09-03-2017, 04:48 PM | #1 |
driver side tail light problem
Hey everyone somethings up with my driver side tail light in my s14.
i thought the tail was out so i replaced the bulb and it still didn't fix itself so i wiggled the connector to the tail light and than the running light turned on. So i thought i had fixed it but its just the running light the brake light isnt working. Does anyone know of a fix? |
09-03-2017, 09:48 PM | #5 | |
i have no idea where to ever start with tracing the issue electrical especially wiring harness on vehicles is not my forte.. could it be a loose ground? should i get a volt meter and start testing the wires? replace fuses idk. Last edited by Dunsparth; 09-03-2017 at 09:50 PM.. Reason: Spell correct added more info |
09-03-2017, 10:06 PM | #6 |
Trader Rating: (92)
Feedback Score: 92 reviews
Replacing fuses wouldn't help . A fuse is either blown or not. Multi meter is going to be your best friend. Tracing wires isn't hard since they are color coded just time consuming.
Sent from my iPhone using Tapatalk |
09-03-2017, 11:24 PM | #7 |
I'd eat a mile of shit to get to that asshole ^^^^^^^^^^^
Www.PowerAutosports.com |
09-06-2017, 10:45 PM | #9 |
Gotta be the bulb socket itself, the metal tabs at the bottom and the side get pushed down too far over time and don't contact the bulb properly. Take a small pick and gently pry those tabs up/out to try and regain proper contact with the bulb, also use a SMALL amount of dielectric grease to cover the base of the bulb, good luck
