Old 03-28-2012, 10:01 PM   #1
XxHybridx
XxHybridx's Avatar
XxHybridx is an unknown quantity at this point
S13 Pop up Headlight Issue Thread
So my car was in a accident about a year ago, it was hit in the driver side headlight. My car is fixed now and ready to go. My only issue with the car is that the damn headlights don't go up and down. They turn on fine.
I put on working relays from my buddie's s13 and nothing. I also switched a working button on the bezzel that makes them go up and down, but no luck. Theres a couple threads on Nico that show how to clean the contact points on the actual level that turn the lights on. I'll probably try that next.(but i dont think that would stop them from going up and down when i press the button on the bezzel.
Oh and i'm pretty sure the motors work because we attached the motors directly to a battery and they went up and down just fine, so it sounds like an electrical issue.
My guess is when i got hit, the wiring on the relay box by the air filter got damaged.
Any thoughts anybody? Figured people can put their problems on this thread since i know these headlights gives problems all the time.
XxHybridx is offline   Reply With Quote
Old 03-29-2012, 11:45 AM   #2
Mishkin_707
Mishkin_707's Avatar
Mishkin_707 is an unknown quantity at this point
That may be the case, check for the wiring on the relay box, I don't remember if there are any kind of fuses since I've gone Silvia front I don't remember much about the flip ups
Mishkin_707 is offline   Reply With Quote
Old 03-29-2012, 01:29 PM   #3
XxHybridx
XxHybridx's Avatar
Oh, and also, when i turn my lights on, if i place my hand on the relay by the car battery, i can hear a clicking/pop sound coming from the relay.
Old 03-29-2012, 01:34 PM   #4
tuktuk23
tuktuk23 is an unknown quantity at this point
check ur ground homie
little screw on the side baffle by the headlight motor.
tuktuk23 is offline   Reply With Quote
Old 03-31-2012, 08:40 PM   #5
thundertiger25
thundertiger25's Avatar
thundertiger25 is an unknown quantity at this point
The only two issues I've ever had with my pop-ups, the main fuse was dead but you checked that. The other is to change out the headlight lever by the steering wheel. When I first got my daily it had a similar problem after checking everything else I was like why not? I swapped it and it worked!
Rockin' my EB front lip!
thundertiger25 is offline   Reply With Quote
Old 03-31-2012, 09:55 PM   #6
Bushido
Bushido's Avatar
one of my headlights goes up and down faster, how do i sync them up?
Old 03-31-2012, 10:51 PM   #7
rcdad123
rcdad123's Avatar
rcdad123 is an unknown quantity at this point
what do you guys do to keep the s13 headlights from bouncing up and down. both of my headlights do this and it`s annoying the people in front of me. luckily, i have not been pulled over yet due to this.
rcdad123 is offline   Reply With Quote
Old 04-01-2012, 12:47 AM   #8
Touge_Monster
Touge_Monster's Avatar
Touge_Monster has a reputation beyond reputeTouge_Monster has a reputation beyond reputeTouge_Monster has a reputation beyond reputeTouge_Monster has a reputation beyond reputeTouge_Monster has a reputation beyond reputeTouge_Monster has a reputation beyond reputeTouge_Monster has a reputation beyond reputeTouge_Monster has a reputation beyond reputeTouge_Monster has a reputation beyond reputeTouge_Monster has a reputation beyond reputeTouge_Monster has a reputation beyond repute
The wiring for these things are a nightmare. Make sure u go through all the relays/ fuses. Check the fuse that looks like the eng cont fuse on the passenger side. If that's fine maybe get some really long wire and try jumping the headlight from different parts of the wiring. It may allow u to pinpoint the issue. Oh and diffidently check the stalk on the steering column as previously stated.
...180 Style...
Originally Posted by Panda-Eats-240 View Post
This thread gave me aids, thank you based god.
