11-11-2011, 07:18 PM | #4231 | |
11-12-2011, 04:32 PM | #4232 |
^^^shut up asshole.
I have no pics but I had to stick some aluminum today. Didnt help it was on top of a sulfur pit. All the reading I did said the final product looks like shit. It didnt turn out too bad. |
11-12-2011, 06:11 PM | #4233 |
Ive never sticked aluminum. What is it like to weld? I've mig'd, tig'd, and gas welded it. Ne'er stick.
Glad to see some mods took some action. |
11-12-2011, 06:32 PM | #4234 |
You cant really see the puddle, and it eats the rod up fast.
Had the machine set for 3/32 7018 and left it there for a starting point. Did pretty well with the 1/4 stuff I was welding. First hurdle was I would arc it and pull back and it would go out. I was in a high lift and didnt have a guy on the ground to mess with the machine. I kept screwing with it and finally figured out when you strike the arc you almost had to push the rod right into the weld and stat moving. I though it was pretty cool, id like to try it in a shop or something with a nice clean piece and see what happens. |
11-12-2011, 07:07 PM | #4239 |
It has plenty of of purpose... Ever try building a crane with 200ft of whip? Try getting wire to feed through that. Not happening.
I love stick welding to extent. Mostly just when it's easy. Not so much when doing the back side of a pipe with 3" of clearance between the pipe and wall... Using a mirror to watch what you're doing... That's when I hate stick welding... Lol |
11-12-2011, 09:01 PM | #4241 |
Infiniti G20 3" cold air intake.
www.facebook.com/HellaFab |
11-13-2011, 08:26 AM | #4243 |
the guy i built it for ordered the couplers and didnt get the right one for the maf-pipe.
so i used a random reducer coupler to mock up for him so i could actually build it on the day he wanted it done.
11-13-2011, 02:58 PM | #4245 |
Trader Rating: (25)
Feedback Score: 25 reviews
it would technically be a warm air. "short ram" would be more of what vettes and some camaros use
ill have pictures of the manifold ive been working on tomorrow |
11-17-2011, 03:48 AM | #4250 |
Here are a couple items i fab'd up for my z31.
Here is a set of solid aluminum motor mounts that I made for my Z. This is a custom shift that I made. Even has hide away storage lol. And this is a set of motor mount that I made for a guy on a different forum. |
11-18-2011, 09:34 PM | #4253 |
^^^^^^^^ Thanks.
The stock replacement hasn't been listed yet, were going to do a Black Friday One-Day Sale on that item at a blow-out price. I will put the flyer up when it's ready, as of now it's $595 shipped in the lower 48 states. |
11-20-2011, 02:42 PM | #4254 |
Finally set my tubing bender up...after buying it in March. Nothing fancy, but here's my first bend.
What are your all's thoughts on bendtech pro? Thinking of picking it up after Thanksgiving.
My Website | Unfriendly Garage | Endurance Motorsports | FitMyWheels - Fitment Calculator |
11-20-2011, 07:34 PM | #4257 |
Trader Rating: (22)
Feedback Score: 22 reviews
QUESTION;
What method(s) would you men use when filling the 3rd brake line hole on an S14? It has that ovular shape, FYI. Should I make my patch piece in that same shape and and butt weld it into place? Would it suck if I lapped welded it? I assume I should just run tack welds around the piece "jumping around" to keep heat down... I'm using a MIG (75/25 mix gas) and my material is 22g. Sorry, I'm green at welding.
11-21-2011, 10:30 AM | #4260 | |
89 2tone coupe 2jzgte swap in progress |
