11-11-2013, 10:28 AM | #15361 |
Alright, I've been looking into getting a longer final drive for my S14 (R200V) and have decided to go with a 3.692 final drive. My options seem to be ring/pinions from either an S15 (M/T), JDM S14 (M/T), and Q45 (97-01). Would I be able to use all of my current diff (6 bolt axles, VLSD, S14 pumpkin, etc.) with the R&P from any of these other R200's (I'm guessing I need different axles for the S15 and Q45, this question is mostly about the JDM S14 dif)? If not, what specifically would I need from the other diffs? Just looking for the simplest solution considering I already have an S14 R200V.
Thanks in advance!
Daily: '99 Pontiac Trans Am. Projects: '96 S14, '87 Merkur XR4Ti |
11-11-2013, 03:49 PM | #15362 |
Hi! I NEED HELP WITH MY CAR. Idle is rough and low and there is an air leak but not sure what exactly it is. When car runs for a while, i can smell unburnt fuel or gasoline from the engine. Vaccuum leak or bad fuel filteR? Injectors have been checked and they are good. My car, sometimes at a redlight, when I gas it to accelerate, my RPM will choke a bit and jump up and down 500-1500RPM until I floor it for the car to pick up.
Here is link to video to see how my car runs 1991 Nissan 240SX KA24DE low idle issue - YouTube |
11-12-2013, 12:29 AM | #15363 |
injector lower o-rings?
i have a s13 hatch with a s14 sr
so it seems like my injector lower o-rings may be going bad i've never taken the injectors off so i dont know how this process is to go about. can you guys help me with a tutorial or something on how to properly remove the injectors and replace the lower o-rings? Thankyou so much!! |
11-12-2013, 06:32 AM | #15365 | |
I have a quick question of my own. I have looked all over, rimtuck etc, and have not found a good answer: 7x7.5 +42 ICW (Gram Lights G-Games clones). I know OE SE is 6.5x16 +40 How much spacer do I need front and rear to push these out to the fender lip? I am thinking maybe 15mm rear, 10mm front or maybe 20mm rear and 15mm front. The wheels are in almost perfect shape, have new tires on them, so I want to use them until I can get the cash for what I really want. I figure a little cash for spacers won't be too bad and it will make the wheels set up right
11-12-2013, 07:24 AM | #15366 | |
I looked up Kazz, but I don't see any ring & pinion kits, just differentials. My S14 already has a VLSD, and I don't really need to get a stronger one yet considering my current power goals. My original question stands. Of the R200's from the JDM S14, S15, and Q45, which ring and pinion would be the easiest for me to use in my S14 R200v?
Daily: '99 Pontiac Trans Am. Projects: '96 S14, '87 Merkur XR4Ti Last edited by Chronicle; 11-12-2013 at 08:48 AM.. |
11-12-2013, 08:28 AM | #15367 |
I just got a SR (redtop)swap done at a shop and everything works great the only thing it smells like gas in the cabin especially when I get into boost, I already try looking for leaking and I didn't find anything. What do you guys recommend to check next?
11-12-2013, 08:44 AM | #15369 | |
Sent from my XT907 using Tapatalk
instagrizzle @meadwa |
11-12-2013, 10:07 AM | #15371 |
Ok, I've been searching all day long so far for my answer and having no luck..
So I bought a coupe with a blown HG with intentions to repair it. When I bought it, the engine was half apart, as in exhaust manifold off, and intake manifold pretty much off aswell. ***So my problem is*** MISSING BOLTS So I need sizes and or where to get them I searched everyware please help., pretty much all intake manifold bolts or studs whatever they are. same with exhaust side of things. the studs are there i need to know the sizes of the nuts i guess, But on intake im missing everything. I checked the FSM nothing. please help its the only thing stopping me at the moment............ |
11-12-2013, 11:26 AM | #15372 | |||
Bandwagon.
Im guessing the s14 and s15 should be the easiest, but is it cost effective and cheap to get those differentials. double check the fuel lines, might could be your exhaust leaking where the down pipe to the cat/test pipe. |
11-12-2013, 10:27 PM | #15373 |
When doing a fender wire tuck on an S13 hatch, am I supposed to remove the plastic tubing around the thick bunch of wires in order for the fender to fit back on perfectly? My buddy even made a cut in the frame to stick it in as close as we could and the fender fit like shit. I spent so much unnecessary hours on it that I gave up and ended up putting the bunch of wires back in the original spot. After we put everything together, we thought that removing the plastic tubing might have helped a lot. Is that all I needed to do? Or do I have to have flared fenders / overfenders?
Pics: |
11-13-2013, 10:58 AM | #15376 |
Alright will try that out. Thanks.
11-13-2013, 06:18 PM | #15377 | |
11-13-2013, 10:14 PM | #15378 |
i get a clunking noise mainly from my rear passenger side coilover at low speeds. and a lot of the times when im stopped on a hill, when i roll back i hear a rubbing noise from the same coil. It also happens when i hit reverse. not sure if something is wrong with my coilover or if i just need to run spacers. any suggestions?
11-13-2013, 10:31 PM | #15379 | |
11-13-2013, 11:11 PM | #15380 |
I'd really like to know how you were able to fit the stock fender on without any mods (like flaring) without removing the plastic o.o pictures would be awesome. It just wouldn't work for me.
11-13-2013, 11:40 PM | #15382 |
Trader Rating: (24)
Feedback Score: 24 reviews
I autocrossed mine for 3 years (couple years of r-comps) and a track day or two and it looked great when it came out.
Sold to a friend to put in his drift car and it was dead in a year lol. |
11-14-2013, 02:20 AM | #15383 |
Will an engine rebuild kit fix a bad or broken engine? I know this is such a dumb too general question but I need help. I might buy a 240 DOHC. It doesn't run. The guy revved the engine way too high on the freeway and it hasn't ran since. I'm going to trade my AE86 SR5 and he's giving me 500$ on top of it. Is it worth it? Will the rebuild kit fix the entire engine? Any help or input is really appreciated, thank you.
Sent from my SPH-D710 using Tapatalk |
11-14-2013, 02:31 AM | #15384 | |
11-14-2013, 06:22 AM | #15385 |
Silly question. How do you break in a freshly built engine if it requires a tune to run. I'm assuming set the rev limiter really really low and then have it tuned; but I'm curious if even at such a low limit if it would in any way damage the motor while getting an initial tune.
I'm picking up the parts for my spare vq35 and I'm wondering if it would be easier/safer to initially break in the motor on oem intake system/ecu and then AFTER break in convert to map sensor/standalone and itbs. Or am I just over thinking as usual... |
11-14-2013, 08:12 AM | #15386 |
Trader Rating: (92)
Feedback Score: 92 reviews
so I did rear brakes ( new pads/rotors ) last night.
I have spongy brake pedal now? I visually checked for leaks I couldn't see any, nor can I see any moisture/brake fluid on the lines themselves. Would just a standard brake bleed remedy this situation? Just find it odd that my brakes feel more spongy with new pads than it did with worn out ones. Sent from my iPhone using Tapatalk |
11-14-2013, 10:09 AM | #15387 | |
Trader Rating: (31)
Feedback Score: 31 reviews
Small Questions Thread (SEARCH FIRST! Use this instead of making NEW threads)
11-14-2013, 08:42 PM | #15390 | |
And as you can see, i'm pretty damn low. Not even close to touching the harness. |
