Old 04-26-2014, 03:34 PM   #16561
zombiewolf513
zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513
Does anyone have tips on holding a swivel fitting still while tightening it? I have a 45degree fitting that keeps turning while I tighten it, I'm having trouble holding it at the right angle I need it at while I tighten the nut.
zombiewolf513 is offline   Reply With Quote
Old 04-26-2014, 03:44 PM   #16562
NJs13_1993
NJs13_1993's Avatar
NJs13_1993 is a glorious beacon of lightNJs13_1993 is a glorious beacon of lightNJs13_1993 is a glorious beacon of lightNJs13_1993 is a glorious beacon of lightNJs13_1993 is a glorious beacon of lightNJs13_1993 is a glorious beacon of lightNJs13_1993 is a glorious beacon of lightNJs13_1993 is a glorious beacon of lightNJs13_1993 is a glorious beacon of lightNJs13_1993 is a glorious beacon of lightNJs13_1993 is a glorious beacon of light
When setting a tps on a KA should it be set at the resistance rating with the sensor unplugged or at the voltage on the signal wire when it's plugged in?
Originally Posted by hellion240sx View Post
Zilvians gonna zilvia...
NJs13_1993 is offline   Reply With Quote
Old 04-26-2014, 05:37 PM   #16563
Gar9854
Gar9854 is an unknown quantity at this point
Should or shouldn't isis turbo lines have a little slack/wiggle room at the 90 degree fittings
Gar9854 is offline   Reply With Quote
Old 04-26-2014, 06:00 PM   #16564
zombiewolf513
uninstalled yes, installed no
Old 04-26-2014, 06:05 PM   #16565
Gar9854
Even where the soft line meets the hard 90?
Old 04-26-2014, 06:42 PM   #16566
VNG704
VNG704's Avatar
VNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond repute
Originally Posted by jameswouldgo View Post
So I am looking at some new clutches to go with either a Clutch Masters FX300 or an Act NS1-HDSS/XTSS. Which one do you guys prefer? I want a clutch that is easy for daily driving also stop and go traffic.
I would lean towards ACT and choose one that is enough to handle how much torque your car's putting out. For daily driving, something with a sprung hub and anything labeled stage 1 through 3, but it's all subjective.
VNG704 is offline   Reply With Quote
Old 04-26-2014, 09:03 PM   #16567
acslater9
acslater9's Avatar
acslater9 is an unknown quantity at this point
Alright, so I decided to adjust my throttle cable and every single time I adjust the cable I check to see if my pedal is is stiff. At first when I press on the gas it feels normal, but once I push it down it looses again. What do I need to do so it can stay stiff? Thanks.
acslater9 is offline   Reply With Quote
Old 04-26-2014, 10:37 PM   #16568
simmode1
simmode1's Avatar
simmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfection
Send a message via Yahoo to simmode1
I know most of this aero is Hot Road, but can someone please identify the front fenders & where to get them. Pretty sure they're not Koguchi either...
Originally Posted by REVGASM View Post
saw this on rangerstyle.
simmode1 is offline   Reply With Quote
Old 04-26-2014, 10:50 PM   #16569
mechanicalmoron
mechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nice
Plugged in. slip a thin paper clip up by the wires, into the back of the plug, for your probes.
mechanicalmoron is offline   Reply With Quote
Old 04-27-2014, 06:56 AM   #16570
NJs13_1993
NJs13_1993's Avatar
Thanks. I read to do both but when the voltage I right the resistance is off and vice versa so I wanted to check
Old 04-27-2014, 08:46 AM   #16571
I'm Redline
I'm Redline's Avatar
ACT XTSS will hold 350'# of torque. This means most four cylinders up to about 400hp will work with this clutch. With the accompanying 13# flywheel, a nice combo as most of the cubic displacements to around 2.6L only produces 350'# on 8-12 pounds of boost. You go more boost, you will need a multi puck disc that as you all know has the street manners of a crack whore
My work in progress...
Old 04-28-2014, 09:39 AM   #16572
juhd
juhd is an unknown quantity at this point
so i just did a five lug conversion on my s13 and im using non-abs s14 rotors in the front. They are like 1-2mm thicker than what i had on and when i drive im guessing the rotor just rubs on the pads? will this go away over time since the pads will get thinner?
juhd is offline   Reply With Quote
Old 04-28-2014, 10:08 AM   #16573
yetijeff
yetijeff's Avatar
yetijeff is an unknown quantity at this point
1-2 mm thicker shouldn't rub. But no if they're dragging u did something wrong. And it won't just wear out it will get hot as shit and seize up your wheel
yetijeff is offline   Reply With Quote
Old 04-28-2014, 11:01 AM   #16574
O$mo
O$mo's Avatar
O$mo is an unknown quantity at this point
I want more camber in the front of my s14, I already maxed out my PBM camber plates (Please do not suggest slotting the top coil over mount hole)
I was interested in extending my FLCA 25mm I but idk if i need longer inner tie rods, and if i also need other supporting modifications.
Thanks,
Oz.
O$mo is offline   Reply With Quote
Old 04-28-2014, 11:16 AM   #16575
angel mkiv
angel mkiv's Avatar
angel mkiv is an unknown quantity at this point
I just finished assembling my sr20det from a rebuild on a stand and the last thing I needed to do was to install the oil pan..so without thinking about it I flipped the motor and put the pan on..my question is should I be worried about the lifters loosing there prime? It was flipped for about a hour or so..?
