02-01-2018, 01:40 PM | #1 |
Boost leak test question.
So I did a boost leak test on my KA-T S14 today.
Had your typical "clamp too loose" leaks and was able to fix those just fine, but I could hear a whooshing sound from like under the intake manifold. My questions: - Since it's after the TB, would that be unmetered air just coming from the crankcase? I confirmed the egr block off wasn't the source of the air. - What's possibly leaking? - I heard a creaking sound while pressurizing and of course now there is oil on the ground, likely blew out the back of my valve cover gasket maybe? Just looking for some tips of where to look next. Oil pan looks fine, but haven't been able to get under her yet.
5.3 V8 Swap w/ Nitrous |
02-01-2018, 02:34 PM | #3 |
I can totally take a look at that! Would that blow oil out as well? or was that just likely my valve cover gasket leak getting worse from the pressure
02-01-2018, 05:33 PM | #5 |
There's 4 rubber hoses on the underside of the stock intake manifold that combine onto one hose that goes to the pcv. Not sure what you did about that but those rubber hoses have been known to blow off and or crack once going boosted.
Sent from mTalk |
02-01-2018, 08:31 PM | #6 | |
How do you have the PCV set up? Still ran to the intake manifold? All of that needs to be removed aside from the PCV box on the timing cover which should be ran to a vented catch can.
If you're having air coming out from the boost leak test via the valve cover or PCV you have a tired engine with very poor ring seal. Quote:
Remove the manifold, knock out the PCV ports from the runners, tap and plug or weld them shut. Run the PCV on the timing cover to a vented catch can.
MRP Manufacturing |
02-01-2018, 10:57 PM | #7 | |
GM2 (SW/AW)
It's probably coming from one of the headless hex plugs in your intake runner.
I had the one in the rear leak air like a bitch. Look up some pictures of the intake to know what I mean.
KA-T for life! Current for sale advertisement |
02-03-2018, 07:21 PM | #8 | |
Car drives fine, runs and pulls strong. 148k on the odo, and 160psi across all 4 cylinders. I am only chasing the sound now. Just a big woosh from the passenger side, not sure where it's coming from. But after charging it and hearing the stretching/crackling sound, im getting oil on the ground, which may be from the PCV - i am going to get all of that removed now.
02-07-2018, 10:45 PM | #9 |
Trader Rating: (25)
Feedback Score: 25 reviews
It could also be the gasket between the runners and the plenum....surprised that wasn't the very first suggestion. When I boost leak tested mine it was leaking there
02-08-2018, 12:36 PM | #10 |
Thanks! I’m going to test again and focus on that
02-09-2018, 09:43 PM | #11 |
I removed the intake manifold today, and yes there were tons of dryrotted hoses. I am going to remove all of them and the PCV system.
However, still don't know where all the oil is coming from, gonna be fun.,
02-12-2018, 03:00 PM | #12 |
Well, got me a 3/8-16 tap and some plugs from Tractor Supply Co. Fit like a dream. May JB Weld them in there since threadlocker hasn't been my best friend on this engine
02-12-2018, 04:06 PM | #13 |
It's possible you pressurized the crank case and blew the rear main seal out. I've seen this happen on cars with incorrectly routed catch cans that were putting boost into the crank case.
02-12-2018, 05:02 PM | #14 |
Once i get this intake back on, I will be doing a thorough clean and search for source of the leak. I think it could be either my front timing cover seal, or the turbo drain tube may have damage to it. But I will know more soon!
02-20-2018, 04:52 PM | #16 |
Got her all finished up and drove it home today. No more sputtering! The boost leak was definitely in either the plenum gasket or the PCV system.
Thanks guys!!! It's perfect!
