06-20-2012, 01:16 PM | #1 |
Car starts sometimes and then wont start again
**UPDATE** PLEASE SKIP TO BOTTOM
This is for my brother's 96 s14 ka24de Starts up usually after sitting an hour or so or completely cold, but sometimes you have to crank it a little or let off and crank it again. If the car was JUST running and you turn it off and try to start it, it wont start. It turns over fine it isn't a power issue or anything. Sounds like a coolant temp sensor issue right? Well it was replaced a few years ago because it was bad. I tested it out with a multimeter and it was getting proper voltage and ohms based on the temperature stated in the FSM. Are there any other sensors or things that could cause this? When they car is running it runs perfectly fine too by the way. Thanks for readiing
☆ Panda Pirates ☆ Last edited by Ichiban4; 07-12-2012 at 01:17 PM.. |
06-20-2012, 01:25 PM | #2 |
Run the car until it gets to normal operating temp. Turn car off, and check the resistance (ohms) on the coolant temp sensor.
If that checks out fine you'll want to start the basic process of checking for fuel, spark and compression.
06-23-2012, 03:06 PM | #4 |
UPDATE
Car will not start at all today. Pulled the fuel rail and found out the injectors are not spraying any fuel. I pulled the line from the fuel filter and turn on the pump and got a good flow so the pump is working fine. What could cause them not to spray then? Seems like they went from working sometimes to not at all, and its not the injector itself because all 4 don't spray. Some type of electrical sensor or something?
☆ Panda Pirates ☆ |
06-23-2012, 06:01 PM | #7 |
Just spark was fine yesterday when the car ran, today it won't start at all so just pulled the plugs again and cranked it and no spark whatsoever.
☆ Panda Pirates ☆ |
06-25-2012, 11:45 AM | #8 |
Might help or not but worth a try... Beside the s13 I have a eclipse which was the doing the exact same thing I mean to the T. Well to not drag this it turned out to be the cam sensor. That was not reading after it reach a certain temp but would work when cold. Hope it helps.
06-25-2012, 12:16 PM | #10 | |
That makes no sense.... What does a starter have to do with your engine not having spark or fuel?
06-25-2012, 12:21 PM | #11 |
Trader Rating: (25)
Feedback Score: 25 reviews
I'm saying that was MY problem maybe it would help, i turn key sometimes it would start sometimes it wouldn't i replaced my starter and it fixed MY problem.
06-25-2012, 12:31 PM | #12 | |
No it wont help cuz if you read you would see that he says So its clearly a Fuel/Ign timing component
06-25-2012, 01:08 PM | #13 |
I hope your brother didn't pour NOS in his gas tank...
However, try changing the fuel filter and check the resistance for each injector. You should also check the spark plug wires/cap/rotor. If there's crud on the cap and rotor, you can try and sand the connectors.
06-25-2012, 04:05 PM | #14 |
Injectors work on ground signal from the ECU....
Check all your grounds, check voltage to injector (I am guessing its 0), check fuses.... Is your harness good? Swap ECU's.
Turn and Burn! |
07-12-2012, 12:32 PM | #16 |
UPDATE
Car still isn't running -_- We swapped the distributor for one we bought on here from a guy who said it was working fine and it still wont start. I pulled a plug and cranked the car touching the threaded part of the plug to a grounded bolt on the chassis and no spark whatsoever. ALL wires going to the dizzy are getting proper voltage and resistance so I don't think there is a short anywhere. Pretty sure we are getting fuel because the plugs smell of gas after trying to start it and after disconnecting the hose after the fuel filter there was a steady flow of gas when turning the car on. We are getting power to the injectors as well. Would a bad ecu still allow for all the components to get power? I pulled it and check all the connections everything seems fine and I had good continuity between my components and ecu, I checked everything according to the FSM. Any other thoughts please people that could cause no spark? No NOS in the gas tank lol.. ****qwerth**** Car is turning over when we crank it, did yours still turn over? The starter does seam like its making a winding type noise, doesn't sound normal. I always thought when a starter was bad it just clicked though?
☆ Panda Pirates ☆ |
07-12-2012, 03:20 PM | #17 |
Still sounds like a grounding issue to me if you get no spark during crank....
Make sure you have all the grounds connected properly. There should be 5 grounds? Maybe someone with more KA experience can point out where the grounds are.....