Instagram username:angelmkiv
angel mkiv is offline   Reply With Quote
Old 04-28-2014, 12:28 PM   #16576
acslater9
acslater9's Avatar
The plastic piece that lies behind the gas pedal that holds the cable, is that suppose to be intact? Meaning it is not suppose to be loose, correct?
If so how can I repair this issue? Any place to get that piece specifically? Thanks.
Old 04-28-2014, 12:30 PM   #16577
VNG704
VNG704's Avatar
Yes, rebleed them.
Old 04-28-2014, 05:41 PM   #16578
az_240
az_240's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
Thanks,
Oz.
Yes, longer inner tie rods will be needed.
Old 04-28-2014, 08:42 PM   #16579
Jrbar89
Jrbar89's Avatar
Jrbar89 is an unknown quantity at this point
hey i was wondering what do i need to make around 400 safely on my sr. im gathering parts and right now i just have a megan bottom mount mani, 880cc injectors tomi ecu. and i planing on buy BC 264 cams and im not sure what turbo. i seen some offbrand 2871r that say they had made 400 450 but im not sure if thats true or safe. any set up tips? im going for cheap power lol. mani bought for 75 injectors 100 ecu came with the car i can grab a z32 maf for 50. just the cams and turbo i need help on choosing.
Jrbar89 is offline   Reply With Quote
Old 04-28-2014, 10:34 PM   #16580
juhd
i have silk road rma8 and i dont have a spanner wrench to adjust them. i tried using a raceland spanner wrench but didnt fit. anyone know what spanner wrench i could use?
Old 04-28-2014, 10:56 PM   #16581
Edwin562
Edwin562's Avatar
I'm in need to upgrade my radiator before the summer comes... My only concern is, I have heard that some radiators require the OEM fan shroud to be trimmed and some radiators don't require trimming... my question is why, and which radiators don't require trimming if any apply.
This is going on a S13 SR20DET
Old 04-28-2014, 11:02 PM   #16582
zombiewolf513
Flathead and hammer?
Old 04-29-2014, 06:58 AM   #16583
simmode1
simmode1's Avatar
It would copy Codyace's setup. Its tried & true.
http://forums.nicoclub.com/400-whp-s...r-t213470.html
Old 04-29-2014, 07:09 AM   #16584
JBB
JBB is an unknown quantity at this point
Cheap and reliable dont go hand in hand. I wouldnt buy a knockoff turbo, but thats just my opinion.
Other things to consider:
-BC cams aren't degreed correctly and aren't the greatest unless you plan on getting adjustable cam gears -- then they can be really good. I would recommend HKS step 1's or some JWT cams if you dont want to upgrade your springs/retainers. If you've got titanium hardware then HKS step 2's are awesome and so are the JWT S4.
-Will your current clutch handle ~350ish ft/lbs of torque? If not, you'll need to upgrade that for that kind of horsepower, or run lower boost
-How are you tuning? Factor in the cost of a reflash if you're using an enthalpy tune, or $ for the tuner's time if using a standalone (probably not if you are going the cheap route)
-What size are your wheels and the tires on them? Will you even be able to put that power to the ground?
-Are you running stock brakes? 400hp with single piston calipers sounds like a death wish
-Do you have a generic tiny intercooler?
Its not always as easy at is seems...you know...buy a few parts and throw it on and hit that magic 400hp number
JBB is offline   Reply With Quote
Old 04-29-2014, 07:11 AM   #16585
JBB
Ouch, flipped the motor just to install the oil pan? :P Come on man, just get on the ground to do that! I would do as the other person suggested and bleed them again. It sucks to have to take out the cams and everything but would you rather do it now or when the motor is in the car?
Old 04-29-2014, 10:08 AM   #16586
Standard
Standard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud of
Id say just get the the radiator you want, if you have to trim your shroud, big deal, do it. However my stock fan shroud fits perfectly on my Mishimoto rad, no trimming needed. This is on a twin cam KA though, NOT a SR20
Standard is offline   Reply With Quote
Old 04-29-2014, 01:10 PM   #16587
Jrbar89
Jrbar89's Avatar
ok kol so i will go with hks then for cams. My clutch is starting to go out so i was going upgrade it anyways suggestions on clutch kit. the brakes are stock right now but was looking at buy z32 brakes would that be better? i have two sets of tires both 17 245/45 and 215/45 didnt think about the tires lol. I have a greddy intercooler kit big as intercooler. All this is happening down the road might not even be this year im just needing some advice on it. the turbos i was looking at where these and come with a year warranty. thoughts? http://www.twistedmotionlv.com/apps/...s/show/4052729
http://www.twistedmotionlv.com/apps/...s/show/3634736
Old 04-29-2014, 01:26 PM   #16588
Lompang
Lompang is an unknown quantity at this point
Trunk hole in my s14 fucked up cause of shimmying. Key fits only like a little bit more than half way can't turn it since it's not fully in any way to fix it? Metal hole sagging a bit on to a metal piece to prevent me from putting key. Trunk release in my car is disconnected never used it.
Lompang is offline   Reply With Quote
Old 04-29-2014, 02:14 PM   #16589
89hatchman
89hatchman is an unknown quantity at this point
If everything is about suspension stiffness, then why hasn't a manufacturer come out with "coilovers" that are just solid struts that have an adjustable height? Most guys where I'm drifting don't daily their car at all, they're all track cars. Wouldn't it make sense to absolutely eliminate body roll since most guys are going slammed anyways?
89hatchman is offline   Reply With Quote
Old 04-29-2014, 09:04 PM   #16590
JBB
I have 10/8 springs and couldnt imagine going any stiffer. It would probably cause you to puke or rattle your kidneys into being inoperative
