Old 03-17-2015, 02:36 AM   #1
JeffSteph108
JeffSteph108's Avatar
JeffSteph108 is an unknown quantity at this point
*FEELER* FS/FT 1985 Toyota Cressida W/ 1JZ-GTE VVT-i swap. Legitimate...
Hey Zilvia, You have probably seen this Cressida around a couple times but it just gets better everytime. I traded it off a year ago to a buddy of mine and just traded back like 4-5 months ago. I am putting my Cress up to see what I can get, I just had it built not very long ago, I got it with a na 2jz already swapped in and ended up getting a 1jz from my other buddy and swapping that in.
THOSE OF YOU THAT VIEWED THE POST BEFORE AND SEEN THE CONS SECTION CHECK IT AGAIN!! CAR IS NO LONGER A PROJECT, RUNS PERFECT AT ITS 100% POTENTIAL AND I DRIVE IT DAILY SO SWOOP HER UP! SHE IS HONESTLY AMAZING, I HOPE MY MIRACLE COMES AND I CAN KEEP HER BUT TILL THEN HERE'S A CHANCE FOR ALL OF YOU INTERESTED!!
134677 chassis miles
All Vin numbers match
Jzx110 1JZ-GTE vvti swap ( got it at 40,000 miles ) refreshed 6000 miles ago
New gaskets through mostly original toyota
New front and rear main seals oem
New cam seals oem
New ocv vvti solenoid (updated part#)
New ocv filter
New timing hydraulic tensioner oem
New timing belt bando
New timing pully oem
New tensioner pully driftmotion
New serpentine belt bando
New vacuum lines
New fuel lines
New aem 320 fuel pump
New v2 aluminum pully set
New oem crank pully
New oem intake manifold gaskets
New spark plus ngk v power (0.30 gap)(11-2-15)
New future fab vvti downpipe 3 inch vband
Mizu 3 row aluminum radiator with dual Mercedes pusher fans ( strong as hell!!!! )
Custom intercooler mounting and piping
Nice new big fmic
Custom 3 inch to 2.5 inch exhaust ( very vibrant smooth 1j sound )
Professionally cleaned and painted engine components
Professionally cleaned and painted block
New royal purple 10w30 11-9-15 with k&n oil filter
New motul synthetic brake and clutch fluid
New redline synthetic power steering fluid
Fresh toyota red coolant
Wiring was done professionally it's so clean
Refreshed transmission Mk4 w58
Internal shifter swap
Redline mt90
Comp clutch lightweight flywheel
Stage 3 action clutch
Oem 2 piece drives shaft
New carrier bearing
Welded diff
Full interior
No loose parts
Seats good condition just a bit of fade
Cluster went out at 134677 only thing that work is gas but is uncalibrated ( doesn't bother me 1jz vvti is very economical )
Have autometer water temp connected to upper radiator hose adapter
Garret boost gauge
Nrg quick release
Dino woodgrain steering wheel with working TRD horn.
DIF shift knob and spin turn ebrake button
Has a nice sound system sony mex-n5000bt head unit with focal 4 inch speakers in front and custom fitted focal 6x9 speakers in the rear for mids also rears are connected to an amp. ( Rear speakers act as a single 10 inch woofer and don't lack vocals )---( I actually need to think about letting it go with think the system,I'll see what I get offered(; )
Ecu mounted in glove box bolted in there
Needs new headliner and fix the sunroof
Exterior is very clean original paint little fade on top and trunk
Riveted drift hood vent looks clean and is grilled very close color match
Missing rear bumper but looks much more aggressive
Only 2 major flaw
Ccw reps 16x9 +10 all around relitively new
Hankook optimo tires 205/55 16
Sentra trunk lip
Cons: needs a new headliner
rear windows don't roll up or down (Still a con /: )
Sunroof doesn't work (Still a con /: )
Cluster went out (Still a con /: )
Tiny power steering leak (FIXED!!)