Turn and Burn! |
07-12-2012, 05:11 PM | #18 | |
07-12-2012, 06:49 PM | #19 |
I'll recheck the grounds when I get home. No one to borrow an ecu from but did open it and it all looked fine. Thanks for the help so far.
☆ Panda Pirates ☆ |
07-12-2012, 07:14 PM | #20 |
not sure if ka's have this but if the dizzy has an ignition module and thats bad you wont get spark. from what i'm gathering you are getting power to where you need it to power the dizzy so what ever is controling that power is not working.
07-13-2012, 12:55 AM | #22 |
This may sound silly, but jump start the car with another car while it's running. your battery may not have enough juice in it to actually start the car. This happens when the battery is old and it usually would have a bad cell in it.
and also, when you said your injectors didn't spray any fuel when you checked them..how did you check them? just off the intake manifold and cranked the car over? because they aren't suposed to spray or leak fuel unless the engine is actually started or cranking over. and finally, does the car have gas? MAF connected?
07-13-2012, 01:31 AM | #23 |
Yea ignitor thing is built into the dizzy on obd2 and we changed that with no luck
mad-ass we cant get the car to start, we have swapped batteries and jumped the current one with no results so it's not a battery issue. MAF is connected. Didn't look at the fuel gauge but I am pretty sure it has gas. Look into it more next week I'm gona be out of town this weekend thanks guys <3
☆ Panda Pirates ☆ |
07-13-2012, 11:05 AM | #24 |
I car use to be like that to. The third injector didn't spray so I got a new one. It got worst so I put the stock one back on. But mines was the distrubitor mul-joe. Forgot how to spell it. It use to crank and work to not working. If you advance tune a lot that might be the case. But check it with jumper cable. Use the negative to bite the spark plug and the other side to the negative battery. Then crank it and have someone look for spark.
07-13-2012, 11:27 AM | #25 |
Brian I think its time for an SR upgrade lol
have you replaced the plug since they stopped sparking? Possibly the plugs are fould out from running rich?
07-16-2012, 12:00 PM | #26 |
Not my car Pat lol you know I have SR
Haven't replaced the plugs simply bc I really do't see all 4 going bad at one time, especially seemings we drove home fine and parked and then the next day the car wouldn't start and hasn't since then, been almost a month now :/ I am about to look up the main ground on the car and check and also I will re-check the ecu for burns again. Anyone wouldn't happen to have a extremely cheap extra working one they would be interestef in shipping to help us out?
☆ Panda Pirates ☆ |
07-16-2012, 05:49 PM | #27 | |
07-23-2012, 01:09 PM | #28 |
We just changed the ecu for a known working one and it still doesn't start, completely out of ideas now. Probably gona have to tow it to a shop or something.
Once changing the ecu we checked the codes with a little reader we have and we got a new code: *Evaporative Emission System Vent Control Circuit* Would that be causing all this? (EDIT apparently running a 97ecu on a 96 will make it throw the p0446 code) ... So i guess maybe that isn't an issue since we didn't get that code with his original ECU in. Here is a video, is the sound in the beginning/end normal? KA wont start clip - YouTube
☆ Panda Pirates ☆ |
07-25-2012, 11:47 PM | #29 |
Intel 5811 might be right...check the cam sensor on the transmission housing.. hidden against the firewall. If you're not getting signal from that, then you won't get any spark.
Just out of curiosity, I take it the relays for the fuel pump & ECU are in good working condition?? Another suggestion is to check the ground wires located on the driver side of the motor towards the firewall above the oxygen sensor. If those ground wires short out or go bad, your S14 won't start. Nissan uses this ground spot for several sensors, so you'll have three or for wires grounded at this spot. I forget what sensors use this as the ground spot but I think the cam timing sensor is one of them. I had this problem years ago with my 95. After three weeks with a dead S14 and two ASE certified mechanics not being able to figure it what the problem was, I finally broke down & took it to the dealership. The first thing the dealership tried telling me was that my ECU was bad. After proving them wrong with another ECU from a working S14, I was finally able to convince the dealership that I had a ground wire problem. I just couldn't figure out where the short was. It took the dealership two days to figure out that ground wires above the oxygen sensors had a short in it. Anyhow, hope this helps... ID
Weekend Mechanic for my Not-So-Mechanically-Inclined buddies.... |
07-26-2012, 07:46 AM | #30 | ||
Although I would agree to check and clean all the grounds though for shits and giggles.
