08-08-2018, 12:52 PM | #91 |
Trader Rating: (25)
Feedback Score: 25 reviews
uhhh no..
i bought my last hybrid manifold for $85 shipped. Even having CodyAce do it would be like $250. A used t28 is $300. What lines and gaskets are costing $200? I spent less on gaskets when I did a full rebuild. The bulk of the price comes from ecu and tuning, but after doing so you will most definitely make more power than a stock SR and spend less doing so. People act like you can buy an SR from Japan and throw it right in. You still have to deal with wiring, radiator, intercooler, etc. I spent more on that stuff when I did my first SR than I originally did to boost my KA, and I spent more overall on the SR than I did for my freshly built, forged bottom end KA. You can argue which engine is more capable all you want, but you simply can't argue the price difference. Especially when red tops are going for nearly $3000 these days.
08-08-2018, 01:00 PM | #93 |
Trader Rating: (25)
Actually, I am. I boosted my motor, blew the headgasket, then blew the rings out. I completely rebuilt the motor with forged internals and had an issue with the flywheel that caused the bolts to back out and the flywheel to fall off. I replaced the flywheel, crank(with machining), bearings, head(with machining), and gaskets, and I've still spent less overall than I did on my SR which was ultimately stock.
08-08-2018, 02:37 PM | #94 | |||
heres my old build thread where I did all that in two days at some point http://www.freshalloy.com/showthread...ir-and-Restore Believe me, I know the cost and it isn't what ten KA engines with stock pistons cost. price of a new turbo is the same for both engines so it isn't a factor and makes no difference on one engine or the other. |
08-08-2018, 04:59 PM | #96 |
FYI an sr20 with an EFR turbo, E85, and proper engine management can do 400whp/400ft-lbs (200hp per litre).
(more power and torque than an entry level LS swap) |
08-08-2018, 05:05 PM | #97 | |
...Which brings me to my next point, are you advocating for a KA or an SR? Because you keep talking shit about KAs, then telling OP to go do some Mickey Mouse ghetto hack job like fabbing up intercooler piping that runs the length of the car, and splicing in a water/meth kit that WILL run out of juice while he's driving eventually. And that WILL blow up a KA when it's being fed 12 pounds of boost with nothing to compensate besides a SAFC in Texas heat. If you love SRs so much why don't you just tell him to swap in a stock SR and not deal with any of the bullshit? That being said, even though I would never put a KA-T in my car over an SR, turboing that brand new KA the right way sounds a lot more reliable than throwing in some aging, beat to shit SR that got pulled out of a wrecker somewhere in JP and has been sitting upside-down in a freight container for 2 months. OP: If you want to stay KA, then there's a tried and true recipe to make 300 hp reliably, and its already been mentioned in the thread. $500 Tomei cast manifold (cast because it will NEVER crack) $200 Tomei turbo elbow $0-500 Whatever exhaust you want (stock is good for killing about 20-30 hp) $100-500 Whatever intercooler kit you want (that s15 sidemount setup is pretty slick) $400 S14/15 t28 @ 14 psi $200 740cc injectors $100 z maf $100 turbo lines/mod the oil pan for an oil return $1000 for a decent standalone, I suggest finding a reputable tuner and buying whatever he/she likes to use the most. All that will put you at the price of buying an SR swap from an importer, it will make a little more torque, and you'll have the peace of mind knowing that your engine was in good condition to start with, and that you had eyes on everything that got put on the car. You can go on youtube and look up "tomei making of KA-T" and you'll see their whole R&D process behind building that motor, as well as how much power it made. Actually, thinking of it now, that build is probably something along the lines that you'd be shooting for.
08-08-2018, 05:21 PM | #98 |
Trader Rating: (25)
“No one wants a 20 year old turbo”
...what do you think comes on an sr? And with a good tune a 300-350whp ka will last just as long as that sr. I’ve seen plenty of sr’s blow up at 300hp. Don’t forget we’re talking about a 16k mile ka. You’re not going to make 300+ on an sr without turbo, injector, and ecu upgrades either, so now you’re looking at even more money. I didn’t say anything about how fast you can swap it in.
