09-11-2017, 01:26 PM | #1 |
Oil return from stock catch can to block loose.
The part that you hook the hose onto from the factory catch can that attaches to the block right behind the turbo is loose and I suspect it may be leaking oil. I can rotate it side to side without to much effort. Is there a way to tighten this, I can't really look at it without removing the turbo.
Thanks Jason |
09-13-2017, 01:23 PM | #2 |
if its like on an SR they are not threaded, they are push/interference fit. so you should be able to wiggle it out/clean it up and put something on it to 'glue' it back in. I would use RTV or Loctite. just check the melting temp of whatever you use.
