Old 03-31-2016, 05:52 AM   #1
AndyS13
AndyS13 is an unknown quantity at this point
My 180sx from scotland!
Hi guys I am a long time lurker on here all the way from scotland! I just thought id post up a feature I got done by Monky London on my 180sx hope you like it
https://www.youtube.com/watch?v=mFrn9wqvs9A
Spec list for those that are interested:
Engine
Motec M4 Ecu
HKS 2.1L Stroker kit
HKS 256 Camshafts
HKS adjustable cam pulleys
HKS Metal Head Gasket
HKS GT2835 Turbo
HKS exhaust manifold
HKS 650cc injectors
HKS Oil Cooler and Filter Relocation Kit with custom bracket
HKS 280lph Fuel Pump
HKS Suction Pipe Kit with apexi power intake
HKS Intercooler and Piping Kit
HKS oil filter
Splitfire direct ignition coil packs and amplifier
Greddy high capacity baffled sump with magnetic sump plug
s15 oil pick up
HKS decat
Works 9 otsuka wind eardrum breaker exhaust
Kazama Auto Sump Guard
Kazama Auto Oil Catch Tank
Yashio factory triple core copper Radiator
Yashio factory water pump pulley
Gp sports megatech cooling fan
Greddy radiator cap
Motec map sensor
Z32 AFM
Cusco heavy duty engine mounts
Suspension
Kazama Auto Front Pilo Tension Rods
Uras offset tension rod spacers
Kazama Auto Heavy Duty Tie Rod
Kazama Auto Super Tie Rod Ends
Kazama Auto Tension Support Bar
Kazama Auto Rear Upper Arms
Kazama Auto Toe Control Arm
Kazama Auto Rigid subframe Collars
Driftworks cs2 coilovers
GP Sports adjustable Wheel Spacers front 15mm and 15mm rear
5 Stud Hub conversion
Cusco front strut brace
Cusco rear strut brace
c's garage 555 knuckles
c's garage 555 lower arms
c's garage 555 extended track rods
yanack solid steering rack collars
Auto staff duralumin steering column bush
uras pokochina rear subframe brace
uras nomunohakobune chassis rail extension
Drivetrain
act heavy duty 6-puck clutch
act prolite flywheel
arp flywheel bolts
nismo 2 way LSD
acpt Carbon Prop Shaft
nismo clutch pivot ball
nismo reinforced clutch pedal assembly
uras super solid shifter
kazama auto brass shifter bush
hks shift return spring kit
uras imo youkan gearbox bush
Brakes
Front
r34 gtr Brembo calipers
Project Mu SCR-Pro two piece discs
Endless CC-Rg pads
Sfida braided brake lines
Rear
z32 rear calipers
Project Mu SCR Pure Plus 6 discs
Endless CC-Rg pads
Sfida braided Brake Lines
Exterior
Respray in ebisu black pearl metallic
Kazama auto tryval bodykit
Uras clear front indcators
Oem carbon rear light panel
G corp carbon b pillar covers
G Corp Front Fender +30mm
G Corp Rear Fender +50mm
despoilerd and boot smoothed
ganador mirrors
Kouki Rear lights
Roof washer jet removed
Aerial hole removed in rear arch
Upper door line removed
Front and rear gp sports g sonic tow hooks, re sprayed ebisu black pearl metallic
Wheels
Rays te37s
Front – 17×9 Offset +15
Rear – 18×10.5 Offset +15
Interior
Vertex 10 star wheel 330mm
Trust Profec B spec 2 Boost Controller
Kazama auto roll cage
Bride Zeta III Drivers Seat
Bride Xax II Passenger Seat
Bride super low rails
Bride gear gaiter
Defi BF – Water Temp, Oil Temp, Oil Press, Boost Meters
Defi Link Controller
kazama auto drift button
kazama auto gear knob
Pivot sleepy eye controller
G corp led ignition barrel light
G corp chequered floor mats
AndyS13 is offline   Reply With Quote
Old 07-07-2016, 03:23 PM   #2
Eoken
Eoken is an unknown quantity at this point
Saw the video!! I love the car man. I checked out Kazama Auto's website and I do not see the roll cage listed. Do you know where I can find one? looks very similar to a Cusco 7 point roll cage with an extra bar across the back to make it an X.
Eoken is offline   Reply With Quote