08-08-2018, 09:04 PM | #99 | |||||||
thanks to everyone for posts
Yep and I would not use it. Why go through all the trouble to install an engine using 20 year old parts that are on the verge of replacement? The issue now with sr20's is age + mileage. Not performance, we know they perform well. The idea being discussed here, the comparison contrast isn't between sr vs ka, and it isn't between hp vs dollars. The real comparison being made here is reliability vs effort, and then we can include cost for a final stats breakdown once the truly reliable, least effort pathways are exposed. And I will address this further if you will bide... Quote:
On the other hand, 400 is pushing it for an OEM sr20. 400rwhp is so easy on a redtop, but its just a tad higher than I would comfortably daily a reliable stock sr20det engine with, personal opinion. Look at the other engine, the LS is barely working at 400 and weighs about the same, whereas the sr20 could go/blow apart any minute due to all that boost and rpm on stock internals and presumably sometimes poor fuel condition. Reliability rears its ugly head in the form of 'potentially unreliable'. Changing engines is always more effort than not changing engines and is less reliable. I can say the LS at 400 would last 10 or 20 years with a 98-99% confidence interval. That is essentially how/why they are made and there are thousands (hundred thousands?) examples. Whereas with sr20's I cannot think/find even one or two good examples of 400hp/20 years, and even if I could it wouldn't form a substantial sample size to draw reasonable confidence/conclusions from. Feel free to add statistical evidence of such models it would be interesting to find some and do some better comparisons. Quote:
always has meth -> timing isn't an issue at 8-10psi of boost -> safc is the best/cheapest alternative, least amount of effort and high reliability. The only thing more reliable is to actually control the timing, which means only slightly less timing (two to 5 degrees), which means less power (5 to 12 ft*lb of torque probs). In other words, its a significant additional cost to rom-tune/stand-alone ($500-$1500) for such an insignificant change (2-5* less timing and 5 to 12~ less torque). What I suggest things I do these statistical analysis so you can rest assured it was an appropriate series of assumptions that led me to that route. Now, the cheap ebay parts, there are some good one and some terrile ones. Ebay radiators WORK GOOD. If you turbo the KA you would want the Aluminum KA radiator anyways (not using plastic end tanks ftw) so the cost is not important. It doesn't matter if you bought a $75 or $200 radiator because EITHER WAY, with BOTH engines, you still have to buy one, whichever one you would have bought to begin with. The same thing goes for an intercooler. You can't say that $intercooler cost is part of the SR swap and nothing to do with the turbo KA because the turbo KA still needs an intercooler. So again, it won't matter if you spent $5 or $500 for an intercooler because thats the same intercooler you would have purchased regardless of which engine you have. The cost of those parts is not part of the equation at all and cannot be fairly used 'against' one engine or the other. Quote:
here is an stand-out example http://www.nsxprime.com/forum/showth...-testing/page8 Quote:
If you opted for 93 only the reduced timing would be a necessity instead of just a recommendation and a SAFC would not work. But I never once suggested pump gas + safc by itself. I mentioned several times that it would be used in conjunction with Methanol/water. Quote:
Ex. if you bought $5000 in parts for the KA engine and blow it up. Where are you going to get another 13k miles KA engine to drop in? That KA motor is worth $800-$1000 if sold at 15k miles to the right person. I would suggest to sell it for $800 and use that money towards a rebuilt SR20 that you follow FSM procedure in a clean room with all the right tools and put a turbo on THAT at 350-400rwhp for ~10 years. At least we know the sr20 will do the job and our effort vs reliability will pay off, IF the motor rebuild goes swimmingly. spectacularly. Whereas the KA Is always/still a wild card, question mark, and irresplacable, and parts from which are un-reusable. To many ifs and oopses I'm afraidses. Quote:
Finally, I would never use a redtop. Its absolutely the most ancient sr20 out there, and lacks VTC. Use the S14 version and maintain the VTC working properly for best results. |
08-08-2018, 10:26 PM | #100 |
Trader Rating: (25)
We’re talking about whp here. Notchtops are rated at 220, s15’s at 250. Put it on the dyno and they MIGHT break 210 at the wheels. Once again, if you’re changing the turbo, therefore requiring a tune” that adds even more to the total price. No thanks, I’d rather spend less and have a freshly rebuilt ka with more power, better power band, and significantly more reliability due to freshness and forgedness. It’s not rocket appliance, it’s easy to comprehend. What’s the downfall, a lower rev limit? 7200 is plenty for me. In fact I bump mine down to 6900.
08-08-2018, 10:30 PM | #101 |
Slapping a turbo on the KA and doing it right would be great if you are going to keep the power around 300whp. It'll be a hell of a lot quicker than stock and probably last quite sometime with a proper tune and supporting mods. I have seen local guys romp on stock KA's on low boost for event after even without fail.
If the car were mine I'd opt for an SR all day, every day. Get your hands on a clean S14 or S15 SR20 and completely refresh it. Keep it stupid simple, get it tuned for whatever octane fuel you have locally and enjoy it. As others have stated, a stock SR is bullet proof if maintained properly, swap it and never look back.
