05-10-2017, 11:12 PM | #1 |
Quest Alternator Upgrade How-To!
Delete. I don't remember the drill bit size and I don't want anyone to goof up.
NAVY Last edited by snow hawk; 08-14-2017 at 12:50 AM.. |
05-13-2017, 02:57 PM | #2 |
is this the same as the 90's quest?
http://www.240sxforums.com/forums/rb...ject-s-rb.html |
05-13-2017, 03:01 PM | #3 |
I believe the early 90's quest was a 110 amp, but I'm not sure if it's the same setup. Should be I think
NAVY |
05-14-2017, 10:23 PM | #4 |
Nice write up! One thing I'll add, remember when working with manual belt tensioners to loosen the bolt that secures the accessory to the engine/bracket along with the lock nut and adjustment bolt. Shouldn't need a prybar then. Good work man!
05-14-2017, 10:24 PM | #5 | |
You're absolutely right. I couldn't get to mine (on the power steering pulley) so I skimped and used force lol. Thanks man! Appreciate it! Hope it helps a few people!
NAVY |
01-06-2019, 05:31 PM | #6 |
Bumping this from the dead. I've done this once before and have forgotten trim step. Does the front or rear top area need to be trimmed? If I trim the front this will screw up the threads..?
01-07-2019, 08:22 AM | #7 |
01-07-2019, 09:13 AM | #8 | |
01-07-2019, 12:48 PM | #9 |
I installed a quest alternator on my KADE and didn't need to trim any bracket. I left the bottom mount as-is, and loosened the bracket mount that bolts to the timing cover. Then I installed the alternator and tightened back down the bracket.
The factory belt was a little too short at first, but I finagled it on and has been fine ever since. The only thing I noticed was the threaded hole at the top of the alternator was different so I drilled it out a little bigger and used a nut and bolt to tighten down the adjustment piece. |
01-07-2019, 01:22 PM | #10 | |
01-07-2019, 05:33 PM | #11 |
I deleted all miscellaneous things off my intake manifold so I am unsure if it'll work on a stock intake manifold. I followed Ennes's tip and just loosen my alternator bracket, and slipped the alternator in. I did not need to trim the top bracket like I did before on my first car.
Hope this helps someone in the future |
