07-26-2015, 07:33 PM | #1 |
1996 240sx Built SR20 500 WHP+ Pearl White
For Sale: 10.5k OBO
1996 Nissan 240sx SE Repainted WK0 factory pearl white antenna shaved Tubed front wheel wells Chassis harness simplified and fuse box relocated to airbag under dash Full OEM Navan aero Kouki Tail light DMAX rear wing 17x9+22 17x9.5+38 RPF with 255 and 275 NT05 Aero catch hood pins and GT500 hood vent Veilside evolution exhaust EXTREMELY RARE New OEM undertray Engine: S13 SR20 built with CP Pistons Eagle rods Clevite bearings. Just compression tested 165-170 on all 4. Tomei headgasket Refreshed head with TOMEI 256 cams ARP head studs New oil pump All new oem gaskets Split fire coilpacks Tomei oil pan Custom catch can set up with an lines to valve cover Isis intake manifold with iacv delete. Iacv can be added back on. Tuned on Megasquirt on a map sensor. Made 521 WHP 405 TQ on 25 psi. 320 whp 300 rq on 12 psi. Taarks PS relocation and PS cooler with AN PS high and low pressure lines Turbo and fuel: Precision 6031 rebuilt with billet wheel and 360 degree thrust bearing. DOC race exhaust manifold 2.5 inch stainless downpipe bolting up to 3 inch greddy downpipe with vibrant flex welded in. Custom intake AN oil feed and return Tial 38 mm wastegate with dump tube Treads tone 700 HP intercooler core with custom piping Aeromotive 340 lph fuel pump AN lines from firewall forward properly flared AEM FPR ID 1000 cc injectors with circuit sports top feed rail Suspension, brakes and drivetrain Silk road RMA8 coils Z32 front brakes and stock rear with Hawk HP Plus pads 15/16 BMC with SS brake lines all 4 corners 2 way diff with nismo diff bushings Driveshaft shop 12 pound aluminum driveshaft Stock sr trans (slight 4th gear scratch at high rpm) BLITZ active twin disk with proper TOB (1800 alone) PBM tension rods Circuit sports RUCA and toe rods Tomei short shifter MOOG OE replacement outer tie rods Energy suspension steering each bushings amsoil 20w-50 in engine. Will be fresh for buyer Redland MT90 in trans Motul 300LS in diff Interior and electronics Clean stock s14 interior Nismo steering wheel with works bell hub No radio but all wiring there No sound deadening in car AEM oil pressure and water temp Innovate LC2 wideband Greddy boost gauge Cons: Minor accident last year. Car was measured by body shop and front end is all in spec. Still visible.in parts of rad support. Does not affect body panel alignment. Rattle can engine bay. My plan was to eventually have it painted once I had all the engine atuff sorted out. Other stuff I'm forgetting since I've had the car for almost 7 years. Serious inquiries will be given any info desired. No test drives I will take you for ride and only with money in hand. Looking to get into something I can class into a NASA road racing class. Will come with a new set of rotors, and can come with a spare sr20 bare block and head.
96 240sx S13 SR20 521 WHP 405 TQ Last edited by jorge1190; 08-04-2015 at 06:07 PM.. |
07-28-2015, 08:40 AM | #4 |
I'm mainly looking at already built e36 M3s. I bought the diff with the subframe and swapped everything in. I bought it from JEI in VA and if I remember correctly it is a Kaaz 2 way.
Pic of dyno numbers uploaded. I will have my tuner send me the full sheet.
96 240sx S13 SR20 521 WHP 405 TQ Last edited by jorge1190; 07-28-2015 at 09:26 AM.. |
07-30-2015, 07:47 AM | #10 |
^^ what did you pick up, jorge?
I can vouch for this car also. One of the nicest s chassis in our entire area and whoever buys this will not regret it. Ton of time and effort to get it where it is today. BTW I love the fuse box relocation! Glws bro
1990 s13 hatch sr20det 2001 Lexus is300 |
07-31-2015, 07:13 PM | #13 |
Damn i would trade u... Ur far lol
http://zilvia.net/f/showthread.php?t=608744 |
