Old 08-20-2003, 11:11 PM   #1
SleepySR
SleepySR is a jewel in the roughSleepySR is a jewel in the roughSleepySR is a jewel in the roughSleepySR is a jewel in the roughSleepySR is a jewel in the roughSleepySR is a jewel in the roughSleepySR is a jewel in the rough
map sensor on SR
just wondering if any body has converted there SR to use a map sensor insted of the maf . just curious on pros and cons of the map sensor set up
http://farm4.static.flickr.com/3509/3279342840_de50549412_m.jpg
SleepySR is offline   Reply With Quote
Old 08-21-2003, 02:01 PM   #2
Tricky-Ricky
Tricky-Ricky is an unknown quantity at this point
I have Emanage+ E-01 which has its own 3 bar map sensor, still using
std AFM but may run ignition map from the map sensor, i think a few aftermarket engine management allow the use of a map sensor, but unless you are outflowing the std AFM or planning big power then its not realy worth it.
Tricky-Ricky is offline   Reply With Quote
