Old 10-11-2017, 06:01 PM   #1
boostin_jim
boostin_jim is an unknown quantity at this point
s13 Sr20det need help!
So my car has fuel, spark, compression an getting air but it wont start.. just cranks harness, ecu an plugs are getting power the only thing thats weird is my fuel pressure fluxtuates on prime an when cranking then when the powers off it drops injectors seem to fire fine
boostin_jim is offline   Reply With Quote
Old 10-12-2017, 10:18 AM   #2
jedi03
what pump are you using and is it hard wired?
Old 10-19-2017, 04:26 PM   #3
nisileighty
nisileighty's Avatar
nisileighty is just really nicenisileighty is just really nicenisileighty is just really nicenisileighty is just really nicenisileighty is just really nicenisileighty is just really nicenisileighty is just really nicenisileighty is just really nice
Retime your cam angle sensor.
Buy a Walbro 255 and hardwire it.
Check for fuel leaks
nisileighty is offline   Reply With Quote
Old 10-22-2017, 06:39 AM   #4
boostin_jim
Problem was solved lines got mixed up at the pump!
Old 10-23-2017, 09:02 PM   #5
TheRealSy90
Four Lug Swap
TheRealSy90's Avatar
TheRealSy90 has much to be proud ofTheRealSy90 has much to be proud ofTheRealSy90 has much to be proud ofTheRealSy90 has much to be proud ofTheRealSy90 has much to be proud ofTheRealSy90 has much to be proud ofTheRealSy90 has much to be proud ofTheRealSy90 has much to be proud ofTheRealSy90 has much to be proud ofTheRealSy90 has much to be proud ofTheRealSy90 has much to be proud of
It's normal for the fuel pressure to drop off when you stop cranking. The regulator is at the outlet of the rail and there's nothing keeping the fuel pressure from back flowing to the tank from the rail.
Such a good signature.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
Copyright © 1998 - 2015, Zilvia.net™
