Old 11-10-2017, 02:39 PM   #1
240Prax
240Prax is an unknown quantity at this point
KA Full 240sx Manual Swap
I was planning on manual swapping my 240sx but school came up and I had to let go of the car. Now I have the full manual swap sitting in my garage.
-5 Spd Manual transmission + clutch sleeve, clutch fork, new pivot ball, clutch fork rubber boot and all necessary springs. Also will include Megan Racing short shifter. And has the speed sensor but previous owner cut the wire so new wire will need to be soldered on. The previous owner said it shifted good and when test shifting it shifts fine. Not parting this out, buyer will have to buy all of it.
$300
-XTD OEM KA24E/DE Stage 1 clutch kit, includes flywheel, clutch, pressure plate, both bearings and clutch alignment tool.
$150
-5 Spd Non-abs Manual transmission driveshaft
$80
-Techno toy tuning manual transmission cross-member
$50
-Clutch Pedal with mounting bolts
$80
-Manual transmission duralast clutch slave cylinder + master cylinder
$40
-ISR manual clutch line
$20
-Manual Transmission bellhousing bolts
$25
-Flywheel bolts
$30
-Pressure plate bolts
$10
If any other parts are needed for the swap I probably have them, just ask.
Located in California
Text me at 209-361-8026
240Prax is offline   Reply With Quote
Old 11-13-2017, 04:05 PM   #2
mattrobertsxn
mattrobertsxn's Avatar
mattrobertsxn is an unknown quantity at this point
will you sell short shifter separately?
mattrobertsxn is offline   Reply With Quote
Old 11-14-2017, 06:06 PM   #3
240Prax
Everything has been SOLD