And retains a really low rev limit (FIXED!!) car runs 100% perfect now! Took it to the master of jz engines Robert over at Sideways performance and got everything running right and smooth. The car is FAST! Revs to redline on all gears smoothly and can take a beating but, I drive her like a granny to save gas (; They Replaced coilpacks and rewired the harness. Have a receipt of all of that!*
I may be forgetting a lot but I have a receipt of all parts ordered and put on, car was built at slide garage in o.c and had help from a very knowledgeable 1jz man from suspicious garage in LA Brea. Both of them love the car and Spencer from sideways performance known for jz swaps in o.c has been trying to get a chance to see her.
You can contact me at (323)599-6725 or my email at [email protected]
Pm or reply
I AM NOT IN A RUSH TO SELL , CURRENTLY A PERFECT DAILY ! ♡(:
$$$ I would say 10.5k, I've been offered a lil more than that from some folks who admire it. It's an old car but if people can appreciate a nice classic toyota and. No flaming, I'll just ignore it. Just honestly give an input and if it helps me thanks and if not and you don't like it move on to another post.
I'm interested in trades plus cash for nice dailys, daily drifters, subarus, bimmers, mercedes, lexus, toyota, nissan, i like all cars less likely of the fwd though or I'm interested in any straight trades I can possibly take use of or flip. I'm really needing the cash to help my family so anyone interested with cash welcome too. Thanks guys! I have more detailed photos of the build if anyone is really interested. The interior pics are from before but I can take recent photos no problem.
Here's another link to the car, I have a little more pics on there
http://losangeles.craigslist.org/wst...314718663.html
Sent from my SAMSUNG-SM-N910A using Tapatalk
Last edited by JeffSteph108; 11-30-2015 at 04:18 AM.. Reason: Car is fixed, no longer a project!! 11-30-15 update!
JeffSteph108 is offline   Reply With Quote
Old 03-17-2015, 02:52 AM   #2
JeffSteph108
I have engine bay pics and detailed build pics just ask. Tapatalk is not letting me upload anymore and most of my pics on the post are cropped because of this aswell. Thank you for you time have a good rest of the morning.
Old 03-20-2015, 07:22 PM   #3
JeffSteph108
Friday bump.. Just got out work.....
Old 03-21-2015, 06:34 AM   #4
Dalton
Dalton is an unknown quantity at this point
I wish you were closer. I would trade you my wrx. GLWS
New to the game
Dalton is offline   Reply With Quote
Old 03-22-2015, 12:07 PM   #5
JeffSteph108
Same.. thanks for the offer tho! Bump.
Old 03-24-2015, 12:23 PM   #6
Hatemy7
Hatemy7's Avatar
Hatemy7 is an unknown quantity at this point
awesome car!!!!
Hatemy7 is offline   Reply With Quote
Old 03-24-2015, 11:47 PM   #7
dizzariot
dizzariot's Avatar
Trader Rating: (47)
dizzariot is close to perfectiondizzariot is close to perfectiondizzariot is close to perfectiondizzariot is close to perfectiondizzariot is close to perfectiondizzariot is close to perfectiondizzariot is close to perfectiondizzariot is close to perfectiondizzariot is close to perfectiondizzariot is close to perfectiondizzariot is close to perfection
Feedback Score: 47 reviews
I still remember when you wanted to trade your Celica for my S13...I should've done it :/
GLWS.
The mark of a true sucka: 'RARE JDM' & 'OLD LOGO NISMO'
dizzariot is offline   Reply With Quote
Old 03-24-2015, 11:52 PM   #8
JeffSteph108
Originally Posted by Hatemy7 View Post
awesome car!!!!
Thanks man!
GLWS.
Haha damn! That was back in highschool.. dude I miss that clean s13 ha, the Celica I even regret giving up...
Thanks bro!
Old 03-24-2015, 11:57 PM   #9
dizzariot
dizzariot's Avatar
Trader Rating: (47)
Thanks bro!
