04-10-2018, 04:22 AM | #21751 |
KROIL, scrub with stiff brush, KROIL, repeat 3x. Spray with Kroil from the top, and let it do it's thing over 24 hours, repeat 3x
04-10-2018, 08:04 AM | #21752 |
Are s13 power steering (more specifically KA24E) known to be slow or laggy?
For example, if I try to do fast AX style moves like slaloms, it's like the steering hits a wall, then picks back up. Is that normal behavior of an old system? Or does mine need a refresh? |
04-10-2018, 10:28 AM | #21754 |
Been having issues with gear oil leaking in between my KA trans and driveshaft. Threw a new seal in, still leaked. Thought I installed it wrong so I pulled the seal out and reseated it.. still leaks a considerable amount when it sits after driving. Any ideas? Super frustrating.
04-10-2018, 11:26 AM | #21755 | |
04-11-2018, 04:44 AM | #21756 |
That's just a 20 year old car marking it's territory.
04-12-2018, 12:24 PM | #21757 | |
Turn the wheel back and forth, lock to lock while you fill it. Our cars are supposed to take DexronIII btw.
93 coupe - AutoX/Fun summer daily/Eternal project |
04-12-2018, 01:46 PM | #21758 |
How have you guys with very low cars dealt with this?
Mines not even that low but still rubs on speedbumps and potholes, I don't think hammering it is a good idea and I don't know about cutting and welding, kinda afraid I'll fuck up the chassis structure. |
04-16-2018, 11:09 PM | #21760 |
Me again... Still dealing with my coilover undulation. Noticed that front has little to NO compression. Is this normal for a supposed 8k front spring?
Not my car, but the suspension movement on mine it's EXACTLY the same. https://youtu.be/cc4ve88IgRo Sent from my SM-G930P using Tapatalk |
04-17-2018, 04:30 AM | #21761 | |
04-17-2018, 07:51 AM | #21762 |
IDK if that's normal but you just described the power steering on my single cam. It does the same thing. That being said, I think it is low on fluid, due to a leak which I can't track down. I ordered a rebuild kit for the pump though, so hopefully that will stop the leak.
04-17-2018, 02:21 PM | #21763 | |
04-17-2018, 02:54 PM | #21764 |
Trader Rating: (31)
Feedback Score: 31 reviews
So I picked up an apexi GT reserve tank. Apparently instead of the return going to the lower radiator hose, it t's into the heater core return line to the motor. Is there any advantage to either setup? I know they're both a "negative pressure" area, just trying to think of any advantages
Sent from my SM-G955U using Tapatalk Last edited by mr.nismo.; 04-17-2018 at 03:25 PM.. |
04-17-2018, 04:48 PM | #21765 |
can anyone help me understand why I have this hood gap? kouki bumper with upper kouki bracket, and the hood is pulled as far forward as possible https://imgur.com/a/Oj9pJ
04-17-2018, 04:57 PM | #21766 |
ITS LISA'S FAULT!!!
Trader Rating: (41)
Feedback Score: 41 reviews
loosen up your bumper, push forward... tighten while holding forward with knees
if this doesnt work, you need to realign your mounting brackets + fenders no one likes to believe when i say "25 year old metal fatigues, brackets shift and panels move over the life span of the car".... buuuuuuuuuuuuuuut it does! |
04-17-2018, 06:56 PM | #21767 | |
04-18-2018, 04:27 AM | #21768 | |
I have Apexi Evo on mine, full arm kit, and ST anti sway bars. I KNOW all flexion is my tires only(oe SE wheels and tires becuase trying to save for good wheels and solve old car problems like hub bearings going out, ball joints going out, other bushings failing....yeah, 240 problems)
04-18-2018, 01:16 PM | #21769 | |
I guess I need to know if this is a spring rate/ quality issue, or dampening. Because I'm willing to upgrade to swift springs and/ or step down in spring rates, but poor dampening is writing off all the money spent on these. I just don't have enough experience with c/o to determine which is it. Any suspension Gurus in Socal willing to help or suggest a shop that can diagnose modified suspension ride quality? Getting desparate now. [emoji17] Sent from my SM-G930P using Tapatalk |
04-18-2018, 02:14 PM | #21770 |
ITS LISA'S FAULT!!!
Trader Rating: (41)
most coilovers ride stiff as shit... you sure youre not being over sensitive about the coils? MOST entry level coils for the S Chassis are stiff as hell! the video you posted is fairly normal on entry level 1 way coils. if youre thinking theyre going to move up and down like a set of springs + dampers, then youre going to be sorely disappointed. even with softer springs, the car is still going to barely move when you push down on it.
bumps ARE firm and coils settle instantly when going over speed bumps... if you start bouncing, then you hit the speed bump WAY too hard. the car will still have body roll thru turns at higher speeds, but not much. Stance coilovers are one of the better entry level 1 way coilovers out there... after reading thru your posts, it honestly sounds like you are just being overly sensitive and paranoid about your coilovers and/or spring rates. coilovers ARE NOT meant for comfort (for the most part). theyre basically race car suspension for consumers. if you want comfort, then youre going to be hard pressed to find something within the $1000 price range. PS: the proper word is DAMPING, not dampening. Damping is the ability to absorb a resistive force... Dampening is when you make something wet. |
04-18-2018, 03:18 PM | #21771 | |
Perhaps I am being overly sensative about the c/o, problem is, I don't have a real world point of reference. This is why I'm reached out to the Community for validation. Best I have for perspective is youtube videos, and those I have seen don't show the occupants "bouncing" like I'm experiencing. <-- this including emusa/ godspeed/megan, raceland!!! So, as you mentioned, Stance should be a better ride so what gives? The biggest variable in all this is the the coils are second hand units (bought used) so who know if they've been tampered with or advrtised incorrecly (not 8k spring rates). I guess the only way to know is for a experienced S-hassis enthusiast to drive it and validate them. Sounds a bit pathetic, I know, but as I said.. i'm getting desparate.lol Oh, and sorry about the "DAMPING" mistake, I thought I had that right.(Derr) I know a member here has this mentioned in his signature with a supersoaker toy to illustrate the point. How embarrassing. Haha Sent from my SM-G930P using Tapatalk Last edited by [240sx]; 04-25-2018 at 08:19 AM.. Reason: **Update available** |
04-18-2018, 04:26 PM | #21772 |
ITS LISA'S FAULT!!!
