Old 08-19-2021, 10:42 AM   #6781
corkscrew
corkscrew's Avatar
corkscrew is an unknown quantity at this point
Going to check that out tonight along with changing the plugs and re gapping them. The ones I have now are fouled and I never changed the gap out of the box apparently -_-
corkscrew is offline   Reply With Quote
Old 08-19-2021, 05:57 PM   #6782
corkscrew
corkscrew's Avatar
Won?t rev over 4500rpm even with very light throttle input. Leaning towards maf. Going to try to find one to test out
Old 08-19-2021, 06:00 PM   #6783
corkscrew
corkscrew's Avatar
Won?t go over 4500 even with very light throttle input. Negligible little things found under boost leak test and tightened everything up. Leaning towards maf as well, trying to find one to try out
Old 10-05-2021, 07:16 PM   #6784
Bikemaster00
Bikemaster00 is an unknown quantity at this point
Trans tunnel with cdpro
Any fellas that put a 2jzgte with the Serialnine (Serial9) CDPRO bellhousing in the 240sx S13. Do you have to beat the trans tunnel for it to fit or does it clear the tunnel with no issue? I know the Stock one needs finesse but not sure about the CDPRO one because it is smaller in size. Having a hard time finding information on fitment. I have the Excessive mounts.
Bikemaster00 is offline   Reply With Quote
Old 10-06-2021, 12:35 PM   #6785
crash n' burn
crash n' burn's Avatar
crash n' burn has a spectacular aura aboutcrash n' burn has a spectacular aura aboutcrash n' burn has a spectacular aura aboutcrash n' burn has a spectacular aura aboutcrash n' burn has a spectacular aura aboutcrash n' burn has a spectacular aura about
It looks identical to the Fisch housing, I'd go with whatever information they have on theirs. Its a C-hair shorter than a A340 housing/adapter plate combo. minor firewall clearance needed, you're going to beat the shit out of your trans tunnel the same amount regardless due to the actual transmission size.
Key'd Performance
@jz_2tone
crash n' burn is offline   Reply With Quote
Old 10-25-2021, 08:50 AM   #6786
Supreme_Origin
Supreme_Origin is an unknown quantity at this point
Anyone with a 1J and still have A/C? S13 if possible. Would love to see photos and see how its hooked up.
Supreme_Origin is offline   Reply With Quote
Old 05-10-2022, 11:26 PM   #6787
Chief 1402
Chief 1402 is an unknown quantity at this point
Anyone know the part numbers for the S14 heater hoses to 2jz? From the firewall to the engine. I saw the part numbers a long time ago, wanna say they were Dayco hoses but not sure. Anyone know this?
Chief 1402 is offline   Reply With Quote
Old 01-31-2023, 11:47 AM   #6788
Whitey13
Whitey13 will become famous soon enoughWhitey13 will become famous soon enoughWhitey13 will become famous soon enoughWhitey13 will become famous soon enough
How is the vibration on 1JZ/2JZ setups running solid engine mounts?
It appears that all of the mounts, outside of ISR, are solid mounts.
Thanks
Whitey13 is offline   Reply With Quote
Old 01-31-2023, 02:51 PM   #6789
jr_ss
Thanks
Couldn?t you modify mounts to utilize a different option? I find it hard to believe only ISR has done this?
Goleby?s, Xcessive, etc are a few that utilize rubber/urethane.
With that said, in-line 6?s are naturally balanced, so even with solids, it would probably be smoother than a KA or SR.
Old 02-01-2023, 01:07 AM   #6790
wezurii
wezurii is an unknown quantity at this point
Also correct me if I am wrong.
But if you make the bracket etc can't u fit rb25/26 engine mounts or orginal 1/2jz mounts ?
wezurii is offline   Reply With Quote
Old 02-03-2023, 09:56 AM   #6791
Whitey13
Based on what you said, I went back and looked at the Xcessive again. It looks like they recommend using their BMW mounts if you're looking for a urethane option. I looked at Golebys quickly but didn't see anything.
I'm not looking to "modify" anything. Just want it right, right out of the box.
Old 09-19-2023, 08:39 AM   #6792
jonny mac
jonny mac is an unknown quantity at this point
hey guys, does anyone have a pic of their dakota 8 rpm signal converter setup for a vvti 1j into s14? i'm using the IGF wire as a source from the igniter to input to the dakota
just cant remember what position i need the green switches in and also which output to use on the actual unit.
jonny mac is offline   Reply With Quote
Old 01-29-2024, 07:35 PM   #6793
ph1tnessjunk1e
ph1tnessjunk1e is an unknown quantity at this point
Originally Posted by AS240 View Post
I went to a junkyard and got a PS pump off a non vvti GS300 and swapped the parts needed to delete the vacuum valve over to my vvti PS pump.
I'm also using this power steering line which I HIGHLY RECOMMEND. Can you tell which review is mine? lol
http://www.rawbrokerage.com/raw-brok...-nissan-240sx/
My power steering hasn't worked since I swapped in the motor and it randomly leaked all over my garage floor the other day - trying to diagnose what's going on.
Are the vacuum valve and the variable steering valve the same? What does the valve do?
ph1tnessjunk1e is offline   Reply With Quote
