09-01-2014, 08:39 PM | #1 |
Vaccum should read what ? At idle on s13 red top
What should sr20 vacuum read at idle I've seen post an stuff say -18,-20 not really sure. I am doing a boost leak test and trying to see if this fixes the jumpy idle after revving.
09-01-2014, 09:36 PM | #3 |
Yep, healthy motor should be around 20", could be more. Larger cams can drop that roughly 2-3".
09-04-2014, 04:16 PM | #6 |
No, you'd have less vacuum if you have larger cams.
09-04-2014, 04:33 PM | #8 |
Exactly. Larger cams have bigger lifts and durations, which cut down on created vacuum.
09-16-2014, 11:22 AM | #9 |
Uhm mine is like 7-8" vac on 280 degree 11.5mm lift with full ported head and 1mm over sized valves. I had to check with the Head shop and mine is normal for ITB's at that vacuum. Lucky I can still stop with my brakes(barely).
09-16-2014, 01:56 PM | #11 | ||
GM2 (SW/AW)
barely stopping? Even when pumping the brakes? Are you sure you don't have a leak though, it wouldn't hurt to boost leak test just to be safe. Also a good idea to inspect that check valve in your booster line. Never a bad thing to blow out your vacuum booster diaphragm
KA-T for life! Current for sale advertisement |
09-16-2014, 02:20 PM | #12 | |
09-16-2014, 03:20 PM | #13 |
my blacktop idles about -22-24 and likes to almost die after revving, I could have a boost leak but I assume it's cuz the vta bov since my car seems to hold boost fine
09-16-2014, 07:56 PM | #14 |
Idle vacuum needs to be read from a standard rpm idle, for anyone to begin to compare. You guys idling at 1100rpm ...
