Old 03-16-2011, 07:25 PM   #1
carcrzy920
Trader Rating: (24)
carcrzy920 is an unknown quantity at this point
Feedback Score: 24 reviews
ca18, sr20, RB, KA, random parts goodness
contact: PM or text 540-903-4022
tired of my shed and room being clustered up with stuff im not using so heres what i got, if your going to flake please dont waste my time because im really sick of people flaking out lately.
ka24de auto ecu #25-$30
rb20 ignitor-$35
j30 front calipers, brackets-$60
x3 j30/z32 ignitors-$25 each
q45 ignitor-$25
ka24e distributor, cap, and rotor-$30
ka24de alt-$30
ka24de coil-$25
x2 oem sr20det O2 houseing (good for a budget t25 setup)-$15 each
oem s13 suspension-$25 pick up
s13 ka24de oem header-$5 pick up
s13 hatch oem taillights-$35
s13 SR blue valve cover-$60
ca18det stripped valve covers-$45
s13 KA24de valve cover stripped-$35
s14 ka24de valve cover white with splater paint-$35
r32 skyline crossmember-$70
s14 oem tension rods-$30
ca18det oem turbo manifold-$40
new KA top timing chain tensioner-$25
s14 ka24de distributor-$45
S13 coupe sunroof glass with latch-$50
s13 SR cam angle sensor(plastic cover cracked and plug clastic surounding cracked but still works fine)-$65
r32 powersteering resevior-$25
x2 g70 s14 ka mafs-$40
93 s13 ka24de #28 5 speed ecu-$30
2 s13 SR coilpacks-$30 each
s13 single cam ka mafs-$20
s13 SR fuel rail (no injectors)-$20
s13 ka fuel rail with injectors-$40
s14 bumper parking lights (new)-$30
450cc top feed injectors-$130
ca18det t25 wastegate-$20
s13 SR20 water neck-$40
s14 steering wheel airbag-$50
s14 rear seat belts-$50
s13 sr oem exedy pressure plate-$30
ka24de oem exedy clutch disk with lots of life-$20
s13 front OEM calipers with OEM lines-$30
SR steel hot pipe with hks flange welded on-$55
SR alluminum hot pipe-$40
s14 mint mudflaps, just could use paint-$50
HKS bov flange only, never used-$10
apexi avc-r boost controller(just the main unit, needs boost selunoid and wire harness. only like $180 through apexi)-$60
thats about all i can think of right now, i got some other random parts too just ask me and ill take a look at what i got.
sorry for the shitty cell pics
I'm so JDM i sleep on the right side of the bed.
carcrzy920 is offline
Old 03-17-2011, 10:24 PM   #2
carcrzy920
Trader Rating: (24)
night time bumpedy
Old 03-18-2011, 02:56 AM   #3
jdmchuckiwill
jdmchuckiwill is an unknown quantity at this point
how much for valve cover shipped to 37087
and is it in good condition.
are the coil pack and coil cover screw holes in good condition.
jdmchuckiwill is offline
Old 03-18-2011, 08:54 AM   #4
rb20240sx
rb20240sx's Avatar
rb20240sx is an unknown quantity at this point
s14 side marker
Can you do the right s14 side marker for $15?
95 SE Serengeti sand- RB25 Neo
rb20240sx is offline
Old 03-20-2011, 04:35 PM   #5
carcrzy920
Trader Rating: (24)
bump it on up for the second time
Old 03-21-2011, 02:49 PM   #6
JDS Performance
JDS Performance's Avatar
Trader Rating: (53)
JDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of light
Feedback Score: 53 reviews
WTB; S13 SR20DET Redtop Various Parts Needed
I am putting a SR back to totally stock for my upcoming video series - my donor motor is missing quite a bit.
Water Neck
It is the neck in front that hooks to the bottom radiator hose
If you have the mounting bolts too that would be awsome!
I also need the alternator belt tensioner setup - I have the bracket but not bolts/nuts/washers
I need the (3) bolts that bolt the power steering bracket to the block - I have the one in front
I need the (4) bolts & small plastic isolators that go under them to bolt down the fuel rail
I need the (4) water pump pulley nuts
I also need the fuel hardline that monts to the rear of the fuel rail - I also need that rubber line and clamps to attach it as well as the bolt that bolts it to the intake manifold torwards the front
I need the (2) turbo inlet pipe nuts/washers as well as the (3) bolts/washers for the turbo outlet pipe T25 turbo.
I also need (3) turbo banjo bolts and crush washers for them.
I need the stock catch can "black box" and mounting bolts and hose.
I need the A/C bracket with mounting bolts
Pix/prices shipped to Concord,NC 280825
[email protected]
JDS Performance is offline
