass
I think that with the clear, detailed information you've provided someone should be able to help.
Old 10-25-2016, 11:02 PM   #4
NateMR2
Originally Posted by KAT-PWR View Post
Wow. Just wow.
Im so glad u comment on all my posts ur such a huge help.
Old 10-25-2016, 11:56 PM   #5
KAT-PWR
KAT-PWR's Avatar
You're welcome, not all heros wear capes.
MRP Manufacturing
Old 10-26-2016, 08:23 AM   #6
TheRealSy90
TheRealSy90's Avatar
Sounds like you mixed up the firing order when deleting the coilpack igniter.
Such a good signature.
Old 10-26-2016, 09:39 AM   #7
Juan@Fontananissan
Juan@Fontananissan has a spectacular aura aboutJuan@Fontananissan has a spectacular aura aboutJuan@Fontananissan has a spectacular aura aboutJuan@Fontananissan has a spectacular aura aboutJuan@Fontananissan has a spectacular aura aboutJuan@Fontananissan has a spectacular aura about
sounds like it.
Competition Engines & Dyno Tuning.
(951)708-1648 | [email protected]
Juan@Fontananissan is offline   Reply With Quote
Old 10-26-2016, 11:03 AM   #8
NateMR2
Its a s2 so no igniter i dont think i could have messed up the order cause the wires arent long enough 😲
Old 10-26-2016, 12:32 PM   #9
TheRealSy90
Well at least we know now what engine you have, your first post didn't really state anything.
Old 10-26-2016, 12:59 PM   #10
NateMR2
Sorry about that
Old 10-26-2016, 01:01 PM   #11
NateMR2
I mean pretty much all that was done was used existing power for all 6 used existing ground andded one ground to all 6 then the signal
Old 10-26-2016, 07:28 PM   #12
NateMR2
Fixed cylnder one and 2 were flipped took the plugs out they were soaked