Hahahaha I did, too. Then I found another pretty good one. Trying hard no to let go of this one but the 'responsibility bug' is telling me to get out of the 'car scene' for a while. Even my wife is telling me to keep it...but not build it. Like that's even a fucking thing lol.
If you ever get that Celica back I might have an S13 with you. This one has all the rare shit I've ever dreamed of. I've been busy hahaha.
Old 03-25-2015, 12:06 AM   #10
JeffSteph108
Nice man, dude I don't even want to give up my cress. haha I can't get a car and just watch it sit, I always get bugged to do something to it lol.
Maybe one day when I do I'll hit you up that sounds pretty cool man haha.
Old 03-25-2015, 06:50 PM   #11
can24
can24's Avatar
can24 is an unknown quantity at this point
03 bugeye subi for trade ?? pm me if interested
can24 is offline   Reply With Quote
Old 03-26-2015, 04:48 AM   #12
can24
can24's Avatar
i responded, but your messages are full
if you're interested lmk pm me your #
thanks
Old 03-26-2015, 12:58 PM   #13
JeffSteph108
thanks
Sorry, just cleaned out my pm box everyone.
I pm'd you back with my number and email, I couldn't see the pics. Thanks
Old 03-28-2015, 03:31 AM   #14
JeffSteph108
Spring break is coming up, hopefully I can get a little extra cash to fix the fuel cut problem by swapping over either jzx100 parts or getting a standalone. Don't know yet but, I do want to fix it for the sale because I want people to really feel the full potential this baby has.. man even being held back by only being able to use like 10% throttle and it being dbw stupid etcs-i laggg plus the stock neutral start switch 4k-5k rpm Rev limit, you can still feel this thing kick in! The intercooler piping is all a one piece piping on both sides plus it's very short, I spool up very quickly around like 3k rpm, and it's on a stock automatic jzx110 ecu tune. The engine is so clean and refreshed to like new condition and is a dream. I just drove it home from work which is like 2 hours away and I enjoyed it that much to share my experience and let y'all know it'll probably get way better. Damn I appreciate this car a lot, I hope when I sell this thing and be able to help my family out that someone will still take very good care of her. She won't let you down, she's very solid. Well goodnight zilvia.. see you on another day! BUMP THIS UP!!
Old 03-28-2015, 05:56 PM   #15
wacko2
wacko2's Avatar
wacko2 is making a name for him/her selfwacko2 is making a name for him/her selfwacko2 is making a name for him/her self
Bump, Luis did first 1jz swap
wacko2 is offline   Reply With Quote
Old 03-28-2015, 06:26 PM   #16
JeffSteph108
Lol.. Thanks for the bump. But Luis did a 2jz-ge swap before the 1jz-gte vvti swap. This is the first it has seen a 1j..
And to those that are interested the 1j has a lot done to it I have pics and a receipt waiting at slide garage for the labor done to it and a receipt from driftmotion and frsport for the all the parts purchased for whoever picks it up!!
Old 03-31-2015, 11:11 PM   #17
JeffSteph108
Bump up, I got offered something really interesting. Most likely meeting Saturday. So if anyone else has an interest in her let me know. Thanks guys
Old 04-04-2015, 08:02 PM   #18
JeffSteph108
Bump.. almost off work yess!! Update: Something i noticed for a couple days (nothing big though) it started to seep coolant through the radiator fins which indicate a tiny pinhole. I'm planning to fix it with some radiator sealant because it really isn't that big but it only seeps out on long drives where the coolant is flowing hotter than usual for a period of time but street driving I don't even worry about it. Planned to take it to Spencer from sideways performance this Monday or Tuesday to get things checked for that fuel cut/stock neutral switch Rev limit from the ecu which can literally at the very minimal just be something that isn't wired. I can't find it and I don't want to fry it for trying so I'll have a trusted guy like Spencer check it out for me and for any future buyers or traders. But, never mind all that bs, the car is still driving perfect, starts up every morning, gets me from home to work and school everyday with no hesitations, gets stares from ladies and gentlemen, and never gets dissed, there is a lot of respect for this build. So offer up peeps!! For y'all a price drop to $10k obo and trades [emoji12] thanks guys and have a good evening
Old 04-06-2015, 02:50 PM   #19
JeffSteph108
Update : took the car to a professional radiator shop and had them take a look at the small leak. It was a small pinhole in one of the lower coils. He took the radiator out, flushed it out clean, did his magic and the radiator was fixed. No more leak at all and put some fresh Toyota red in there. Boom-bah-clatt... the car now once again has a coolant flush with brand new coolant, I don't even run Temps past 190°f because of the super powerful dual 12 inch Mercedes fans (; and is free from any leaks or future ones.
