10-22-2018, 06:17 PM | #1 |
1995 Nissan 240sx
For Sale is a 1995 Nissan 240sx base model factory 5 speed, clean title. Asking $6,000 OBO, not looking for any trades. Car has a Sr20det engine swap with a lot of extras. Drives well and is mechanically sound but is in need of paint and body work. Engine swap was completed in 2008. Car served as a daily driver for about two years after the swap and has since been driven a couple of times a week.
Car is in the Jacksonville, Florida area. PM for details or with questions. Drivetrain: • S13 redtop sr20det • Apexi metal head gasket • Tomei adjustable cam gears • Rocker arm stoppers • HKS cams • Nismo fuel pressure regulator • Koyorad aluminum radiator • Aluminum coolant tank • Aluminum power steering reservoir (Not Installed) • Flex a Lite dual 12 inch fans with controller • Z32maf • Greddy aluminum pulleys • Greddy high capacity oil pan • Walbro 255 fuel pump • Apexi super suction intake • Oil filter relocation kit with steal braided lines • Greddy oil catch tank • Blitz front mount intercooler with full hot/cold hard piping • HKS SSQV BOV • Megan racing tubular exhaust manifold • Greddy turbo elbow • Apexi down pipe • Test pipe (cat delete) • Apexi N1 dual exhaust • Drive Shaft Shop aluminum one-piece drive shaft • J30 limited slip differential • Battery relocated to trunk • Light weight flywheel • Nismo engine and transmission mounts • Samco silicone radiator hoses • Nismo radiator cap • Nismo oil filler cap Electronics: • Apexi AVCR boost controller • Apexi AFC neo air fuel controller • Defi racer boost, water temp, oil temp (Partially Installed) and oil pressure gauges • AEM air fuel ratio gauge • HKS turbo timer Interior: • NRG steering wheel release • Personal Steering wheel • Dmax blue checkered floor mats • Nismo shift knob and boot Chassis: • Nismo clutch slave cylinder with steal braided line • KYB GR2 shocks • Tenzo R springs • Circuit sports caster, camber, toe and traction links • SPL aluminum rear sub frame bushings • SPL aluminum differential bushings • Energy Suspension Poly suspension bushings • Suspension Techniques front and rear sway bars • Moog ball joints all around • Elite motorsports 17x9 +15 wheels Extra/Spare Parts: • A/C components (Not installed, I have the compressor, some of the lines and the condenser) • S13 blacktop sr20 long block (Factory assembled head and block. Low compression, needs rebuild) • OEM genuine nissan rear bumper • Misc Parts Issues: • Cracked driver side mirror glass • Needs paint or wrap • Body work (Dings, a-pillar and right rear damage) • Minor corrosion in spare tire well • Interior wear/cracked trim • Cracked Dash Last edited by SR20Driftking4lyf; 11-08-2018 at 06:10 PM.. |
11-08-2018, 06:09 PM | #5 |
Had some questions regarding the body work, rust and interior condition.
Here are some additional pictures. Rust in trunk. Passanger A-Pillar rust. Driver side fender. Driver side quarter panel. Passenger side quarter panel. New OEM Nissan bumper included in sale. Hood corner. |
