04-05-2005, 09:08 PM | #1 |
no low beam headlights, but got high beams ?
ok i checked all the fuses and the 2 under the hood for the regular low beams and they are all good. does anyone have any ideas why my low beams dont work, i also replaced the headlights and still nuttin. this sux cause until i get it fixed i gotta run high beams at night and lower my headlights by hand so i dont blind the hell outta people and or get pulled over someone please help thanx
04-07-2005, 10:18 PM | #7 |
Hrm.... that same thing happened to my s13 as well (on one headlight).
I just replaced the one headlight and it worked lol
White '90 S13 Fastback (SOLD in '07) |
04-07-2005, 10:59 PM | #8 |
I had this similar problem also, first it was my plugs, then it was the fuse, then it went back to the plug, i switched the headlight and the fuse and the plug and it worked. It'll be irritating and annoying i tell you. Hope you get it fix.
04-08-2005, 07:21 AM | #9 |
change youre none working headlight to the side where low beam is working. If the low beam is working on the other side, its something in your wiring/switch, If not, its just the light
hope this help |