Old 04-14-2015, 10:47 AM   #20
JeffSteph108
Bump. Have a guy who's probably coming from San Juan Capistrano to check her out, I'll see how that goes. Let's see some more offers? [emoji6]
Old 05-14-2015, 11:42 AM   #21
JeffSteph108
Bump!!! Car is now fixed. Still retains minor cons but major ones are out of the way! Car is running at its full 100% potential! Runs smooth and Really fast.. check out the post and see what was done. Nothing much but it fixed a whole lot. Car is leak free, rev limit free (revs to redline all gears no problem), and is a perfect daily. Anyone interested hit me up.
Old 05-15-2015, 12:53 AM   #22
Spencer dougherty
Trader Rating: (65)
Feedback Score: 65 reviews
Good car runs great shifts smooth and pulls hard. Very clean inside & out. Good luck with the sale
Old 05-15-2015, 02:21 PM   #23
JeffSteph108
Thanks man! I really wish a miracle comes my way bro.. if it does I'm forsure keeping her... I did so much and finally now it's running right thanks to you guys. But hard times do get the best of you so till that day I can't do nothing. Thanks again dude!
Old 05-20-2015, 01:03 PM   #24
JeffSteph108
BUMP! Going down to West Hills CA today to meet up with an interested trader. Let y'all know how everything goes, any other offers or trades hit me up!
Old 05-20-2015, 03:19 PM   #25
SlvrAvant
SlvrAvant is an unknown quantity at this point
that hood is tough. bump for a cool ass looking carr
SlvrAvant is offline   Reply With Quote
Old 05-28-2015, 10:52 AM   #26
driftertim
driftertim's Avatar
driftertim is a well-known jackass
Send a message via AIM to driftertim Send a message via MSN to driftertim
Bump for a legit car and owner, runs beautifully and sounds great.
FRIENDS DONT LET FRIENDS DRIVE STOCK
1992 Coupe SE
driftertim is offline   Reply With Quote
Old 06-20-2015, 10:23 AM   #27
JeffSteph108
Bump this up! Still for sale or trade, price drop to $9,500. Car still runs beautifully, it's a dream.. only dropped price for the Zilvians interested, nothing wrong with car. Or willing to trade for nice daily, I will consider manual transmission daily drivers or automatic either is okay just offer them up with photos and specs and I'll check it out. Thanks guys!
Old 06-21-2015, 07:08 PM   #28
brian310
brian310's Avatar
brian310 will become famous soon enoughbrian310 will become famous soon enoughbrian310 will become famous soon enoughbrian310 will become famous soon enoughbrian310 will become famous soon enough
damn would trade you for my daily but i would need cash on top so bump for you and glws
tumblr
brian310 is offline   Reply With Quote
Old 06-21-2015, 10:17 PM   #29
JeffSteph108
Hey whatsup Brian! Thanks for the bump bro, haha yeah not trying to add cash as I'm in need for it, thanks tho man.
Old 08-16-2015, 03:20 PM   #30
JeffSteph108
Bump this up. I'll take trades for nice dailies like is300 5speed or ls400 gs400 gs300. Maybe I'll try a 2 door so also will consider sc300s! Let me know
