Old 05-30-2018, 10:32 AM   #1
luuzilla12
luuzilla12 is an unknown quantity at this point
s14 Help with my 2jz swap
would anybody like to give me some tips and tricks, on going about doing my 2jz cd009 swap into my s14 that im eventually going to do, i like to gather everything all together at once, planning on keeping it stock ecu and doing it how "motionautotv" did his giveaway car. keeping this car strictly street only. and would really like help on how i would go about getting the speedo to work
luuzilla12 is offline   Reply With Quote
Old 05-30-2018, 12:17 PM   #2
Avayo
Avayo is an unknown quantity at this point
C’mon man. Put in a little bit of effort and search the topic. It’s only been covered a zillion times.
Avayo is offline   Reply With Quote
Old 05-30-2018, 12:25 PM   #3
di-devol
di-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enough
Alright, get your bib ready.
2jz swap thread, hella info
http://zilvia.net/f/showthread.php?t...d.php?t=384161
CD009 trans swap thread
http://zilvia.net/f/showthread.php?t=628596&page=7
jz swap is straightforward, cd009 depending on what adapter you go with is straightforward as well.
Step 1: Beat the shit outta your trans tunnel
Step 2: Beat the fuck outta your trans tunnel some more
Step 3: Finally realize that you need to beat the trans tunnel again.
Step 4: Admire how the transmission hangs really low.
di-devol is offline   Reply With Quote
Old 05-30-2018, 08:47 PM   #4
doyle4281
doyle4281's Avatar
doyle4281 is on a distinguished road
Contact serial nine for the CD009 conversion. Impressed with their products. Wiring Specialties for the harness, used them for 2 cars now
doyle4281 is offline   Reply With Quote
Old 05-31-2018, 12:26 AM   #5
Kingtal0n
Kingtal0n's Avatar
I don't understand how I fit a 4l80e under the S14 and its as high as every other trans. 4l80e is 250lbs monster.
Why does the cd009 hang so low when the 4l80e must be larger, heavier, does not?
Old 05-31-2018, 12:27 AM   #6
di-devol
I think it's just the way it's built. The output shaft is rather high up, making a good amount of girth to hang down haha
Old 05-31-2018, 07:07 AM   #7
Black240Ct
Black240Ct will become famous soon enoughBlack240Ct will become famous soon enoughBlack240Ct will become famous soon enough
Send a message via AIM to Black240Ct
I drilled out the welds on the transmission brace support and re welded it on further back and used a stock cross member for the transmission. freed up some space and my cd009 sits even with the frame rails on a maverick motorsports adapter.
also hammered out about and inch extra room around the bellhousing of the firewall.
Black240Ct is offline   Reply With Quote
Old 05-31-2018, 08:58 AM   #8
derass
looking forward to this eventual swap! all the instructions will be right here for you when you're ready!
