Old 06-11-2011, 04:49 PM   #1
Jonathong
Jonathong's Avatar
Jonathong is an unknown quantity at this point
wtf is going on with my car.
ok as im driving my car, the car will rev higher then drop down while driving. for example ill be on 3nd gear and ill be on 3k rpm then when i try to gas it from there it will shoot and rev all the way to like 4 or 5k then drop to the appropriate rev like 3500 rpm. The sound im hearing sounds like im in neutral revving but im not. Any input on this would be nice.
Jonathong is offline   Reply With Quote
Old 06-11-2011, 04:54 PM   #2
PIN GIO 2
PIN GIO 2's Avatar
PIN GIO 2 is an unknown quantity at this point
Send a message via AIM to PIN GIO 2
wanna know that i have same problem.
PIN GIO 2 is offline   Reply With Quote
Old 06-11-2011, 04:55 PM   #3
Jonathong
Jonathong's Avatar
I knew i wasnt the only one having this promblem!
Old 06-11-2011, 06:05 PM   #4
Razi
Razi is an unknown quantity at this point
Are you sure your clutch isn't slipping?
Razi is offline   Reply With Quote
Old 06-11-2011, 06:10 PM   #5
NIZzS13
NIZzS13 is an unknown quantity at this point
I need a little more info on that Issue. Heavy throttle, lite throttle, only in gear, ?
NIZzS13 is offline   Reply With Quote
Old 06-11-2011, 06:15 PM   #6
Jonathong
Jonathong's Avatar
yea, i think its the clutch slippen. it has the symptoms of a cluthc slippen and out of all the people i asked they said the same thing
Old 06-13-2011, 04:36 PM   #7
Drakey
Drakey is an unknown quantity at this point
Clutch. How many ks on it? You'll notice it on the hwy best. Drop to 5th (or 4th on a 5 speed) and floor it. You'll see the rpms rise but speed remains constant as you start boosting or entering your torque range.
Upgrade your flywheel when you do the clutch!
Drakey is offline   Reply With Quote
Old 06-13-2011, 05:30 PM   #8
Hashiriya415
Hashiriya415's Avatar
Trader Rating: (22)
Hashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enough
Feedback Score: 22 reviews
Clutch slip
YouTube - ‪SR20DET GT2860 64a/r Worn clutch slip 16psi wastegate .avi‬‏
Hashiriya415 is offline   Reply With Quote
Old 06-14-2011, 03:18 AM   #9
Jonathong
Jonathong's Avatar
This is exactly what it's starting to do. And yea I'm getting an exedy oe clutch and a fidanza flywheel, so I think that should be good enough.
Old 06-15-2011, 08:44 AM   #10
Drakey
Yeah mate, It's definitely the clutch. You should be able to get a clutch/flywheel set for cheaper. I'm not sure where you live... But I live in J-Land and can speak enough Japanese, so I yahoo auctions the parts for dirt cheap. Do a set if you can find it. Make sure you think about what you are going to do with the car in the future. No better time to go to a twin plate than now if you are after huge numbers...
If you are just fine where you are, def. do the flywheel. It's frigging amazing the difference it makes! I hope you have honed your heel and toe though! Coz those RPMs just DROP!
Enjoy mate!!!
-Don
