Old 09-19-2018, 11:21 AM   #1
fishstix
fishstix is an unknown quantity at this point
Auto to 5MT, clutch line correct?
Got this car from my brother with "all the parts'' for the swap. I've had to source a few things most of it was there. After mounting the trans, peddle, master and slave cylinder, I find that the ends of the new clutch line don't seem correct. I bought a new line off FRSport and it's the same. The bent 90* end has a free spinning male connector but the other end is fixed male connection. You either have to screw it in rotating the whole line, or its made to connect with a rotating female connector). The end with the 90* bottoms out in the SC and same with MC before compressing the flared end. What am I missing here? some obvious over site?
fishstix is offline   Reply With Quote
Old 09-20-2018, 07:21 AM   #2
Datsun freak
Datsun freak is an unknown quantity at this point
Your missing the clutch Slave cylinder soft line
File Type: jpeg 0D8BF36A-BE8E-4B54-BA70-9C57C89B6189.jpeg (170.4 KB, 8 views)
Datsun freak is offline   Reply With Quote
Old 09-20-2018, 09:27 AM   #3
5280VertDET
5280VertDET's Avatar
5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light
I had the same puzzlement when I bought my Agency power clutch line, I have the 90* into the master.
I first connected it the slave and let the line twist and spin as I tighten that end, then ran it up and used the 90*/swivel connection to tighten on the master cylinder. Adjusted pedal, Bled it, adjusted it, bled it and adjusted. No issues.
I agree though, it seems odd there are no 90s on both ends, even a swivel on both ends. I looked at a couple other brands online and they all seem to be this way.
You don't need the little soft line, unless you are running the dampener, which is a common deletion in most S-Chassis, factory 5 speed or a swapped chassis.
S13 Vert | SR | PE1420 | 5-Speed | 15x9.5 - 0 |
5280VertDET is offline   Reply With Quote
Old 09-20-2018, 05:25 PM   #4
fishstix
Right on I'll give that a try.
