10-23-2016, 01:38 AM | #1 |
Last of my parts, come get what I got left!
finally posting up the last of my parts. Im back in florida, so time to finally let these last parts go. Priced to sell and ready to go.
Btw...IF YOU GOT NOTHING GOOD TO SAY, DON'T POST! Thank you you can reach me promptly at 6-19 five-34 zero312 (text=quickest) for any Q&A or for photos. My hosting got *&#*×. Trades i'd be interested in: 240sx/z32/cd009 5/6spd transmission, tig welder/plasma cutter, mac/snapon toolbox or 225/75/16, 215/85/16 tires. will consider AC service, electrican service or concrete work. What I got --------------------------------------------------------- NISSAN 240sx 12v interior socket - $4 Ka24de stant tstat -sold Nissan rubber trunk bumper new pn:84840-65f00 -$2 PBM black hood spacers /w hardware - sold n60 maf /w cone adapter - sold airtex ka waterpump - sold KRC high volume SR20 power steering pump - $400 s14 zenki silvia grill - SOLD s14 new felpro intake manifold gasket pn:94357 - $5 S14 new felpro oil pan gasket pn:30644 - sold Ka manual trans dust plate -$20 S14 RHD Carbon Fiber Shifter Bezel - SOLD S14 LHD/RHD carbon fiber inner door handle bezels -SOLD S14 LHD & RHD Carbon Fiber Door Handle Window switch- SOLD 3in Topmount Downpipe for KA/ SR) for 4 bolt turbos. - SOLD S14 4 lug hubs (F/R) - $40 (4) Intercooler pipes /w beaded lip (2mm thickness) with 8 t-bolt clamps & 90 deg 3ply coupler - $30 Subframe brace S13/s14 - $30 180sx bumper turn signal (RIGHT) - sold http://i21.photobucket.com/albums/b2...rnsignal-R.jpg S13 bead blasted valve cover - sold Nissan consult /w serial - sold S13 SR Fuel Rail - $20 T3 to T4 angled braced adapter - $20 (4) 370cc phase one injectors /w caps & harness (z32/q45) - $20 Z32 Igniter(does work on SR/RB) - $3 S14 Center console - gone (1) COP coilpack (works on SR/KA) - $5 KA Shifter w/ clip & bushings (no plate) - $10 S14 generic intake pipe /w couplers & clamps - $10 nissan oem new Sidefeed injector complete seal kit (for 4 injectors) - $15 SR turbo hard line - $5 (2) 240sx power transistor PRW-2 - $2 S14 EGR part - $2 KA Throttle Position Sensor (TPS) - sold Everything else Fogel cc-7 6.7cu ft glass front commercial refrigerator -$300 2jz oil filter housing - $20 Aisin Brake master cylinder -$5 2jz arp new rod bolts - $50 2jz oem cam gears -$10 2jz tstat TTH rotater - $20 1jz/2jz timing idler pulley bolt - $5 1jz left over gaskets from a full gasket set -$5 1jz hard lines -$5 1jz stock injectors - $30 1jz alternator pulley -$10 1jz belt tensioner -$20 2jz timing idler tensioner pulley -$10 R154 new throwout bearing -$10 R154 transmission mount - $10 1jz oil pan inspection cover -$5 Ex-d in-d mounts -$5 OEM JZX81 Cressida mounts/brackets (direct swap mounts for 1jz to mount into cressida) - $125 http://s21.photobucket.com/user/Gene...ckets.jpg.html 92 Supra FSM - $80 86 Celica-Supra FSM - $30 1uz felpro new oil pan gasket pn: 30654 -$5 3in muffler silencer bolt in tip - $10 Hurst aluminum pistol grip shifter - $20 Kazama shift knob - $20 (4) FC rx-7 550cc high impedence injectors FLOW Tested (can be used on low impedance systems with use of resistor pack or wiring resistors inline on each Injector) - $125 Hallman Pro RX boost controller - sold Momocorse HB-09 horn button /w locking ring - $15 Pair of 5mm spacers (4/5/6 lug) - $10 5 bolt turbo flange - $5 Sunpro super tach II (4/6/8 cyl) - $10 (6) Gas door gascap holder - fits nissan/toyota/honda hole configuration) - $2 ea Last edited by GeneStarWindGSW; 02-02-2017 at 09:53 PM.. |
12-14-2016, 04:53 PM | #7 |
12-30-2016, 09:35 AM | #12 | |
I'll have to go through them. most are small except for the manifold gaskets. Pm'ed you with update. |
02-10-2017, 05:46 AM | #15 |
How big is the sunpro tach, and will you ship? If it's a smaller one I might be interested. Give me a shipped price when you can.
93 coupe - AutoX/Fun summer daily/Eternal project |
10-02-2017, 10:28 PM | #17 |
still got this stuff
http://zilvia.net/f/showthread.php?t=637070 last of my parts f/s |
