11-29-2017, 11:15 AM | #1 |
Swap wiring help
Hey guys,
So lets start with its a 1995 S14, automatic. I removed the KA24DE and the auto transmissions, with that being said the upper and lower harnesses were removed for the gentlemen who purchased it. I have since done a few things.. 1. Converted to 5-speed, removed AT ecm. 2. Swapped in new engine using its own ECM and harness. I was able to wire up some of the needed connections from the F3 connector inside the car. However I am having some issues still. 1. I have no lights, horn, turn etc...Now I know that the lower harness on the S14 connects to the fuse box inside of the engine compartment, however I no longer have the harness. I cant find anywhere on how/pins to find in order to wire this up, and would I wire directly from fuse box to F3 connection? 2. I have read everywhere about the fuel pump relay setup and that its ground triggered, so I have seen people tell me to ground the black/pink wire for fuel pump relay, and I have also read somewhere they recommend grounding pin 1 black/white wire on the fuel pump relay and then my black/yellow should be my hot wire. Can someone please confirm/assists on my struggles, thanks everyone. |
11-29-2017, 12:51 PM | #2 |
Sorry but you didn't mention if you had used this or not. But have you looked at this page?
5.3 V8 Swap w/ Nitrous |
11-29-2017, 02:05 PM | #3 | |
12-12-2017, 08:32 AM | #5 |
Gonna bump my own thread again, my car is a 95 with the OBD2 connector under the dash from factory. On my F3 plug I have two wires that say CONSULT, a green/white wire and a green wire. Does anyone know of which is the signal wire in order to read the ecm?
