07-22-2011, 09:51 PM | #6961 | |
07-22-2011, 10:27 PM | #6962 |
Trader Rating: (60)
Feedback Score: 60 reviews
Ok I did a little more search and found out u copy and pasted that answer
difference between jdm vlsd and usdm vlsd - Nissan 240SX Forums That conversation was about clutch types not ratio so I'm think there's a diffrents still. Please if u don't know for sure don't post
Want to roll fenders, custom gauge pod pm me |
07-22-2011, 10:39 PM | #6963 |
AFC #1
S14 SR20DE/T MT are 4.083
S14 SR20DET AT is 3.916 S14 SR20DE AT is 4.083 Pop the pumpkin off and rotate till you see the numbers stamped on the ring gear. 49/12 = 4.083 47/12 = 3.916
07-23-2011, 10:51 AM | #6964 | ||||||
Trader Rating: (58)
Feedback Score: 58 reviews
I'd assume the mis alignment bushings could work in reverse, but you'd probably need to install them opposite of how you'd do it in a S13 no? Quote:
PS: Push those vacuum linees on those fittings more. Quote:
You can also put a VLSD unit into your current housing if you're that concerned as well. Or cheat and count driveshaft revolution per tire revolution. If it goes over 4 it's a 4.08 Less mess that way
07-23-2011, 11:18 AM | #6965 | |
Trader Rating: (31)
Feedback Score: 31 reviews
I've seen alot of people Put S15 frames in a S13 with diff bushings, but thats all I could find searching for what I'm asking. Clearly the S14 should be better than S13. *Some people say its a direct replacement and Lines up perfect/same as S14 with extra bracing/diff suspension geometry. I need more info on S15 Subframe.
z-tERty-2 |
07-23-2011, 02:35 PM | #6967 | ||
AFC #1
The lower you have to with the block because it will jack the head up. The upper is hit and miss if the bolts line up or not.
07-23-2011, 11:19 PM | #6968 |
anyone ever have a cv boot rip from rubbing the RUCA?
I drove my car after a few years today, and i got back and noticed the passenger side exploded and the driver side left black marks from the boot on the RUCA. my car isnt even as low as it used to be and ive never had this problem...maybe they are just old/weathered? S14, cusco ruca, low chassis, blowin cv boots. |
07-24-2011, 09:00 AM | #6969 |
I did some searches and came up with a few leads that lead nowhere...can anyone point me in the direction of this build...if there is one out there? Or another build using a BN Sports Blister widebody? THX
07-24-2011, 05:20 PM | #6970 |
OK so I tried looking for over a half hour so I will post here. I have a 98 base model 240SX and was thinking about going with the ichiba 5 lug conversion. is that all I'll need other than 5 lug wheels and rotors or is that it.
07-24-2011, 05:32 PM | #6971 |
AFC #1
Conversion hubs are for S13's. If you have a S14 just get OEM 5-Lug hubs and bearings.
07-24-2011, 07:54 PM | #6972 |
Trader Rating: (26)
Feedback Score: 26 reviews
S14 240sx question,
Would it be easier to get 10mm bolt on spacers or just get some 60mm extended wheel studs and get slip on spacers? My main concern is with the extended studs. Dont want to have to buy new lug nuts haha.
IG/TikTok-ThatS14_Z06guy |
07-25-2011, 04:13 PM | #6973 |
OEM Steering Wheels
I'm looking at steering wheels, a leather upgrade wheel for my S14. I like the 4th generation Maxima steering wheels and searching I found it fits (very close to the Kouki S13 wheel). I'm wondering if the early 2000's Sentra SE/SE-R/Spec-V steering wheels will fit (as in splines to the stock and turn signals, I'll figure out the C/C)? I remember it was comfortable when driving my brothers 2002 SE, and it has a sporty look to it, a nice update. Any Information?
07-25-2011, 04:44 PM | #6974 | |
Trader Rating: (58)
With that said, you could get the ARP studs for our cars, I believe they retain factory lugs. On my personal car, I run aftermarket studs front and rear, and just run domestic style lug nuts.
07-25-2011, 07:27 PM | #6976 |
so i have an apexi pfc and commander for my s14 sr20det that was professionally tuned. ive never had nor messed around with a pfc. my question is if my battery dies or i disconnect the cables to replace it will my pfc settings be lost?
07-25-2011, 07:44 PM | #6979 | |
AFC #1
Some people wire the constant to switched for an easier wiring job. It's fine on a stock ecu but the PFC will never save it's settings if it doesn't have it. Every time you start up is like starting it for the first time on the base tune.
07-25-2011, 07:49 PM | #6981 |
07-25-2011, 07:51 PM | #6983 | |
07-26-2011, 02:42 AM | #6987 |
07-26-2011, 06:39 AM | #6988 |
07-26-2011, 07:03 AM | #6989 | ||
Trader Rating: (58)
1. When someone doesn't feel like getting the right hose, or a correct hose isn't possible when putting Engine XYZ in Chassis ABC 2. If you're using a high pressure (race cars somtimes) system, and want to eliminate long lengths of hose (although at that pressure it's easier to go with A/N lines, or Sillicone high pressure hose. Quote:
07-26-2011, 09:18 AM | #6990 |
I will be buying valve guides very quickly here and I need to know if there is anything besides OEM Nissan at $20 a piece that will last a long time on a turbo ka. I've seen Z1 and supertech bronze so far. Are these durable? Or drop the dime on Nissan?
