07-31-2014, 02:10 PM | #2 |
Did you just start the motor for the first time? If so the rings need to seat so there will be lots of blow by at first. Should get a lot better after break in.
07-31-2014, 03:37 PM | #12 |
How long before the sound the of the motor changed after you started it up the 1st time? Did it start to sound better after a few min of running?
95 240sx RB20 415whp 91 Nx2000 VVL yo |
07-31-2014, 08:38 PM | #17 |
Is that the fitting on the back left of the valve cover? If so nothing is, I was going to put an air filter on it, is that supposed to go to the intake also? I just saw that people have run that to an oil catch can with a filter and thought a filter would be fine. |
07-31-2014, 10:18 PM | #18 |
Trader Rating: (33)
Feedback Score: 33 reviews
Yea, that's supposed to run to a fitting on the back of your intake manifold. There should've been a swivel fitting included with the manifold or you can just get a 90 degree elbow that threads into the back on the manifold to run a hose from your pcv valve off of your valve cover to. It's not supposed to be left open. There should be suction on your catch can as well. I can tell from the picture but I'm guessing there's a filter on the other port of the catch can? Here's a good thread on catch can set ups. http://zilvia.net/f/showthread.php?t...ighlight=catch
07-31-2014, 10:39 PM | #19 | |
mine was the same. |
