11-10-2013, 06:41 PM | #1 |
Trader Rating: (22)
Feedback Score: 22 reviews
S13 240SX Hatchback track drift car San Francisco OEM green SR20DET GT2860 64ar
Accept Bitcoin, Google Wallet, cash, and paypal
trades. Maybe Y33 Q45 and Prius GEN 2. Really looking for Road bicycles 58cm (CF or Steel*cro, NO Aluminum frames. /w Dura ace, ultegra, 105, Sora, SRAM, Campy components.) TV minimum 120hz, 46inch. DSLR Camera around $300-$500 budget. (BODY with lense). You can reach best after 1 or 2 pm. till midnight if you want come by at that time. PICS $180 3 inch intercooler (XS Engineering) $60 aluminum pipes from throttle body to turbo. Silicone hoses and t clamps. $60 Interior harness SMJ to back tail lights and pump. Stripped down to bare minimum. No wires for auto-seatbelts, no sensor for seatbelt, handbrake, trunk, doors. ( I think the size and weight is a third of the factory) $10 Z32 Fuel filter. Used for 2 track days. Genuine NISSAN filter $40 18 gauge sheet aluminum you can use to make under car protection like skid plate(s). Size is about 2x2ft or maybe 2x3. $80 ~6-puck 450 ft lbs rated clutch kit by "SPEC". Kevlar friction material and high torque sprung hub. $20 ~SS clutch line, from hardline to cylinder. Used for three track events. $20 ~Bearing and throwout bushing BRAND NEW . $160 B&M shifter kit. Best shifter! for Works for SR and KA $20 Clutch Master cylinder (like new condition) $20 Slave cylinder (like new condition) $20 SS Clutch line 10 or 12 inches (Like new. Used for 3 track events) $20 Clutch hard line. From master to slave. Painted blue, paint can easily be removed if you want to. $10 res $20 cooler with hoses (not old hoses, these only have one track day) $100 Brand new in box wastegate actuator. (14PSI) $60 Brand new in box PBM swirl pot kit. Silver. $80 high flow fuel pump (Walbro brand) $20 Relay, wiring, and adjustable fan controller with temp sensor. Headlights $140 has 2 lights in each housing. Room for 3rd if you want to install. Turn signal can also be installed. Plug and play (no wire splicing needed) $60 Black door panels. $40ea. Roll up window. $40 pair of pillar door bar covers. Have 2 sets, Black and Brown. $850 Tein Type flex, have 10 track days. $50 extra I will include second set of springs (8 springs total) 6kg and 7kg. (Front left spring had fire damage to paint when engine bay caught fire. Still works perfectly fine, was removed and tested, it's just that the paint or coating of spring looks melted a little) Rear: $60 Factory rear lower control arms. Bushings in good condition $160 KTS (from Japan) rear upper control arms. 6 Track days $100 rear Toe arms M.R. 10 track days $200 KTS Toe arms, brand new in box. $100 rear traction arms M.R. 10 track days $100 knuckles with hubs. No studs. $30 extra you get the Extended wheel studs already in there. $100 Pair of hubs with extended studs. 4 lug. $200 lower control arms. $30 Pair brake calipers. +40 pair of rotors. +$60 Hawk pads, like new only one track day. Front: $240 COR Integration, tension rods 1 track day. $180 KTS tension rods, brand new in box. $50 generic Chinese tension rod. Used temporary to drive car 20 miles. They are painted blue as seen in pic. $200 Lower control arms 10 track days (sportline, made in USA) $15 steering column no key ignition lock. $10 Steering wheel, $20 turn signals and wiper switch. $20 aftermarket steering shaft solid aluminum bushing SOLD$200 Re-manufactured steering rack (Lifetime warranty). Only used for one or two track days. With boots. Inner rods. $80 Pair of 4 lug hubs with extended studs. $40 Pair of brakes. +40 pair of rotors. +$60 Hawk pads, like new only one track day. $20 hotpipe $10 clutch bearing $20 BOV $80 2x Bolt on spacers. Comes with nuts $120 for 4 spacers. Comes with nuts 15mm 12x1.25mm 5x114 hub centric for Nissan Infiniti but adapter can be removed to fit any car if you don't want it hub centered. These have only 5 