S14 Ka24DE Cold start- Rough Idle
I have a 1997 s14 with a turboed Ka24de. When the car sits overnight or for a few hours in the cold weather (below 55 degrees) i go to start it up... starts up fine and rpms are at about 1,200rpm and after about 20 seconds-30 seconds the idle will drop. When the idle drops the car will throw the rpms from 800-1100rpm. My wideband is reading extremely lean (reading over 17). Once the car starts to get slightly warm (movement shown on coolant temp gauge) the idle smoothes out (for ex. after driving a mile down the road or reving the engine for a few minutes at about 2000rpm). If the weather is nice out (above 60 or 70) the idle problem does not exist. I have replaced the idle air control valve, dizzy cap and rotor, and plugs. I have monitored the colant temp sensor with consult 2 and the reading was showing about what the air temp was. I have cleaned the z32 MAF with MAF cleaner and have checked all piping and connections to and from the throttle body. i have tried adjusting the set screw on the IACV while the problem is happening and that did not help the issue. Anyone have ANY ideas what this could be?
