Old 08-16-2018, 07:03 PM   #1
dirtdiggler666
dirtdiggler666's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
2JZGTE VVTI low idle when warm
When cold it starts right up and idles fine but when it gets past 170/180 it wants to idle around 300 and die.
Also what should it idle at cold?
bone stock 2j
oem ecu
stock injectors
small single
runs amazing unless I come to a stop lol
Any help would be great I wanna drive this damn thing
dirtdiggler666 is offline   Reply With Quote
Old 08-19-2018, 07:41 PM   #2
Kingtal0n
Kingtal0n's Avatar
idle is controlled by airflow mostly
let more air into the engine somehow
you could simply open a vacuum leak
or drill a hole in the throttle body
or find out why the IACV/DBW isn't doing this for you
Old 08-26-2018, 01:48 PM   #3
dirtdiggler666
Trader Rating: (26)
Could the TPS being out of adjustment cause this?
Old 10-05-2018, 12:11 PM   #4
Nemui
Nemui is an unknown quantity at this point
Try adjusting throttle cable to have less slack. I had the same issue and that fixed my problem. I thought it was a boost leak at first but ended up being that my idle was set so low it would drop rpm and die when coming to a stop.
Nemui is offline   Reply With Quote
