Old 09-22-2008, 09:24 PM   #1
bowflex
bowflex is an unknown quantity at this point
SR boost controller for SR-20DET
i am making 350whp on my S13 with an SR-20 engine swap with 6lbs of boost. I'm running really rich (especially since I'm at 7000 feet) and want to get a boost controller that links to my ECU so it can regulate how rich I'm running along with getting my boost pressure higher. I want to be able to decide in the cab (if i want to mess around) to turn up the boost to 10-12lbs and have the ECU compensate, then after I'm done put it back down to 6lbs and run a lot leaner so I'm not needlessly wasting gas. I have 550 cfm fuel injectors and an upgraded turbo (greddy t-28). Everything should be good to go engine wise. My ECU is currently Enthalpy tuned but i don't really want to ship it out and pay $500. any advice on what i should get, or just help on anything?
bowflex is offline   Reply With Quote
Old 09-22-2008, 09:42 PM   #2
S14cagged
S14cagged is an unknown quantity at this point
1st of we need a dyno-chart of this 350whp on 6psi
but what you need is a SAFC to control the A/F ratio's, put it on the dyno or buy a wideband to see what A/F's you are running and go from there.
but listening to this i would recommend you take it to a professional
S14cagged is offline   Reply With Quote
Old 09-22-2008, 10:15 PM   #3
tommyboi
tommyboi is an unknown quantity at this point
stock sr20det boost solenoid and rock nistune!... you will be able to make different maps in real time, and if you have a s14/s15 sr. I believe its said that you can actually map the stock boost controllers in those motors. i have not tried it out yet so i don't know much about it but im looking to get it in a month or two... check this forum out Nistune Forums :: View topic - Control Boost with ROM Tuning?...just my 2 cents...
tommyboi is offline   Reply With Quote
Old 09-22-2008, 11:34 PM   #4
Erjay1
Erjay1's Avatar
Erjay1 is making a name for him/her selfErjay1 is making a name for him/her self
If your ecu is already enthalpy tuned then retunes are only like $150 or something.
Erjay1 is offline   Reply With Quote
boost controller, ecu
