Old 11-19-2012, 04:14 PM   #1
berto1
berto1's Avatar
berto1 is an unknown quantity at this point
s14 Rear differential (I believe) noise/vibration
My S14 used to clunk into drive-ways and parking lots until I added some Peak Performance poly subframe spacer bushings 3 years ago. Also swapped all of the control arms for battle version adjustable units at the same time, and replaced bushings on the knuckle and sway bar (19mm JDM unit). The car has been tight and quiet, except for a random 'clonk' seeming to come from the rear end every once and a while when I let off the throttle. The car drives quiet and smooth around town and 80mph + on the freeway with no issue...untill...
I squeeze 5 people into the damn thing like I did last night... drunk friends in Belmont Shore = I'm the DD. Anyways...
Upon acceleration I get this weird vibration/wabble noise coming from the rear end. When I cruise or let off the throttle the noise goes away. After I dropped people off the noise went away and it was as before. I have not changed out the rear differential bushings, could this be it? I'm hoping its not something worse. If you've had this problem please tell me how you resolved it!
berto1 is offline   Reply With Quote
Old 11-19-2012, 06:13 PM   #2
ghoti
ghoti's Avatar
ghoti is an unknown quantity at this point
I've had this happen with a J30 diff which also has bushing in the diff ears like the S14. I just had to tighten those bolts, maybe you should try that. Something else that I can think of is wheel hop.
Originally Posted by SaNTi View Post
^ That shit always scares me... and I clinch my asshole a little bit.
ghoti is offline   Reply With Quote
Old 11-19-2012, 06:57 PM   #3
berto1
berto1's Avatar
Before I added the peak performance spacer bushing I had wheelhop... non-existent since then. I'll try tightening the bolts!
Old 03-08-2013, 08:55 AM   #4
GreenMNTDC5
GreenMNTDC5's Avatar
GreenMNTDC5 is an unknown quantity at this point
Did tightening the bolts work for you?
GreenMNTDC5 is offline   Reply With Quote
Old 03-08-2013, 09:50 AM   #5
Mikester
Mikester's Avatar
LOL This thread is nearly 4 months old. I doubt he will reply
Old 03-08-2013, 10:11 AM   #6
GreenMNTDC5
Worth a shot, worst case i'm out .0003 seconds of my time.
Old 03-08-2013, 12:27 PM   #7
berto1
berto1's Avatar
s14 Bushings
The diff is coming out and new bushings are going on. Also installing a helical LSD at the same time since it will be out. Subframe seems to still be pretty solid all around. I'll update once everything is back on.
bushing, differential, rear end, suspension, transmission