Touge_Monster is offline   Reply With Quote
Old 04-01-2012, 02:18 AM   #9
HesterLigon
HesterLigon is an unknown quantity at this point
HesterLigon is offline   Reply With Quote
Old 06-19-2012, 01:23 AM   #10
soryu
soryu's Avatar
soryu is an unknown quantity at this point
There should be a metal trim that goes around the headlight to keep it in place.
soryu is offline   Reply With Quote
Old 06-19-2012, 08:37 AM   #11
sil80d
sil80d is an unknown quantity at this point
The real issue with pop ups is that they are horribly ugly. Except on mk2 and mk3 supras
sil80d is offline   Reply With Quote
Old 06-19-2012, 08:51 AM   #12
Piggy
Piggy's Avatar
Piggy is an unknown quantity at this point
Mine had this issue. Though I can't say how to fix because I just left them up from then on.
Originally Posted by mrmephistopheles
This piggy know's what's up.
Piggy is offline   Reply With Quote
Old 06-19-2012, 10:38 AM   #13
MeGusta.jpeg is an unknown quantity at this point
Mine don't work either, put a brand new headlight switch and still didn't work, how do I connect the motors to the battery to see if the motors are good?
MeGusta.jpeg is offline   Reply With Quote
Old 06-19-2012, 10:43 AM   #14
coupesallday!
coupesallday!'s Avatar
coupesallday! is an unknown quantity at this point
Send a message via MSN to coupesallday!
mine won't go up or down either. and i cleaned the switch on the steering wheel like they did on nico but nothing..
coupesallday! is offline   Reply With Quote
Old 12-10-2016, 09:14 PM   #15
Kamronman
Kamronman is an unknown quantity at this point
hahahah holy crap man!!
Kamronman is offline   Reply With Quote
Old 12-10-2016, 10:20 PM   #16
Kamronman
Anybody find broken wiring or anything?? I have the same issue, absolutely no operation of my motors. I've repaired multiple broken wires and can't get them to turn on. When I plug in my motor switch, i hear a relay open or close, then when i push the switch i hear another relay open or close, is there a short causing that relay to make a noise when I plug in my switch?
Old 12-13-2016, 06:26 PM   #17
slamburger
slamburger's Avatar
Trader Rating: (24)
slamburger is just really niceslamburger is just really niceslamburger is just really niceslamburger is just really niceslamburger is just really niceslamburger is just really niceslamburger is just really niceslamburger is just really niceslamburger is just really nice
Feedback Score: 24 reviews
This just happened to my car about a month ago. If i screw them down manually then turn lights on or flash hi beams they come up no problem. Mine just wont go back down.
slamburger is offline   Reply With Quote
Old 12-13-2016, 07:18 PM   #18
EnnEssEnnKAT
EnnEssEnnKAT's Avatar
EnnEssEnnKAT can only hope to improve
I'd set everything so that the headlights should be up, and then remove all of the headlight up/down relays and take a volt meter to check each single socket for 12V. If there's no 12V anywhere that's a good place to start. Then do the same thing with the headlights down. Headlights can go up and down without ignition, so there's 12V around constantly in the up and down retract circuits.
Sent from mTalk
EnnEssEnnKAT is online now   Reply With Quote
Old 12-13-2016, 07:58 PM   #19
XMcEvilson
XMcEvilson's Avatar
XMcEvilson is an unknown quantity at this point
what years are your cars? anytime I've had an 89 or 90 the headlights worked prefect, 91-93 they're always messed up
XMcEvilson is offline   Reply With Quote
Old 12-14-2016, 10:15 AM   #20
slamburger
slamburger's Avatar
Trader Rating: (24)
My car is 89. Lights worked perfect up until a month ago. I just leave them up. manually turn them down for track events.