Trader Rating: (41)
honestly man, your best bet would be to call Stance and talk to them directly. if the damper was damaged in some way, the piston might be seized. they can rebuild them for you, but theres a fee for it.
but from what youre describing, it sounds like a stiffer suspension rate than what youre use to. id offer to ride along in your car with you, but i live in Las Vegas which im sure is quite a ways away. silly question, have you turned the damping rates down on the dampers themselves with the little knobs? if theyre cranked all the way up, then the ride is going to be HORRIBLE since compression and rebound are basically cranked up to the max. for a daily driven vehicle, ive never run more than half the clicks available on my coils... currently on my Protege5, my YellowSpeeds have like 32 clicks for damping. i leave mine at like 16 upfront and 12 in the rear. my S13 hatch i run Fortune Auto 500s set to 12 upfront and 10 in rear (24 clicks damping). if you have the damping set too low, the ride is too squishy feeling since the spring winds up taking the brunt of the impact where as if its set too high, the damper doesnt have enough actuation to properly absorb and repsond. basic rule of thumb, if youre street driving your car, set the damping to about half for a decent ride. |
04-18-2018, 05:03 PM | #21773 | |
I had an s14 once that was booty, the ride always felt like my suspension was made out of a shit ton of balloons. Bounced around on smooth roads like yours. The damping was all messed up from the PO, the coils ended up going to shit not long after i found this out, I have a suspicion that the damping being terribly set caused accelerated wear. Sent from my iPhone using Tapatalk |
04-19-2018, 04:41 AM | #21774 | |
If you don't like the harsh suspension of your coilovers, I suggest talking to Stance and moving to Swift springs. You may even want to consider a progressive spring if they have one. ISR Pro coil overs in my son's old kouki were stiff as fuck, jolted the seat on back roads, but they were also very nice on the freeway. My Apexi's are nice everywhere, allow the car to absorb bumps nicely, don't chatter the seat on a bumpy road. Bottom line though, you put stiff race car parts in your car, you are going to have a stiff ride. My only advice is if you do not plan to race hard, and only want that occasional auto x or drift, DO NOT GET ISR or other super stiff motor mounts and transmission mounts. You think stiff coilovers suck, try the vibration that shakes the car apart. If you go still mounts, also get a good damper pully to balance your engine externally, you'll thank yourself with the light flywheel if you do
04-19-2018, 10:50 AM | #21775 | |||||
I've been on full soft(-8), and just tried (+6), still not much of an improvement. Used your setup as a reference and kept the rear two settings softer. Quote:
Too late about the mounts tho, sorta. Got Nismo motor/trans mounts & energy suspension Steering rack, rear subframe & diff bushings. The rest is all oem Nissan rubber which was replaced 2yrs ago. You think loosening and re-torqueing the LCAs at their new static height will help? I did it while on lowering spring 2 yrs ago so it's only a inch or so difference. Here's a short clip I made. Notice how my knee/legs keeps being bounced/ jolted? Aslo, sorry for the bad quality uploaded... youtube would only do 480p https://youtu.be/NdaHpJC1u00 *EDIT* That part of the freeway is smooth. Sent from my SM-G930P using Tapatalk |
04-19-2018, 01:23 PM | #21776 | |
ITS LISA'S FAULT!!!
Trader Rating: (41)
honestly man... your best bet right now is to the send the coilovers back to Stance for a diagnosis/rebuild. |
04-19-2018, 09:21 PM | #21777 |
I swapped over an automatic chassis harness onto my s13 cuz my old one was shit. Would i need to jump the black and tan wires to foul it into park at all times if i have wiring specialties sr20 engine harness and lower harness?
04-19-2018, 10:13 PM | #21778 |
Anyone in SoCal running an rs-enpalthy ecu?
S14 ka Isr 3871 turbo 550cc nismo injectors Z32 maf ? In need to test an ecu just to see if mine has a problem, if so please IM me, I’ll pay for your time and inconvenience. Sent from my iPhone using Tapatalk |
04-20-2018, 04:29 AM | #21779 | |
That non revvy KA thing, get an ACT 13 pound flywheel, sucker will rev quick, but do not be tempted by the 11 pound one or you will shift third gear at the second crosswalk of an intersection from a red light. The engine is capable of revving 7500, comfortable at 7200 shift point, but you really fall off power at 7k. 7200rpm shift DOES drop right at the torque peak though. I'm tellin ya, that ACT 13# wheel is nice, but get the external damper pully with it
04-21-2018, 06:59 AM | #21780 |
I bought a new knock sensor harness but the connector seems to be mirrored, it doesn't fit with the current connector. Are S14a knock sensor harnesses different from other Nissan harnesses or what?
Also it has only one wire coming to sensor itself, does it matter which pin it goes to? Left or right? Just wondering since if it can be either one I can just get a new female/male connector somewhere This is the one I need And this is the one I got, seems to be mirrored or something |
