03-16-2011, 05:55 PM | #1 |
RB26 full swap for sale!!!!
OK so I decided to abandon my rb26 project, I'm going to give it at least a week before parting it out so don't ask I will post prices for all in a different thread. The swap is practically complete minus a few small items witch ill list further down. The engine is torn apart because I wanted to look at the condition of the engine and see what I was working with. I can put it together for those of you who are not familiar with this engine but everything is together and labeled so no missing bolts or misc. items. you will receive a engine: complete head, intake manifold with sensors, and itb's , exhaust manifold, turbos, turbo extensions, lines, cas, intakes, mafs, igniter, fuel rail, injectors, rb25 power steering pump,alternator, I dont have the ac compressor only the bracket, rb25 trans and clutch, r33 harness and ecu. Basically the stock engine. Swap kit: syko performance engine mount and tranny mount, sway bar spacers and steel drive shaft shop drive shaft,
r33 cross member and i can include your choice of ka harness. this kit works with either s13 or s14 since the both chassis use the same cross member. I'm willing to do: 1.engine swap+swap kit+parts 2.engine swap+swap kit 3.engine swap These are the things missing to complete the swap witch aren't hard to acquire. 1. 02 sensors 2. you will see in the pic but your choice.. 1 custom turbo outlet 3. rb25 crank pulley cause the 26 one i have doesn't work with 25 pump 4.injector resistor box 5. machine work (depending on your choice) here are the parts that i will include if you take it for my asking price..These parts are new or extremely low miles.. THIS IS ONLY IF YOU BUY ALL FOR MY ASKING PRICE.. OTHER WISE IT WILL BE ALL STOCK...if you need more pics or if really interested txt me at 713-545-8924 stan.. 1.HEAD stock complete 2.cosworth metal headgasket 1.1 87mm 3.micro-polished ferrea intake and factory exhaust valve (standard size) 4.Tomie type A cams 5.HKS cam gears in/ex 6.HKS timing belt 7.Brian crower valve springs and titanium retainers 8.ARP headstuds 9.Oem valve cover gasket and halfmoons 10.powder coated valve covers with matching intake manifold 11.tomie metal intake gaskets 12.name less exhaust manifolds (they look good quality) 13.Garret 2860-5' x2 twin ball bearing 360hp rated each 14.custom turbo outlets to down pipe (saves a ton over tomie ones) 14.5another custom just down pipe for use with stock 02 housing 15.blitz sus twin intakes with maf adapters 16.STOCK BLOCK complete but needs over bore (deep enough scratch on 5+6 cylinders as far as I can tell still usable but will encounter excessive blow by) 16.5.BARE BLOCK a little surface rust but will hone out for you before purchase.. perfect for use with provided parts. 17.Raw6 crank collar (extends crank for reliability in prolonged high rpm situations saves pumps and bearings) 18.ARP rod bolts 19.new oem piston rings 20.Tomie oil restrictors 21.cosworth main+thrust bearings standard size 22.cosworth rod bearings standard size 23.N1 oil pump 24. oem water pump 25.rb25 6 qut. custom oil pan and rb25 stock pan 26.stock 440cc injectors 27.Tomie 555cc injectors 28.tial blow off valve 29.black powder coated turbo intercooler pipes factory and custom hot and cold pipes with hks flange. ( have pipe with tial flange but not as pretty) 30.RB25 trans shifts smooth 31.ORC twin plate clutch with throw out bearing TO MAKE THE SWAP EVEN SWEATER 32. nismo thermostat 33.issis blue rad hoses 34.dfi fan controller 35.fal twin slim fans 36.blitz rad cap 37.HKS twin power DLI igntion pack 38. s14 rb ls auto tach adapter (fixes rpm) 39.power steering cooler 40.pieced together oil cooler setup -10 lines 2 core oil cooler with fan greddy oil block adapter with thermostat raw6 oil stud ( fan can be wired to dfi controller for full cool down) 38.aeromotive fuel pressure regulator kit (gauge,mounting hardware, rail adapter,fitting push-ins, and fuel lines) 39.extra set of rb26 pistons and rods.. coils..starter..stock manifolds..turbo's one blown..and any of my expertise on rb's (This is my third rb and was my first 26) well thats a lot of parts if I say so but I can't continue for personal reasons..I'll add prices for engine,kit,parts but first want to see offers on it complete. Ill update as soon as its decided for the next step. you will need an intercooler also forgot about that but the worst part (pipes) are covered. Well I have the intercooler really a precision one I might throw it in..... I think my asking price is Fair givin the parts im providing....ive seen less for more so.. you decide Thanks for looking.... To save some space.. here's a link to all pics gonna take more individal ones later. Image hosting, free photo sharing & video sharing at Photobucket 8K |
rb26 |
