Old 02-04-2018, 12:32 PM   #1
calebbo
calebbo is an unknown quantity at this point
KA-T Questions
The goal is 220WHP
This is what I bought:
Turbo, Elbow, Coolant lines (Rebuilt SR T25)
Turbo Manifold (ISR V2)
FMIC Kit(CX Racing)
3" Exhaust (HKS Hi Power)
550cc Injectors (Deatschwerks)
Enthalpy Tune
Z32 Maf (N62)
BOV (HKS)
Headgasket (Felpro)
ARP Head Studs
Spark Plugs
Oil Feed/Oil Drain Lines
Glow Shift Gauges (Boost, Water Temp, Oil Pressure, Wideband)
Timing Chain Kit Install by shop (Includes *)
* Front Main Seal
* Tapped Oil Pan
* Oil Pump
My question is pertaining to the head.
When I swap out my head studs to ARP and change the gasket to a felpro, should I go ahead and swap out the valve stem seals?
I also have 200PSI compression on all 4 cylinders on a warm engine. Wide open throttle. 4 engine cranks. MATCO compression tester.
I assume this is carbon buildup since max is supposed to be 179-180PSI. So should I set the pistons to TDC and scrape off the carbon on the pistons while the head is off?
1991 S13 w/ rebuilt KA and Trans
calebbo is offline   Reply With Quote
Old 02-05-2018, 08:08 AM   #2
tuzzio
tuzzio's Avatar
If you're already doing all this work, I would absolutely change the head studs and head gasket.
Old 02-05-2018, 08:28 AM   #3
calebbo
The HG and head studs are a given. I just don't know if I should swap the valve stem seals and scrape off the carbon on the pistons.
Old 02-05-2018, 08:46 AM   #4
EnnEssEnnKAT
EnnEssEnnKAT's Avatar
EnnEssEnnKAT can only hope to improve
Valve stem seals have a spring built into them so they wear and tear and get weaker over time. Prob a good idea if you have the spring compressor to remove and replace them with new.
Sent from mTalk
EnnEssEnnKAT is offline   Reply With Quote
Old 02-05-2018, 08:48 AM   #5
calebbo
Sent from mTalk
Do the valves need to be replaced as well or are they fine?
I have low HP goals. Around 220 at the wheels.
The warm engine compression test showed 200psi on all four cylinders after 4 cranks. It seems to be a very healthy engine. It has ~90k miles on it.
Old 02-05-2018, 09:35 AM   #6
EnnEssEnnKAT
It seems to be pretty high compression for a used motor. As for the valves those do not need to be replaced, they're typically reused. What I've done is remove them and soak them in a special detergent to remove the carbon deposits and then reassemble. That's the best 'free' option.
Sent from mTalk
Old 02-05-2018, 10:02 AM   #7
tuzzio
tuzzio's Avatar
Valve seals are so cheap youd be a fool not too.
jwt makes a tool where you dont have to remove the head. works well.
Old 02-05-2018, 11:36 AM   #8
calebbo
Sent from mTalk
That's why I assumed it was carbon build up.
Anything I should do besides replace the seals? How a bout scraping off the carbon from the tops of the piston? Will that help lower the compression test to 180?
Old 02-05-2018, 11:37 AM   #9
calebbo
Well a fool I will not be. Replacing them.
