03-23-2015, 08:55 PM | #1 |
2006 350z ProAm/Pro2 Drift Car
This is a hard post to write but the time has come to put my 350z Drift car up for sale. I am not in a hurry to sell nor do I NEED to sell, so don't bother with lowball offers. PM me with questions. Serious inquires only please.
This car is turn key ready to compete in FD ProAm or FD Pro2. 2006 Nissan 350Z Chassis Mileage: 51,xxx 420 RWHP, 400 ft. lbs. tq. @ 14psi. Build Specifications Chassis/suspension Custom Formula Drift+ spec roll cage by Parts Shop Max USA Parts Shop Max Pro Coilovers Cusco front a-arms Cusco rear camber/traction arms SPL rear toe arms Sparco 6 point harnesses (valid through 2015) Sparco steering wheel Works bell Team Orange quick release B&M short shifter with Nismo shift knob Parts Shop Max Super Steering Angle Kit (spare parts included) 1” custom extended FLCA by Parts Shop Max USA Custom Hydraulic handbrake by Parts Shop Max USA Vis Ings N Spec replica side skirts and rear bumper w/ JP type N Front Stillen roof spoiler SPI composites 50mm Rear over fenders (set 2 of 2 in the USA) *discontinued Chaser aero vented front fenders w/ custom arches for wheel clearance Custom Aluminum rear fire wall Parts Shop Max Prototype Solid sub frame Risers SPL Solid differential bushings Injected Performance Differential brace Stillen Power Steering cooler Hawk Brake pads PowerSlot Brake Rotors Stoptech Stainless Brake Lines ARP 4” wheel studs Weds Kranze Cerberus I – 18x9.5 -6 front and 18x11 +0 rear Falken RT615K Tires Autometer/stack water temp, oil temp, fuel pressure, boost pressure, and air fuel ratio gauges Engine/ Drivetrain Modified Momentum Performance Single turbo kit Garrett GT3582R w/ 1.03 A/R and Tial SS V-Band Housing Custom Arias Pistons 8:1 compression Brian Crower connecting rods ARP Rod Bolts Balanced rotating assembly Koyo Nissan 350Z R spec Aluminum Radiator Flex a lite 4600 cfm Radiator fans Cry02 Radiator water sprayer kit Mishimoto Nissan 350Z Silicone Radiator Hose Kit Mishimoto Oil Cooler, 19 Row Mishimoto M-Line Intercooler Whiteline adjustable Sway Bars DEI turbo Blanket Momentum Performance Headers Custom straight exhaust Momentum Performance Solid motor mounts Brian Crower Valve springs and retainers Cosworth VQ35HR Head gaskets Cosworth Main and Rod Bearings Cosworth Thrust washers ARP L19 Main and Head studs Nissan Pathfinder cooling mod Modified coolant passages in block Bosch 1000cc injectors Bosh 044 Fuel pump Cosworth Fuel Rails AAM fuel return system Welded differential Parts Shop Max USA coolant swirl pot DEI 12 Gallon Fuel Cell w/ stack fuel level gauge HKS f-con v pro ECU Autometer/stack water temp, oil temp, fuel pressure, boost pressure, and air fuel ratio gauges Custom Mustang 75mm Throttle body w/ cable throttle conversion Tuned on VP110 Race fuel by RACETUNE Engineering Car will be sold without seats. Stock seats can be installed upon request. Asking $27,500.00 |
