07-30-2017, 11:30 AM | #1 |
Oil pressure question??
What should my SR20det oil pressure gauge be reading at idle at 1000rpm?
At the moment I'm getting a reading of 8psi. Thanks Luis Last edited by 72nismo; 07-30-2017 at 06:10 PM.. |
07-30-2017, 11:43 AM | #2 |
wow, thats extremely low.
I've seen numerous numbers in the range of 35-40 psi
Intangible Visionary: Multimedia Production |
08-01-2017, 12:22 PM | #3 | |
are you running atleast a 40w oil? maybe try a 50 but if that's the case you probably have some moderate bearing wear definitely should not be 35-40 at 1k unless your engine is cold
The Game you lose haha |
08-01-2017, 12:34 PM | #4 | |
I'm running 5-30 Mobil synthetic oil. And at idle its dropped as low as 6 and sometimes lower. When I give it gas it does go up to 30-40. But no higher. I'm starting to think my oil pump might be bad. |
08-01-2017, 03:38 PM | #7 |
I run mobile devlac diesel oil
08-01-2017, 03:44 PM | #8 |
this is good too, as long as its atleast a 40 weight and not more than a 50 weight (which diesel usually is a 40w)
I can gurantee that using a 40w will help at the least if not correct this issue all together
08-02-2017, 08:57 AM | #10 | |
Even if the car had sustained some damage or wear. it happens, itll still run and still provide a long service life if properly watched and maintained from there Why does everyone on zilvia always recomend the most expensinve impractical route
08-03-2017, 12:15 PM | #12 |
08-03-2017, 01:17 PM | #13 |
08-04-2017, 07:18 AM | #14 | |
Myself, some what recent oil change. Mobil 1 10w30. Cold start @ 1500rpm I see 80psi. As it falls down toward 1000rpm I see 60psi. Once fully warm @ 850rpm I see 18psi. I'd start with an oil change... Either 15w40 or 15w50. If oil pressure is still low I'd get a new oil pump. Worst case, if you do need a rebuild, you will want a new oil pump anyway.
| 92 S13 Hatch | 92 S13 Coupe | 95 S14.5 | |
08-04-2017, 04:10 PM | #15 | |
08-04-2017, 06:35 PM | #16 | |
Sent from my iPhone using Tapatalk Last edited by 72nismo; 08-05-2017 at 09:07 AM.. |
08-05-2017, 12:52 PM | #18 |
yes run the diesel oil, a lot of people run it. I even run it in my brand new rebuilt ka24 but I use a 10w30 rotella cause ka's take 30-40 weight, but SR's take 40-50 and the weight is very important for oil pressure
08-05-2017, 01:30 PM | #19 | |
Thanks Bam! Got it https://imgur.com/a/XvIwm?s=sms Last edited by 72nismo; 08-05-2017 at 07:51 PM.. |
08-05-2017, 09:06 PM | #21 |
FSM call for about 11 psi at 800RPM, now granted my engine isn't stock I figured I'd throw my 2 cents in. I run SAE 60 Dominator by Amsoil and see 12-15 PSI at idle and that's usually in 100+ degree weather.
08-06-2017, 09:35 AM | #23 |
I run 0w20 in my rebuilt rb. I see 6 bar at warm idle with 10w30 so I had to switch. About 2 bar at idle with 0w20 However this isn't an Sr so my info probably is useless.
08-06-2017, 02:32 PM | #24 |
Changed oil to 15-40
So I did the oil change. Warmed it up and my pressure went up to like 30s then when warmed up it ended at 10psi. Took it for a test run and got home and at 900 rpm and oil pressure was at 7psi. So gut feeling something wrong.
https://imgur.com/a/LmgNt?s=sms |
08-07-2017, 11:41 AM | #25 | |
and 2 bar at idle would be like 30 psi and 6 bar would be like 90psi one of which are very unlikely OP are you rod knocking at idle? You have some oil pressure so thats atleast a good sign how are we testing oil pressure? like what setup are you using youre only a couple psi off where you should be id say give the 50w a shot your bearing might just be worn a bit
08-07-2017, 11:46 AM | #26 |
That's too low. Engine building rule of thumb is 10PSI per 1000RPM. Drain the pan and look for any metallic material. Also pull the oil pan and start checking the rods to see if any are knocking that you can't hear yet. If you still don't find anything pull the engine and then the main caps and check the main bearings. If you're lucky you haven't spun a bearing and you just need to replace the oil pump.
08-07-2017, 06:34 PM | #27 | |
https://imgur.com/a/OFL8r?s=sms |
08-07-2017, 06:39 PM | #28 |
08-07-2017, 06:39 PM | #29 |
Yes. That's bearing material.
08-07-2017, 06:41 PM | #30 |
