07-20-2015, 04:51 PM | #1 |
Clicking / Ticking Noise.. Possibly arching from plugs?
Hey guys,
I hear this weird ticking noise when my car idles, it clicks quicker when rpms increase but only so a certain point... like 2500. I googled a crap load and thought maybe it was arching from my plugs. I took all the plugs out and cleaned them, checked them for proper gapping and secured everything back down. It still seems to click. I have even messed with my TPS thinking it was something to do with that. I am running NGK BRK7E gapped at .028 Is this normal? Any suggestions?
07-20-2015, 06:48 PM | #6 | |
Is it possible that it could be coming from one of the cylinders. Would it be dumb to try and disconnect 1 coil pack at a time to see if it stop the noise or would that cause more problems? I can try and upload a video when I get a chance Thanks. Sent from my SM-G900W8 using Tapatalk
07-20-2015, 06:54 PM | #7 |
No no no no I need the pattern spelled out. If you post a video then I would have to inerpret the numbers clicking instead of you, and only the true owner can recognize the pattern.
You can try to disconnect the coil packs but you can never disconnect the coilpack in a consecutive direction: example of what I mean. Disconnect cool pack, reconnect coilpack, disconnect coilpack to the right of first coilpack I disconnected, now I can not disconnect a coil pack to the right of the second coilpack because that ruins the pattern so you have to disconnect to the left. |
07-20-2015, 07:19 PM | #10 | |
07-20-2015, 07:21 PM | #11 | |
07-20-2015, 07:34 PM | #12 |
On a different story excluding spark plugs or coils... A possible clicking/ticking noise could be a lifter tick. But this early on i wouldn't specifically pinpoint that as your problem.
07-20-2015, 07:35 PM | #13 | |
07-20-2015, 07:45 PM | #15 |
What motor is this again? S14 VTC? It's your VTC cam gear. You need to replace it.
07-20-2015, 07:50 PM | #16 | |
EDIT: I just watch some youtube videos, and the noise I am getting is no where near as loud as the ones in these videos. Its not a rattle. It literally sounds like a small arching noise. Does not sound like the VCT rattle: https://www.youtube.com/watch?v=qHfdF0aLUrw https://www.youtube.com/watch?v=95qdoK44zQg
07-20-2015, 08:52 PM | #18 |
Can you take audio of the ticking? It may just be your injectors...
07-21-2015, 10:53 AM | #21 | |
It's hard to say what exactly it is. I would say it's more of a faint tapping sound than a tick/click. If you want something to do, check your valve train. Make sure your lifters are bled and the shims are within spec. A bearing on the front of the motor might be going bad(I.e. Water pump, tensioner). There are a lot of things this could be. Replace your plugs, if they have a brown trace mark on the ceramic, they are bad. I honestly don't think it's anything to cause alarm or worry. These motors seem to have a lot of random noises.
07-21-2015, 11:04 AM | #22 | |
07-21-2015, 11:11 AM | #23 |
actually, it was helpful as I stated that I did not believe it to be in the engine or an injector. process of elimination. i dont give a fuck what my post count is, you on the other hand are the "post whore" fucking troll
07-21-2015, 12:01 PM | #24 |
I'd get a stethoscope and at least look into it. Sometimes you can catch a little problem before it develops into a big one with a tool like that.
07-21-2015, 12:02 PM | #25 |
Thats a good point. I will try and pick one up. thanks
07-21-2015, 12:47 PM | #26 |
Wow, another educated response, you're on a roll pal.
07-21-2015, 03:53 PM | #28 |
Yeah, yeah...
Try unplugging your VTC solenoid, it's the red plug right next to the throttle body coming out of the head.
07-21-2015, 04:25 PM | #29 | |
Trader Rating: (37)
Feedback Score: 37 reviews
Lol. He's a "post whore" who joined at the end of 2005. Lol, such a post whore, fucking troll! Sorry, I'm just trolling.
I like my bikes how I like my b¡tches...naked! 2014 Triumph Street Triple |
07-21-2015, 04:27 PM | #30 | |
