03-03-2018, 08:05 PM | #1 |
1993 SR20DET 240sx/180sx Hatchback $15,000 OBO
Accessories ------------------ Car has proper A/C. The fill valve either got damaged or loose on the last charge, so it needs to be repaired and system recharged. AEM True boost Gauge and Controller AEM Air Fuel Mixture Gauge DEFI Advance ZD gauge with Oil temp, and Oil pressure Electronic Water Temp and fan controller Appearance ------------------ Painted Porsche Guards Red OEM 180sx body kit: Wing, rear valances, front bumper, side skirts and lights(using adapters no harness cutting) OEM 180sx tail lights S14 front seats, no backseats in this car Replica 180sx front lip Ford GT500 engine vent installed into hood, setup in low pressure area for max engine cooling Engine: ---------------- s14 SR20DET with VTC Nismo lightened flywheel SPEC Stage 2 Clutch Kit Nistune programmable standalone with a standard S14 SR20DET map installed Nistune Programming cable GReddy LS-spec Intercooler Kit Circuit Sport oversized oil pan Setrab oil cooler Tomei sr20det oil block adapter Greddy remote oil filter block Synapse Diverter Valve Circuit Sport Aluminum under panel KOYO 4 core radiator Dual Mishimoto Heavy Duty 12" fans Suspension and driveline: -------------- Five lug conversion using ICHIBA hubs(they use OEM bearings) Fortune Auto 500 coil-overs 17x8 Enkei RPF1 SPL PRO V5 Outer Tie Rod Ends Tein TRS01-P2410 Inner Tie Rods Circuit Sports Rear Toe Links Circuit Sports Rear Traction Rods Circuit Sports S13 Rear Upper Control Arms Circuit Sports Front Tension Rods Viscous LSD Brakes: ------------ 300zx rebuilt front calipers 300zx rear calipers 300zx rear drum parking brake, adapted for 240sx hand brake braided brake lines Upgraded brake booster, maintains same correct braking bias with 300zx brakes HAWK HP STREET/RACE PADS Upgraded Rotors Exhaust ------------------- HKS 3" Sport Exhaust More pictures listed in craigslist ad below. Price is $15,000 OBO; OBO means make an offer, the worst I can say is no, I'm flexible on pricing. Car drives great, I'm currently paying an arm and a leg to store it so it needs to go. https://miami.craigslist.org/brw/cto...511198119.html |
03-03-2018, 08:13 PM | #2 |
You need to post the info on the thread and not just link the CL ad. Forum rules.
GLWS
03-10-2018, 09:35 AM | #6 |
Thanks for looking. The picture at the top is with Enkei EDR9s, but there is a picture with the RPF1s, i think third down. Also the CL has RPF1 shots. I think the car looked better with the EDR9s, but I went with the RPF1s because they're so much lighter. The RPF1s are what's on it now.