miles on them. http://www.amazon.com/Nissan-ICHIBA-...ds=ichiba+15mm Tools for sale http://zilvia.net/f/showthread.php?t=478050 $60. These TEIN upper mounts had 100 miles on them, when the car it was on had caught fire. The bright color has very good bearing, very tight like brand new. The darker color that the fire got, has the slightest up and down play of 1mm. Compared with the factory rubber piece which moves 10mm, these upper mounts are great deal. $60 Tow hitch with stabilizer. Be safe when towing your trailer/car. $60 all 5 tension rods + 2 green ones not pictured on here made my SETCHI. ($18 to ship) 2 of them are KTS aluminum arms. You could buy a piece square piece of aluminum and drill and tap it. 3 of the blue ones are just cheap eBay stuff. Working fine. $50 Brand new Front SS brake lines and clutch pedal line DOT certified. Made in Canada. Have a protective cover over the stainless steel. $40 Water lines for turbo. These can be used on S13/14/15 and many other things. $860 turbo GT2860RS 64ar. w/o wastegate. Has 8 track days of use. $880 with wastegate actuator (14PSI). $900 with mani and elbow outlet. $920 with compressor outlet adapter for 2inch pipe has plug to tap wastegate into. $940 with SS hoses above. $960 with SS oil hose and fitting. This is the complete bolt on package. $90 14PSI wastegate actuator (with 2 spare c-clips, when you buy actuators they don't include these and you wanna have 2 because you will loose the first one as soon as you try to install it. $15 all 3 gauges. Water gauge, and two boost gauges. SOLD$30 Clutch pedal SOLD$220 Engine bay wiring, with switches and kill switch. SOLD$140 Dashboard (slightly modified, cut at bottom of radio for easier removal and installation) SOLD$120 SR20DET wiring harness. SOLD$110 Starter. SOLD$100 Gas tank SOLD$240 Koyo 3 row radiator & Flex lite fans with shroud. SOLD$40 ignition coils SOLD$460 SR20DET longblock. With intake mani, throttle body, alternator, PS pump, CAS, and TRUST downpipe SOLD$80 Z32 MAF, pigtail about 6 inches. SOLD$10 Transmission MPH speed sensor. SOLD$240 5 speed tranny, shifts perfect in every gear. SOLD$50 NISMO tranny mounts. SOLD$30 NISMO tranny pivot for fork. (3 track days) SOLD$100 Shell only nothing attached: SOLD$120 ~ Doors, hatch, ~ Hood ~ Quarter panel glass and windshield ~ Back bumper SOLDBumper $100 SOLD$150 NISMO power front brace. Tension rod brackets. SOLD$360 Front crossmember, knuckles, and F&R Sway bars. SOLD$15 NISMO Cap and Greddy Shift knob SOLD$360+CYCLE NISMO 2 way LSD SOLD$100 Fenders SOLD$540 Enthalpy, 640 cc Deutschworks. NISMO regulator. Rail SOLD$200 Rear sub-frame. solid bushing SOLD$40 Passenger rear knuckle. SOLD$60ARP flywheel bolts. SOLD$260 Flywheel and Brand new SS line Last edited by Hashiriya415; 10-31-2015 at 11:58 PM.. |
11-10-2013, 09:07 PM | #3 |
Trader Rating: (22)
$10 2x Pilot bushing or $7ea
$15 Fuel pump gasket. Both for $20 Brand new. Could fit many other things besides S13 $20 for all 6. Or $8ea $15 about 45 feet. Comes with a few metal zip ties Should be able to do full exhaust or couple of manifolds $15 XL, new. Official Simpson pit wear from Falkon / Sears auto center drift team. $30 S13 SR20DET fan shroud $120 J30 dual piston front brake calipers, rotors and pads almost like brand new. The car at pick&n pull just got into accident and the brakes look like they just got done on it. It's been sitting a little, got some surface rust which can be removed easily. $150 (+$16 ship) Brand new KTS ( ADJUSTABLE CASTOR RODS THESE CONTROL ARMS PROVIDE MORE RESPONSIVE STEERING AND IMPROVED TIGHTER HANDLING & FEATURE ADJUSTABLE LENGTH FOR MORE CASTOR AND BETTER TURN IN. BILLET ALLOY MAIN ROD WITH PLATED STEEL BUCKLE & 18MM SPHERICAL BEARING ROD END. THESE CONTROL ARMS WEIGH IN AT 1050 GRAMS EACH COMPARED TO 1818 GRAMS FOR THE FACTORY ITEMS WHICH ARE NON-ADJUSTABLE AND HAVE BUSHES THAT ARE PRONE TO WEAR. COMES WITH HIGH