08-08-2018, 10:54 PM | #102 | |
Forged is not better with 4-cylinder typical JDM engines. Forged is less reliable, not good for a daily. Needs proper setup for success. Oil acumulator or rod bearing #1 is toast after 15-20k miles in sr20's I've seen over and over. KA? good ruck |
08-08-2018, 11:12 PM | #103 |
Trader Rating: (25)
You're still missing the point. You changed the turbo, injectors, maf and got a tune, I can only assume on a powerfc since it's the most common. None of that is cheap and adds to the already high price of the SR motorset. Building a KA will still cost less. I disagree with a built motor being unreliable as I have seen many run for years, but for the sake of the argument you could do an oem rebuild, have it blueprinted, and make the same 350whp with just as much, if not more reliability, more torque, and less boost, all for less money.
08-09-2018, 12:09 AM | #104 | |
Sorry man gota buy turbo maf injectors ecu etc... no matter what no matter which engine you pick. If I am forced to buy those things its better to buy for an application that is common so the re-sale value is higher. Or a setup that can cross-platform coexist. Thus the recommendation of a rear mounted 600hp turbo that couldn't care less whether you had the KA or SR or LS or 2J or 1J or RB or VQ application. Swap each engine in, all day long same power output maximum regardless of displacement because its the turbo, not the engine, that makes the power. Invest in the car- win even when you lose the engine Invest in the engine- lose if you lose the engine 15k miles chassis at stake, as an engineer you aren't building an engine or a swap, the engineer is building the car. Chassis support, stability, fabrication that will look mint and serve a higher purpose no matter how the car is used. And will re-route as many parts as possible throughout the car's life to be viable regardless of what is going on with the engine flavor of the week. The KA obviously isn't going to stay forever; they never do. |
08-09-2018, 12:36 AM | #105 | |||
Trader Rating: (25)
I'm not missing the point and I very obviously understand that you have to buy all the stuff considering we're discussing adding a turbo to a non turbo engine. That was by far the most redundant statement possibly in the history of this forum. You clearly are missing the point which is that, and I'd like for this to be the last time I state so please pay attention here: It will still cost less than an SR setup. Quote:
There are too many people that disprove that idiotic statement.
08-09-2018, 12:42 AM | #106 | |||||||
Stop trying to use big words to sound smart and go back to your $10,000 turbo setup, ebay radiator cars in Florida.
08-09-2018, 11:17 AM | #107 | |||
This is very unlikely.
Lets do the labor math: 1. turbo KA engine 2. blow KA engine trying to make 350rwhp (400bhp) cast piston seizure 3. reBuild KA engine (machine work, labor, "DOING IT TWICE") 4. Blow KA engine from stupid mistake or fail machine work 5. reBuild KA engine "doing it three times" 6. Blow KA engine more fail machine work, block is toast 7. Get another KA engine block 8. reBuild KA engine "fourth try" ... No, this doesn't cost less than using the right engine right off the bat. Even if parts are free, machine shop plus labor costs more in terms of time. You ain't going no where fast like that, for cheap. Quote:
Boost is meaningless. It is just a measure of restriction in an intake manifold. Engines do not have "boost capacity" or "boost limits" they have FUEL limits and POWER limits which have nothing to do with fluid restriction. Quote:
So, not wrong |
08-09-2018, 11:24 AM | #108 | |
with that said, im not picking a side but this thread went down the shitter quick. zilvia is alive and well. |
08-09-2018, 11:43 AM | #109 | ||||||
As many have mentioned an SAFC is still required with a rom tune. I also said ROM tune is highly recommended. SAFC would be required regardless and that METH system is easy to re-sell, whereas ROM TUNE for KA engine is NOT easy to re-sell. Quote:
The calculations part goes like this (and this IS A REPEAT you can read above also) The stand-alone is not going to protect the cast fragile KA piston engine. Even with a stand-alone, 93 octane is NOT REALLY SAFE. Some reasons sr20det gets by with that, is because lower 8.5 or 9:1 compression, plus piston oil squirters, plus shorter stroke, plus combustion chamber tech, plus the fluid(air is a fluid) pathways are intended to be high density (the motor was designed with turbocharging in mind). It all adds up. Main girdle support for stability. Coil on plug. I cannot say the same for the KA engine which lacks all of those support features for boost. Here is the predicting the future part: If ANYBODY turbos a factory cast piston KA engine, they are very likely to explode that engine esp if its the first time, and not even their fault. Accidents happen. Its just so extremely common you can't do it without expecting it (always expect the worst). So that's where I 