Old 02-11-2016, 05:30 AM   #1
ZEratic
ZEratic is an unknown quantity at this point
s13 sr20det circuit sports top feel fuel rail and ID injectors help!?
New to this whole installing new parts thing. Can anyone help me figure out how to install a circuit sports top feed fuel rail for the sr20det and 725 cc injector dynamics injectors with it? Kind of confused as to where the fuel rail parts all go in conjunction with the injectors. These are the parts I have.
Fuel rail:
http://www.enjukuracing.com/products...d8lRoCEHnw_wcB
Injectors:
http://ep.yimg.com/ay/yhst-364897734...-engines-7.jpg
thank you!
ZEratic is offline   Reply With Quote
Old 02-11-2016, 07:06 AM   #2
cotbu
cotbu's Avatar
The wires from the original injectors/harness goes in the the green grommets, then in the little female pins, the pins with the wires, go into the sockets/plugs the plugs go on the injectors, that are installed in the fuel rail.
Then install the tuned ecu.
If your original injector wiring is good you may be able to depin them, then insert them into the new plugs. If, the original plugs dont fit.
The stickers get plastered on your windshield.
Sent from my SM-N910T3 using Tapatalk
Old 02-11-2016, 08:09 AM   #3
ZEratic
where do the silver barrel things go ?
Old 02-12-2016, 09:12 AM   #4
cotbu
cotbu's Avatar
Bottom left in the picture?
The wires from the original injectors/harness goes in the the green grommets, then in the little female pins.
If thats what you're calling the silver female pins?
Old 02-12-2016, 04:13 PM   #5
ZEratic
no no in the pic with the fuel rail
Old 02-12-2016, 11:31 PM   #6
cotbu
cotbu's Avatar
They are probably the raisers, theres another picture there that shows the rail installed.
Old 02-13-2016, 01:44 AM   #7
ZEratic
this picture helps me a great deal thank you very much! ill post back on here when it's all in thank you
