Old 07-21-2018, 06:53 PM   #1
GX3
GX3 is an unknown quantity at this point
SR 1998 s14 with Sr20det black top
Hey I’m new to this website and I was hoping some one could help me with my s14 black top.
I just got this car two weeks ago and I notice this issue it had. Every time I came to a complete stop my car would bog out/ cut off as well when I turn the car on if it’s cold it idles perfect, but once it start warming up to it’s normal temp rpms start to drop and if you floor it the car cuts off. Also the car has no power what so ever on first and second gear it takes it a while to build up speed.
I’ve tried changing the coolent sensor, changed spark plugs, messed with the tps, messed with the maf, checked for leaks idk what els to check...?
GX3 is offline   Reply With Quote
Old 07-21-2018, 07:41 PM   #2
Kingtal0n
Kingtal0n's Avatar
boost leaks, check leaking bypass,
Old 07-21-2018, 08:11 PM   #3
GX3
Hey kingtal0n I’ve actually tried that as well and no leaks but some people have told me as well to check if I have the right ecu for my blacktop but I wouldn’t know where to lock up if I do have the right one
Old 07-21-2018, 09:21 PM   #4
Kingtal0n
Kingtal0n's Avatar
1. compression test
2. pressure test
3. timing test
whats the wideband say....
....4. get a wideband
Old 07-22-2018, 08:34 AM   #5
rellik27
rellik27 is an unknown quantity at this point
Is the blow off valve recirculated?
rellik27 is offline   Reply With Quote
Old 07-22-2018, 10:57 AM   #6
GX3
No it’s not recirculated
Old 07-22-2018, 10:59 AM   #7
GX3
Originally Posted by Kingtal0n View Post
1. compression test
2. pressure test
3. timing test
Yeah that’s going to be my next step to get a wideband and if doesn’t work I’ll post the numbers it was making. Thanks
Old 07-22-2018, 11:10 AM   #8
Kingtal0n
Kingtal0n's Avatar
these engines are remarkably simple.
Fuel goes
maf -> ecu -> injectors
spark goes
cas -> ecu -> coils
The only places to really screw up here are
1. timing
2. maf related (boost / pressure leak or incorrect maf, placement, position, recirculation interference, all of that stuff)
and of course there is always
3. general misc. (wrong ecu/leaking injectors/wiring related/bad fuel pump/etc) but these are more apparent
Old 07-22-2018, 11:20 AM   #9
GX3
Fuel goes
spark goes
cas -> ecu -> coils
1. timing
2. maf related (boost / pressure leak or incorrect maf)
Thanks I really appreciate it I’ll get working today and checking all of that out and see what I can find.
Old 07-22-2018, 11:28 AM   #10
GX3
Fuel goes
spark goes
cas -> ecu -> coils
1. timing
One last thing how can I find out what ecu is the correct one for my black top
Old 07-22-2018, 12:57 PM   #11
Kingtal0n
Kingtal0n's Avatar
1998 Notchtop with VTC Engine uses black "NA" ECU
1995-1996.5 uses red "WC" ECU
1996.5-1997 uses black "WC" ECU
iirc Both WC Ecu share a harness, but the NA ECU will NOT Plug into WC harness. So you can not possible have the wrong ECU since it wouldn't plug into the harness (apparently )
Old 07-22-2018, 02:24 PM   #12
wurley
wurley's Avatar
wurley is an unknown quantity at this point
also make sure the maf is an adequate distance away from the turbo.
@hiddenkouki
WTB: FRONT S14 SILVIA Q'S SEATS purple zebra)
wurley is offline   Reply With Quote
Old 07-22-2018, 05:28 PM   #13
rellik27
recirculate it, it messes up your maf readings. Thats probably why your car shuts off when you come to a stop. Try that first before you waste money, could solve your other problems.
Old 07-23-2018, 12:36 AM   #14
shobotan
shobotan's Avatar
shobotan is an unknown quantity at this point
Add to the list
Check the IACV - they can get clogged up with carbon residue.
Dismantle & clean and you should get a stable idle.
Check if the O2 sensor is still working this can affect idle quality when the car is warmed up.
MECHANICAL INJURNEER
shobotan is online now   Reply With Quote
