Old 10-07-2017, 04:23 PM   #1
Gearhead9992
Gearhead9992 is a well-known jackass
Fuel sending unit
OK so I have a 96 s14 bone stock and my gas gage doesn't work so I pulled out my sending unit and found the black resistor looking thing solder had broke front the other resistor so I soldered it back on plugged it all back in and the gas gauge still sit's below E so I pulled it back out and check ohms and all is in spec
So what can I check next I'm going to try and upload a pic of the sending unit so yall can tell if I soldered it right
Gearhead9992 is offline   Reply With Quote
Old 10-08-2017, 03:01 PM   #2
Gearhead9992
Am I posting wrong or something cause no one seems to want to help
I know people has messed with these things before
So can anyone shine some light on this for me
Old 10-08-2017, 06:04 PM   #3
Agamemnon
Agamemnon's Avatar
Have you checked continuity between the fuel sender and gauge?
Old 10-08-2017, 06:59 PM   #4
Gearhead9992
No I haven't I'll check that tomorrow and I'm assuming I re soldered it to the right place
Old 10-09-2017, 04:44 PM   #5
Gearhead9992
Just checked the wire and holly crap I have 33ohms of resistance
Old 10-10-2017, 09:55 AM   #6
Gearhead9992
So while I'm at work I'm gonna make temporary wire to bypass the original and see if it works
Old 10-11-2017, 07:35 PM   #7
Gearhead9992
Thank you agamemnon I made a bypass wire and as soon as I put the sending unit in the tank and hooked that wire up my low fuel light came on and the gauge started rising so now I will make a permanent wire
Old 10-12-2017, 09:06 AM   #8
Agamemnon
Agamemnon's Avatar
Don't do that. Check your harness connections. If your fuel sender signal is broken, chances are something else is as well.
Old 10-12-2017, 09:30 AM   #9
Gearhead9992
Everything else in the circuit is working and I'm only replacing that one wire
Old 10-12-2017, 09:32 AM   #10
Gearhead9992
And I figured out the only thing that the bypass wire fixed was my low fuel light
