Polls Post All Polls in Here. |
View Poll Results: "Stealth Black" or Chrome Finish | |||
"Stealth Black" | 117 | 79.05% | |
Chrome | 31 | 20.95% | |
Voters: 148. You may not vote on this poll |
05-30-2008, 09:39 AM | #1 |
SPL PARTS version 3 arms - new adjuster info and poll
This is our new adjuster design, a hybrid clamp and jam nut combination. This design uses a billet aluminum clamp on the rod end side and a jam nut on the arm side, to lock down your alignment setting. We are using the clamp design for several reasons: with the old jam nut design, when tightening the jam nut on the rod end, that has a tendency to rotate the rod end. This makes it difficult to hold the alignment setting, as the rod end threads in/out combined with the jam nut stretching the thread, the alignment can shift 1/16" or more. It also makes it difficult to keep the spherical bearing centered to prevent binding under suspension travel. To get an accurate alignment while keeping the bearing centered becomes a tricky juggling act. The clamp design solves all these problems, allowing the alignment to be set without moving the rod end. We continue to use a jam nut on the arm side because I have found that because of its size, it can be tightened without moving the adjuster or changing the length of the arm. FWIW the new adjuster drives up our production cost on each pair of arm by $10-15. It is much more expensive than a 20cent jam nut. But for now we are keeping prices unchanged. All our v2 arms can be upgraded to the new adjuster, I will put up the upgrade information later this month. Here is a picture of all our rear arms equipped with the new adjuster: I need to poll you guys about using a different finish on our suspension arms. We have been using chrome since the beginning because of its high chip resistance and cosmetic appearance. However chrome being a tough finish, develops micro-cracks and pinholes, which are usually not visible, but can cause small rust bubbles to develop over a long period of time, in certain climates. I have been looking into different finishing possibilities. I wanted to avoid powdercoating because once chipped, powdercoat tends to come off in chunks. Also it creates problems with threaded parts. The finish I came up with is Cadmium w/ Black Chromate plating, followed by baking to reduce hydrogen embrittlement. Cadmium plating has better corrosion resistance compared to chrome, it will also prevent long term galvanic corrosion of the steel arm if the arm gets exposed to any salt. And because we can get these baked after plating, it will actually make the parts a little stronger (less hydrogen embrittlement). The downside is that it is not as good looking as chrome... To compare, this is our chromed rear upper arms: Here is the new "Stealth Black" rear upper arms: The poll question is: if only the "Stealth Black" finish was available, would that otherwise deter you from buying the product? ie. You would buy the chromed product, but not the "Stealth Black". It would be too difficult for me to try to stock both finishes, so I have to decide whether to switch everything to "Stealth Black", or keep the chrome. |
05-30-2008, 09:45 AM | #3 |
Trader Rating: (54)
Feedback Score: 54 reviews
Edit: Read the thread thoroughly this time and the stealth black is an improvement on an already improved item so that's a big yes to Stealth Black then. Are those arms for both the s13 and s14?
- Jimmy Wanted: TBD For Sale: TBD |
05-30-2008, 09:49 AM | #6 |
The stealth black is lookin good...I would def. buy those over the chromed ones...
Juicy slayin aint easy, but dammit somebody has to do it!!! |
05-30-2008, 09:54 AM | #7 |
Yup all 3 arms fit S13 and S14 chassis. Our toe arms come with 2 sets of bushings (not shown) that allows it to fit both chassis. The traction rod is common to both. The rear upper arm is also designed to fit on both chassis.
05-30-2008, 09:55 AM | #8 |
Stealth black looks good to me.
I need to pick up some shit in the near future from you too.
Team Pterodactyl SHARK ATTACK!!! LookoutDrift |
05-30-2008, 09:56 AM | #10 |
i agree with stealth black.
Its great how you guys are looking to improve your designs. i do notice with the MR arms i have that the rod ends do twist a lot when trying to lock the jam nut. also the rod end does swivel making it hard to get the rod length correct. keep up the good work. i wish i had gone with real arms to begin with like SPL |
05-30-2008, 10:01 AM | #12 |
aWingThing.com
Stealthy Black for the win.
What I do for a living...www.mhrussell.com |
05-30-2008, 10:02 AM | #13 | |
aWingThing.com
EDIT: Actually I don't see how to do it either.
05-30-2008, 10:23 AM | #20 |
Trader Rating: (47)
Feedback Score: 47 reviews
I like the bling bling, but the stealth black looks cool.
Like sema flat black is what I call it. As long as it works, I wouldn't care if it was in pink with white strips. |
05-30-2008, 10:29 AM | #21 |
My main concern would be the hex screws that you are using on the collar, I have night mares about those things and how they have a tendency to strip out.
05-30-2008, 10:35 AM | #23 |
your suspension arms rust with the chrome, when do the stealth black rucas come available to buy my vote for the stealth black
how much for whats seen in the pic black rucas |
05-30-2008, 10:39 AM | #24 | |
Make sure you put which size allen key to you. Stealth black = YES! |
05-30-2008, 10:46 AM | #27 |
If they strip, just slip off the collar and use a worm gear hose/band clamp while you wait on a new collar from us But not to worry, it doesn't take much torque to lock down the collar, so chances of that happening is slim unless you get overzealous torquing it down.
05-30-2008, 10:51 AM | #29 |
FUNCTION>FORM So Black is where it's at! Plus you rarely see the Chrome arms anyway so who cares, i vote for the added strength and corrosion properties.
05-30-2008, 10:52 AM | #30 |
The new adjusters are shipping on all arms as of this week, however the arms will still be chromed. I do have the stealth black RUCAs available now, but toe arms and traction arms will be about 3-4 weeks out.
RUCAs are $249. For now there are no changes in pricing on the rear arms between v2 and v3 (chrome or black). |
