04-29-2015, 09:16 AM | #1 |
Trader Rating: (57)
Feedback Score: 57 reviews
NissanParts.cc | GKTECH HIGH MISALIGNMENT TIE ROD ENDS 64 DEGREES QA1 14mm | $138.95
GKTECH HIGH MISALIGNMENT TIE ROD ENDS 64 DEGREES QA1 14mm S14 Product DescriptionWe have the GKTech High Misalignment Tie Rod Sets in stock, ready to ship! $138.95 SHIPPED to 48 States. PURCHASE HERE: http://nissanparts.cc/partlocator/in...catalogid=9759 GKTECH have teamed up with QA1 to produce these high misalignment (64 degrees) tie rod ends. These tie rod ends provide up to 25mm of bump steer correction and also come with 3 different length rods (standard length, +15mm and +35mm's). Although these may look pretty similar to other tie rod ends on the market, don't be fooled as they are different (in a good way). Almost all tie rod ends on the market that use rose joints are NOT using high misalignment bearings and wear out in no time at all. OEM type tie rod ends provide around 60 degrees of misalignment and it is critical that around this level of misalignment is kept. Another common issue with most aftermarket style tie rod ends is that there is no protection from dust and dirt. We've developed dust boots specifically to suit the QA1 PCYML10T rose joints that we use in our kit. It's also pretty common for shanks to bend under high loads, our shanks have a tensile strength of 176ksi (class 12.9) - Corrects bump steer - Uses QA1 5/8" high misalignment rose joints - 3 different length rods (standard length, +15mm and +35mm's) included - 14mm - Dust boots included Vehicle Compatibility: - Nissan S13 Silvia - Nissan 180sx - Nissan S14 200SX - Nissan S15 200SX - Nissan Skyline R32 GTS-T - Nissan Skyline R33 GTS-T - Nissan Skyline R34 GTS-T - Nissan A31 Cefiro |