Old 12-14-2016, 04:21 PM   #21
TheRealSy90
Four Lug Swap
TheRealSy90's Avatar
TheRealSy90 has much to be proud ofTheRealSy90 has much to be proud ofTheRealSy90 has much to be proud ofTheRealSy90 has much to be proud ofTheRealSy90 has much to be proud ofTheRealSy90 has much to be proud ofTheRealSy90 has much to be proud ofTheRealSy90 has much to be proud ofTheRealSy90 has much to be proud ofTheRealSy90 has much to be proud ofTheRealSy90 has much to be proud of
My 92 has this issue. They go up fine, but the passenger side won't go down by itself. I can manually turn it down and it stays down, and goes up again when I turn the headlights on. It just isn't getting the down/return signal I guess? No clue.
Such a good signature.
Old 12-15-2016, 01:35 AM   #22
Hoffman5982
Hoffman5982's Avatar
Trader Rating: (25)
Feedback Score: 25 reviews
This mother fucker really bumped this old thread to get his post count up. That should be an insta ip ban
Old 12-30-2016, 08:22 AM   #23
Sway500
Sway500 is a name known to allSway500 is a name known to allSway500 is a name known to allSway500 is a name known to allSway500 is a name known to allSway500 is a name known to allSway500 is a name known to allSway500 is a name known to allSway500 is a name known to allSway500 is a name known to allSway500 is a name known to all
I have had the same issue with my pop ups for years. If I screw my pop ups down and turn on the headlights they come up, but will not go down. I have chased everything, but I'm totally here for this thread, someone has to have a solution that works, too many people have had this issue, and it's not the relays, grounds, or anything like that.
Sway500 is offline   Reply With Quote
Old 12-30-2016, 11:10 AM   #24
Xaser
Xaser is an unknown quantity at this point
The fix is simple, sorry for my poor english, but the system or mechanism work on one way, if you assembly "upsidedonw" the lights come up, or come donw, only one of this.
you must disassembly and put all levers fine, check with other work headlight or other S13.
again, sorry for the bad english
Xaser is offline   Reply With Quote
Old 12-30-2016, 11:29 AM   #25
Oh Em Zee
Oh Em Zee is an unknown quantity at this point
Also have an issue on my 93 s13. headlights go up. headlights don't go down. (but can be manually lowered and stay down just fine)
Oh Em Zee is offline   Reply With Quote
Old 01-07-2017, 12:23 AM   #26
Mysterious Driver
Mysterious Driver's Avatar
Mysterious Driver is an unknown quantity at this point
Send a message via AIM to Mysterious Driver
Mine use to work perfectly but after fixing them from an accident they were always up.
Now with the new head lights etc. They won't go up when i turn the head lights on but they will go down, no problem. They will only flip up when the high beams are up, has anyone has this particular problem before?
Mysterious Driver is offline   Reply With Quote
Old 01-08-2017, 04:02 PM   #27
leedle-leedle-lee
leedle-leedle-lee is an unknown quantity at this point
Half of these issues sound like it could be to do with the brown/green wire sleepy eye mod. If you cut that wire and don't install a switch, the lights will go down when you use the button and go up when you turn the actual lights on, but won't go up when you hit the button.
Will get some pictures and maybe a video if anyone needs further clarification?
leedle-leedle-lee is offline   Reply With Quote
Old 11-14-2017, 07:58 AM   #28
Itsuki Takeuchi
Itsuki Takeuchi's Avatar
Itsuki Takeuchi is an unknown quantity at this point
i agree withe Leedle
check that brown wire!
i hate Fanbois wanting to do the sleepy eye mod- cutting the brown wire is the incorrect way of doing it!!!
Search DIY Tengoku on youtube- should be one of the top 5 videos.
Itsuki Takeuchi is offline   Reply With Quote
Old 01-14-2018, 04:35 PM   #29
akruger34
akruger34 is an unknown quantity at this point
Sorry to further gravedig this post, but i noticed my car had the brown wire clipped, I put it back together and now the button makes them go up and then immediately back down. Any suggestions? Headlight stalk operates them as normal
akruger34 is offline   Reply With Quote
