11-09-2016, 09:59 AM | #20461 | |
11-09-2016, 08:21 PM | #20462 |
1jz s13? Does it really give you that much understeer? Would making it sit far back in the bay help that much? Would using it for drifitng just not be worth it? Just curious any info appreciated.
https://www.instagram.com/jdpowersport_/ |
11-10-2016, 04:32 AM | #20463 |
I have, that's why I am puzzled by that photo. I had to go outside, feel around up there to make sure there was actually nothing there. There is also an activation switch in the front bumper area. I am still mystified by the photo, and wondering why my fsm and their pages do not match
11-10-2016, 05:45 AM | #20464 |
11-10-2016, 10:34 AM | #20465 |
Those of you guys running fiberglass fenders how are you fitting the corner lights in them so good? I have some origin +20mm fenders and the corner fitment is crap. Should I be modifying the fender itself by cutting it or modifying the actual corner light?
11-14-2016, 11:26 AM | #20473 | |
installed same kit, car no start wat do? |
11-14-2016, 01:27 PM | #20474 |
Boost creep issue:
Long story short, my car has been sitting for sometime and ever since I adjusted my HMIC to be centered, I have boost creep. I checked if I have any leaks and I do not (sprayed soapy water). Can a stock wastegate cause this issue too? Current setup: PBM HMIC Stock s13 blacktop sr20det (t25) Greddy profec II Boost controller (set to 6psi)
11-14-2016, 01:57 PM | #20477 |
Trader Rating: (24)
Feedback Score: 24 reviews
Sounds like you changed something else.
Wastegate reference line is hooked up with no leaks? If you remove the EBC from the equation does that fix it? |
11-14-2016, 02:00 PM | #20478 | |
I have a feeling I know what it is but i'll have to check it later. I did change out my vacuum line from the EBC to wastegate because it was pinched (I thought this was the issue). I'll recheck an update later. Thanks!
11-14-2016, 09:12 PM | #20479 |
Maybe someone in here can help me out with this wiring issue. Searched for hours and havent found anything on forums. Going nuts at this point checking wires and taking things a part.
http://zilvia.net/f/showthread.php?p...51#post6135751 |
11-14-2016, 10:21 PM | #20480 |
like e1 said, remove the EBC, connect the signal line directly between source and wg, then check boost pressure again. could also be a ruptured wg diaphragm.
11-15-2016, 01:42 PM | #20481 |
Can asians have freckles ?
Non car related but yahoo answers from 7 years ago is all like " my distant cousin to the 18th degree is asian and has freckles" which isnt really an answer. Just thought about it today, and i never really have noticed any freckles on asians. Dunno fam Sent from my iPhone using Tapatalk |
11-15-2016, 01:55 PM | #20482 | |
Trader Rating: (26)
Feedback Score: 26 reviews
11-15-2016, 02:01 PM | #20483 | |
sorry fam |
11-15-2016, 08:18 PM | #20484 |
does anyone know much about subarus? Thinking of picking up either a subbie, g37 or is300 as daily cars. Need someone with subaru experience to help gauge ads
Skurr Skurr |
11-17-2016, 07:44 AM | #20485 |
hey guys first of all sorry for asking if this has been asked a million times but I'm at work and tried searching for Silvia steering wheels, I got a ton of for sale posts and I don't want to spend any more time on here and get in trouble
okay so my original 240 wheel has been messed up and bought a 3 spoke Silvia wheel to replace it and just got a clock spring to shut off the annoying blinking light (hopefully) will everything. will everything line up and just go right on or will I have to do any modifications to the wheel for it to go on? any help appreciated and again sorry if its been asked a lot but I have inspection coming on soon and I need a functioning horn button that doesn't get stuck lol |
11-19-2016, 11:31 AM | #20486 |
Having a hard time figuring out which circuit sports starter to get for the RB
Since the number on the starter says 23300. Does that mean I get the AA300 starter correct? Picture of Different starters Untitled by Lawrence King, on Flickr Untitled by Lawrence King, on Flickr |
11-19-2016, 11:43 AM | #20487 |
Can anyone take 5 minutes out of there day to take out there eccs relay on s13 preferably and check this pin on it with ignition on? Im getting power here and at the ecu pinouts no matter how many harnesses and ecus I swap out.
11-19-2016, 11:39 PM | #20488 |
What spoiler is this?
https://imageshack.us/i/pmPUG4QPj
Hey guys! Does anyone know what kind of spoiler this is? Or something that looks similar? Thanks! |
11-20-2016, 05:08 AM | #20489 | |
11-20-2016, 02:03 PM | #20490 |
My friend is in the middle of his s15 sr swap and he has some questions so i thought id try here. (Yes we searched) j want some confirmation.
When using the sr 5speed do you still need the s15 diff to retain speedo or can he use the tranny sensor with the dakota digital. Also is it true if you have no speedo your vct wont work? Ive read conflicting info on whether its speedo or oil pressure. Any help appreciated thanks .