TENSILE CAP BOLTS, NUTS & WASHERS. Fits: 300ZX, GTS-T, STAGEA, CEFIRO, SILVIA & 180SX $40 trunk cover $100 good condition SR20DET head S13 No cams Might be missing something because it's been a spare that I've been keeping in case I would need it. So it's been moved around over the past few years. $150 Origin rear bumper, hand laid fiberglass for extra flexibility. Sold. $150 Origin side skirts. YouTube video demonstrating strength and flexibility http://www.youtube.com/watch?v=v7GEq_Ncedo $160 (+$18 ship) KTS manf. Japan. Toe arms $170 (cost $400 brand new) S13, S14. Rear Lower control arms. Have1000miles of use, just some paint chips here and there but great condition, bushings are still like new very solid http://www.tcsportline.com/index.php...mart&Itemid=75 $40 HID. Factory off a Y33 Q45 $20 switches I think it's the same for S13/S14/z32/r32-3 $40 (Pair, both left and right) Great condition tail lights for S14 Zenki. Comes with bulb socket holders. $20 to ship $40 (+$16 ship) pair S14 rear brake calipers ( upgrade your S13, these have large 38mm piston for better balance when breaking and easier to lock up with hand brake) $40 S13 SR20DET cold pipe (greddy) T-Clamps Brand new When buying I will sell at least quantity of 2. You can combine whichever you want ($4 off for 6x items) Everything is constructed from stainless steel Nuts have nylon locking washer to prevent backing off T-clamps create a sealing pressure all the way around the hose they are clamping, unlike worm clamps that create a gap where the worm screw is. T-clamps are extremely strong, they can crush a pipe if you wanted to. Can also be used on exhaust $60 off if you buy everything. PRICE (Quantity) size inch (mm). $3.50ea (2) SIZE: 1.1/4 DOWN TO 1.1/8 (32 DOWN TO 29) $3.50ea (2) SIZE: 1.1/2 DOWN TO 1.1/3 (38 DOWN TO 35) $3.75ea (2) SIZE: 1.3/4 DOWN TO 1.5/8 (45 DOWN TO 41) $3.75ea (4) SIZE: 2.1/4 DOWN TO 2.1/8 (57 DOWN TO 54) $3.50ea (4) SIZE: 2.1/2 DOWN TO 2.3/8 (64 DOWN TO 60) $3.50ea (9) SIZE: 2.0/0 DOWN TO 1.7/8 (70 DOWN TO 64) $4.00ea (1) SIZE:2.3/4 DOWN TO 2.1/2 (70 DOWN TO 63) $3.75ea (2) SIZE: 3.1/8 DOWN TO 2.7/8 (80 DOWN TO 73.8) $3.75ea (1) SIZE: 3.1/4 DOWN TO 3.00 (82.6 DOWN TO 77) $3.75ea (4) SIZE: 3.5 DOWN TO 3.1/4 (89 DOWN TO 83) ((((Shipping is $8 for one or up to whatever fits in flat rate envelope. If you want all of them $15 to ship)))) I also have brand new hose 1/2in. (With clamps I think). I think its about 10 feet. $35 Brand new blue oil cooler -10AN ($15 shipping) $6 Brand new cooler fittings -10AN to 1/2in barb. ($6 shipping) $60 Used Greddy relocation kit. S13 SR20DET (will fit other engines that use same oil filter, such as sentra.etc ($13 shipping) $10 Oil thermostat bracket, screws kit with 1/2in fittings. Brand new in box ($6 shipping) SOLD$35 Oil thermostat 1/2NPT. $120 (+$20 ship) 89K. From track car. Everything works. $20 all the relay's +pigtail in pic (+$8 ship) I assume they work fine, came from wrecked cars. $30 N60 up to 350hp. $30 E60 up to 350hp $40ea, both $45. door panel with window handle. Great condition. Left side is missing speaker cover. $25 solid aluminum bushing $60 shaft $20 lock with key sold $15 wheel. $20 wiper switch $20 light switch . $10 Battery junction terminal. Near new condtion (Use this to connect cable through firewall) $25 charged. And comes with bracket to mount in car. $20 rb25det, rb20det. Exhaust gasket. Metal. Brand new. http://www.frsport.com/Cometic-C4177...T_p_12518.html Sold $25 5 speed cross member Sold $50 sr20det ecu. E6 Sold $200 wildwood hydro rear brake kit : bolt on. SOLD$60 solid engine mounts. SOLD$60 NISMO transmission mount Last edited by Hashiriya415; 10-30-2015 at 06:51 AM.. |
08-07-2015, 11:58 AM | #22 |
Trader Rating: (22)
It's a Garrett 2860RS. Bought it brand new in box from Garrett. I still have the Serial barcode code cutout from original box.
The cooler is not greddy... But the other stuff is. |
