Old 09-19-2018, 09:50 PM   #1
senHR
senHR is an unknown quantity at this point
Fs: 2008 350z
Moving to Philly and wont be bringing my car there, so up for sale is my san marino blue 2008 350Z base. I bought the car December 2010 with 20k miles on it. Right now the car has 69k miles. The interior is in good condition. The center cubby and the vent on the drivers side door have some scratches and there is light wear on the steering wheel. The interior on the 350Z’s is pretty brittle and you can scratch it by lightly touching it with your nails. The window motors are starting to go. Overall the body and paint are also in good condition. The car was a bit lower a couple years ago so the front bumper, and mud guards have scraped. Bought the coils, control arms, camber and toe arms around 30k miles and everything still feels good and stiff. OEM wheels have some scratches here and there, they worked well as dailies, and are currently on 20mm and 25mm spacers. The weather has been garbage for a while now in NC so the pics below are of a very dirty car, which will be properly detailed on Friday.
ASKING 10,500
CONTACT #919-306-8926
Feel free to text
**NOTE:
1) There is a squeak coming from the rear that comes and goes. Not consistent. Not sure where it is coming from
2) Front coilover dustboots are torn
3) Under shroud is bent a bit. Hit a rock and the under shroud took the hit
4) That rock also took out half of a plastic cover part #75898M
Suspension:
-Fortune Auto Coilovers w/ swift springs (9k / 12k spring rates)
-Cusco upper control arms in the front
-Battle version camber and toe arms in rear
-GTSpec rear tie brace
-Powergrid swaybar endlinks
-SPL compression rod bushing
-Whiteline front LCA inner bushing
-SPL rear shock bushing
-SPL front translink bushing
-SPL front shock bushing
Interior:
-Forged Performance shift knob
-New LH/RH window switch finishers (originals very scratched up)
Misc:
-Zspeed undershroud
-Z1 hatch struts
-K&N drop in filters
Brakes:
-Z1 brake upgrade package (SS lines, slotted rotors, centric posi quiet pads)
Wheels:
Posting up a thread for them sometime soon, but info below
-Work Equips 05 18x11 -4 (R-disk) // 18x12 -+0 (A-disk) 5x114.3
Extras:
-OEM shift knob
-OEM upper control arms
-OEM rear camber arms
-Fender roller
-Motive Power bleeder
-Fender Roller
Below are pics. Included pics of whatever scratches or damages I mentioned above.
Link to album if you want higher res pics: https://imgur.com/a/szIJt25
Right behind the under shroud towards the center of the car is the plastic piece that is missing half of it. You can see it better in higher res pic
senHR is offline   Reply With Quote
Old 09-20-2018, 03:28 PM   #2
dahveed
dahveed's Avatar
dahveed is an unknown quantity at this point
Is this a base model? I likey
Wat
dahveed is offline   Reply With Quote
Old 09-22-2018, 10:53 AM   #3
senHR
Yup it’s a base!
Old 09-24-2018, 02:48 PM   #4
senHR
Monday bump
Old 10-01-2018, 12:38 PM   #5
senHR
spooky bump. Price updated
Old 10-06-2018, 12:44 PM   #6
senHR
take this to the top!
