03-10-2018, 12:06 PM | #1 |
Dash cluster fuel gauge not working
So when i bought my S13 in 2010 the fuel gauge didnt read. I figured the float came off the arm so now that im finally working on the car almost a decade later I pulled the pump and sender out and the fuel float is infact attached. Heres a pic
Any ideas why its not working? I bought an aftermarket fuel level sender and gauge but id really prefer to fix the stock unit before I go throwing aftermarket parts im there. Any ideas? |
03-29-2018, 01:47 AM | #4 |
Pull the cluster. Find the pin on the cluster that corresponds to the fuel gauge. Test the reading at that pin on the harness side. If you're getting the right reading, you have a bad cluster. If you're getting a wrong reading, you've got a short in your harness somewhere. Trace the cable back to each connector in between the cluster and the sensor, testing at each step. When the readings come out correct, you know where the fault is.