'hit a wall' for this op's car. I seriously doubt he wants to turbo that 17k mile engine, then pull it out a couple months later to completely rebuild it. I don't think that is a very good plan. But that seems to be what everybody wants for it. Even the other guy blew his up and probably has less than 10k on it and claims "all is well" when I know damn well in 20k hes going to need another one. Nah. The op strikes me more as a "set it and forget it" type. 200,000 miles of reliability is desirable in many applications. Built engines typically offer 5-10% of factory reliability, and the factory one is a ticking time bomb no matter who turbos it. So that is why I am so concerned with the "re-sale ability" of all the parts he buys. This is a money saving tactic that will also save headache, by keeping the parts non-KA specific. Not to mention: That KA would be worth more as it sits (sell it for positive money coming in, instead of money going out). This is simple math here. Would you rather have a few months of fun then potentially spend $2000 on machine work wait weeks/months and get something back that needs rebuild again at 20k miles. And even if it doesn't, will show significant signs of skirt/piston wear due to the forged piston clearances required, and pitting/damaged rod bearing due to cold-starts using thick oil with large main bearing clearances (common but avoidable). Or just put that money towards a proper engine that the car was designed for. Rocket science? Quote:
08-09-2018, 11:50 AM | #110 | |
Real professionals know what is worth $$ and it isn't the engine swap or power output. Ex.1 last year I found a dealer that got a Base model 95 with 130k as a trade in. He took $2800 for it (I overpaid) couple weeks later somebody that Mazworx sponsors came down from Canada to get it for $5000 after seeing the underside. Ex.2 two years ago I found a random white 97 for $5200 and was able to get $9800 for it after driving it for a year. I only cleaned them. Out of respect I don't post what I paid and sold my built cars for because the owners might not want that info public. However if you are curious you can always PM me. That said, I tend to double my money because it isn't worth the effort to sell and re-build unless you have something left over once finished. |
08-09-2018, 12:18 PM | #111 | |
I've been KA-T for over 10 years on the same block and only blew the ringlands twice. Once from a bad fuel pump and the other from my stupidity. What did I do both times? Tore the head off, honed the cylinder walls and dropped new pistons in(forged the second time). I guess I still have to blow the motor two more times! lol |
08-09-2018, 12:32 PM | #112 |
Trader Rating: (25)
I really have nothing left to say, your statements are getting increasingly ridiculous. I feel like if we continue you're going to start telling us we're dumb if we don't spend $800 on wheel spacers.
08-09-2018, 12:51 PM | #113 |
Super Moderator
Trader Rating: (73)
Feedback Score: 73 reviews
This dude has taken over the thread with his "matter of fact" opinion.
You guys are constantly rebuking him. Just add him to your ignore list. It's not your civic duty to defend the KA or to prove him wrong. He's on that Florida water. Just let it go.
08-09-2018, 06:53 PM | #115 | |
Anyway, why isn't this shit locked? Same questions are asked by a regular noob, he gets flamed and his shit locked in no time. Same shit is asked by a guy with a nice garage, all of the sudden is a serious 4 page thread. Fuck that, all this info is already out there. Ya'll be the first ones to respond SEARCH!
Tuners are big bullies |
08-10-2018, 09:26 AM | #117 |
no, but from what I've seen you wouldn't have a problem buying one at a good/decent price.
my favorite example to use in this context is IS300s. you can usually find a handful of factory manual/LSD cars within a couple of hours drive. i was able to find mine very quickly. lots of people from the east coast buy them here because they are cheaper, more plentiful, and have less rust. some east coasters buy them here without ever laying eyes on the car and have it shipped back. |
08-10-2018, 11:28 AM | #118 | |
"its no problem just yank the motor do a rebuild and put it back in wtf is the big deal" only blew the ringlands twice rofl The big deal is the whole point (apparently) of using a KA engine to begin with is because "ITS ALREADY IN THE CAR". If you have to remove the engine for ANY REASON it no longer makes sense to put it back in the car. It completely demolishes your arguments of using it because its easy. Now hes done ALL the work of swapping an engine in a car with 20,000 miles (op's car) twice or more, gfj |
08-10-2018, 01:52 PM | #120 |
OMG when did it get so complicated to turbo a ka????
Are we in early 2000's where were running safc + rom tunes ???? Just get a standalone and tune it correctly. This thread hurts my head.. why is there so much discussion on how to ka-t? Its a 240sx not a ferrari. Just mod it how you see fit.
s14 kouki ka-t |
